Fix Python Print Problem: Get Student Grade Averages
  • Topic: Python
  • Thread starter Thread starter acurate
    Python
acurate
I made a program that would some up a grade average. Everything seems fine, the only problem, when I run the program at the end it prints out like this:
Code:
Jack
Stacy
Jack
Stacy
Jack
Stacy
How can I make the program print out, for example:
Name Grade Average
Name Grade Average
separately for every student's name used?
Code:
grades = []
names = []
ch = 1
while (ch!=0):
    name = input('Enter a name: ')
    if (name.isalpha()):
        grade = int(input('Enter a grade: '))
        if(grade <= 10 and grade > 0):
            names.append(name)
            grades.append(grade)
        else:
            while (grade <= 0) or (grade > 10):
                print ('The grade you entered is not correct, try again!')
                grade = int (input('Enter a grade: '))
            names.append(name)
    elif(name == '0'):
        print ('A zero was entered, end of program.')
        ch = 0
    else:
        print ('The name was entered wrong, try again!')
#problem probably starts from here
howmuch = len(grades)
result = []
for k in range(0, howmuch):
    nreal = names[k]
    for i in range(0, howmuch):
        if (nreal == names[i]):
            result.append(grades[i])
    greal = len(result)
    sumup = 0
    print (nreal)
    how much = len(names)
    for z in range(0,greal):
        a = result[z]
        b= int(a)
        print (b)
        sumup = sumup + b
    avg = sumup /(z+1)
    print (avg)
    result = []
Try replacing your prints with string appends and the last print statement to print the appended string:
pstring = ""+real
pstring = pstring+" "+b
print pstring
By default python outputs a space and newline when you use print
so if you did:
Python:
print "Hello"
print "bob"
you'll get:
Hello
bob
adding a , after the print will suppress the newline eg:
Python:
print "Hello",
print "bob"
results in:
Hello bob
or you can use jedishrfu's solution as well :)
