First order separable Equation ODE
11 replies · 2K views
sanhuy
[tex]\frac{dy}{dx}\:+\:ycosx\:=\:5cosx[/tex]
I get two solutions for y however only one of them is correct according to my online homework
(see attempt at solution)
y(0) = 7 is initial condition
[tex]\int \:\frac{1}{5-y}dy\:=\:\int \:cosxdx\:+\:C[/tex]
[tex]-ln\left|5-7\right|\:=\:sinx\:+C[/tex]
[tex]\left|5-y\right|\:=\:De^{-sinx}\:where\:D\:=\:e^{-C}[/tex]
[tex]\left|5-y\right|\:=\:5-y\:,\:if\:5-y\:>\:0\:and\:\left|5-y\right|\:=\:-\left(5-y\right)\:if\:5-y<0[/tex]
using initial conditions for both equations
[tex]y=5\:-De^{-sinx}\:\:and\:\:y\:=\:5+De^{-sinx}[/tex]
[tex]y=5\:-2e^{-sinx}\:\:and\:\:y\:=\:5+2e^{-sinx}[/tex]
however the first solution is incorrect I don't understand why
Did you mean 5 - y above? If you really meant 5 -7, I wouldn't substitute in the initial condition yet.
I'm not totally clear on what you're doing above. Since y(0) = 7, you can assume that y -7 < 0 for solutions near the initial condition.
[tex]y=5\:-De^{-sinx}\:\:and\:\:y\:=\:5+De^{-sinx}[/tex][/B]
Why don't you apply the initial condition on ##\left|5-y\right|\:=\:De^{-sinx}\,##? That gives ##\left|5-y\right|\:=\:2e^{-sinx} > 0##. Now check your signs again.
Since 2e^−sinx>0 you can drop the absolute sign correct?
then it becomes
y=5−2e^−sinx?
then it becomes
y=5−2e^−sinx?
No you can't, because inside the absolute sign can still happen both possibilities. Just consider the cases ##y(x) > 5## and ##y(x) \leq 5##.
Edit: Sorry, I think I made a sign error myself.
if y(x) > 5 then |y-5| = (y-5)
and if y(x) <= 5 we get |y-5| = -(y-5) ?
then we get two solutions that i posted above again? Am i missing something here
fresh_42 said:
Now, that I've seen my sign error, I did what you should do as well with all of these kind of equations: check them by differentiation. (I think you were right in the first place.)
both solutions work, but my webwork says the first one is wrong
haruspex said:
They satisfy the differential equation, but I do not see how your negative multiplier solution satisfies the initial condition.
I just noticed this as well. BTW I was just wondering the way I got rid of my absolute values was correct right, regardless of the general problem i stated?
I was not quite sure what you did. I would substitute x=0, y=7 with still |y-5| to find D=2. Then you get y=5+/-2e-sin(x), then reuse the initial condition to rule out the -2 case.
