Fleming left hand rule or right hand grip rule?
  • Thread starter Thread starter Help help
    hand
The discussion centers on the application of the right hand grip rule for determining the direction of magnetic field lines around current-carrying wires. Participants confirm that gripping the wire with the right hand, thumb pointing in the direction of current flow, results in fingers curling from point P to point Q. This method is essential for visualizing magnetic field orientation, particularly when analyzing scenarios involving wires and magnetic fields. The consensus is that the right hand grip rule is the definitive approach for such calculations.
  • Understanding of electromagnetic principles
  • Familiarity with the right hand grip rule
  • Basic knowledge of magnetic fields
  • Ability to visualize three-dimensional orientations
  • Study the applications of the right hand grip rule in various electromagnetic scenarios
  • Explore the relationship between current direction and magnetic field strength
  • Learn about the left hand rule for motors and its differences from the right hand grip rule
  • Investigate the effects of wire configurations on magnetic field patterns
Students of physics, educators teaching electromagnetism, and anyone seeking to understand the principles of magnetic fields around current-carrying conductors.
Help help
Answer is C? But why?
For current carrying wires, always use the right hand grip rule to determine the direction of the magnetic field lines.
Thanks.
I don't get why the answer is C. :(
Help help said:
Thanks.
If you grip the wire with your right hand with your thumb pointing in the current's direction, your fingers will curl from P to Q. (Imagine a coil around the wire with the arrows pointing in the same direction as your fingers)
M is right below the wire. The direction of your fingers right below you thumb will then point toward P. You can imagine your right hand moving vertically downwards in the grip position until your fingers touch the cardboard (like bringing a fist down on the cardboard, only with your thumb pointing out). At the point of contact of your fingers with the cardboard, your fingers will point towards P.
Thanks. ;)
Thanks for ur great help! ;)
  • · Replies 18 ·
12K
