Does the Fizz Keeper Device Really Keep Carbonated Drinks from Going Flat?
  • Thread starter Thread starter ContangoJoe
    Partial
The Fizz Keeper device, designed to maintain carbonation in opened beverage bottles, has been deemed ineffective based on Dalton's law and Henry's law. Henry's law indicates that the concentration of dissolved gas is proportional to its partial pressure, and the introduction of air into the bottle does not significantly increase the partial pressure of carbon dioxide. Consequently, when resealing a bottle, the carbon dioxide will still escape to reach equilibrium, resulting in a negligible effect on carbonation retention.
  • Understanding of Henry's law and its implications on gas solubility
  • Familiarity with Dalton's law regarding partial pressures
  • Basic knowledge of gas behavior in liquids
  • Concept of equilibrium in chemical systems
  • Research the principles of gas solubility and how they apply to carbonated beverages
  • Explore the effects of pressure changes on gas dissolution in liquids
  • Investigate alternative methods for preserving carbonation in opened beverages
  • Learn about the ideal gas law and its applications in real-world scenarios
Scientists, beverage industry professionals, and anyone interested in the chemistry of carbonation and gas behavior in liquids.
ContangoJoe
There is a device called a Fizz Keeper that attaches to carbonated beverage bottles and is supposed to keep them from going flat after they are opened by pressurizing them with air. Dalton's law and Henry's law have been used to debunk the device as ineffective.
The argument against the device's effectiveness goes something like this:
Henry's law states that the concentration of a gas dissolved in a liquid is proportional to the gas's partial pressure. Since the concentration of carbon dioxide in the atmosphere is low, the partial pressure of carbon dioxide contributed by the pressurized air is insignificant. Therefore, about the same amount of carbon dioxide must still come out of solution to reach an equilibrium partial pressure in a resealed bottle.
But there's something I don't understand.
According to Wikipedia, the carbon dioxide in the headspace of an unopened soft drink bottle exerts a pressure of about 2 atmospheres. When the bottle is opened, that carbon dioxide escapes and is replaced with air. If the bottle is closed again, carbon dioxide will come out of solution until its partial pressure again reaches 2 atmospheres (actually a bit less because the concentration of carbon dioxide in solution has decreased some, but let's call it 2 atmospheres for simplicity). But now we also have air in the headspace at 1 atmosphere, so why wouldn't the total pressure be 3 atmospheres (the sum of the partial pressures per Dalton's law) at equilibrium?
The total pressure doesn't really go up 50% after a bottle opened and resealed, does it? Can anyone alleviate my confusion?
Chemistry news on Phys.org
Right, but that is mainly an effect of your approximation - the partial pressure of CO2 in the liquid will drop significantly the first time you open the bottle.
Another effect: depending on the way the bottle is filled, it might have O2 and N2 partial pressures below the atmospheric pressure, so some gas can get dissolved there.
Thanks for your answer. I guess I'm thinking about this correctly then.
I have another question that's a little deeper I think.
It's always seemed strange to me that molecules in a situation like this apparently make a distinction between themselves and molecules of a different compound. It seems to me that molecules would bump into molecules of another kind in basically the same way they would bump into molecules of their same kind.
How is it that the carbon dioxide molecules in this situation can just ignore the pressure of the atmospheric molecules in the headspace?
They do, but if there is no CO2 in the gas, no CO2 molecules can dissolve. To reach equilibrium, both fluxes have to be the same, and that needs a certain density of CO2 in the gas. More other atoms just make the motion more jagged (shorter mean free path), but the collision rate of CO2 molecules with the water surface stays the same.
At the pressures you are considering, the mixture of CO2 and air is still essentially in the ideal gas region where the various species act essentially independently.
Chet
15K
  • · Replies 24 ·
12K
