Are the solutions to first order ODE's the same or different for x=a?
  • Thread starter Thread starter mhill
    First order Ode
The first order ODEs y'(x)g(x)=0 and y'(x)g(x)=δ(x-a) yield different solutions despite being equal for x≠a. The solution for the first equation is y(x)=C, while the second yields y(x)=C+∫dx(δ(x-a)/g(x)), simplifying to y(x)=C+1/g(a). The distinction arises because the second solution is dependent on the specific form of g(x), unlike the first. Additionally, the constants C and C' in the solutions are not necessarily the same, leading to the conclusion that C can equal C'+1/g(a). This highlights the nuanced differences in the solutions of these ODEs at the point x=a.
mhill
Let be the first order ODE's
y'(x)g(x)=0 and y'(x)g(x)=\delta (x-a)
except when x=a the two equations are equal , however the solutions are very different
y(x)=C and y(x)= C+ \int dx \frac{\delta (x-a)}{g(x)}
or using the properties of Dirac delta y(x)=C+\frac{1}{g(a)}
the second equation depends on the form of g(x) whereas the first does not, however except at the point x=a the 2 ODE's are completely equal.
Why are you saying the two solutions are different? You should be writing C for one and, say, C' for the other- the two constants are not necessarily the same. In fact, all you are saying is that C= C'+ 1/g(a). Which is perfectly reasonable since 1/g(a) is itself a constant.
