Can a Floating Tensegrity Sphere Support a Mini-City in the Sky?
  • Context: Graduate
  • Thread starter Thread starter Cannon
    Floating Sphere
The discussion centers on the feasibility of constructing a floating city within a large geodesic sphere, as proposed by Buckminster Fuller. It highlights that as the sphere's size increases, the volume of air it encloses grows significantly, allowing for potential buoyancy if the air temperature is raised. The conversation also addresses the challenges of pressure differences and structural integrity, concluding that while theoretically possible, practical limitations such as material thickness and safety concerns with gases like hydrogen complicate the concept. Ultimately, the idea of a floating city remains largely impractical due to these engineering challenges.
  • Understanding of geodesic structures and their properties
  • Basic principles of buoyancy and gas laws
  • Knowledge of material science regarding structural integrity
  • Familiarity with thermodynamics, particularly in relation to temperature and pressure
  • Research the engineering principles behind geodesic dome construction
  • Explore the thermodynamic properties of gases, focusing on helium and hydrogen
  • Investigate materials suitable for high-stress applications in large structures
  • Examine historical attempts and theoretical models of floating cities
Engineers, architects, urban planners, and anyone interested in innovative architectural concepts and the challenges of constructing airborne habitats.
Cannon
I came across this online the other day:
As a sphere gets bigger, the volume it encloses grows much faster than the mass of the enclosing structure itself. Fuller suggested that the mass of a mile-wide geodesic sphere would be negligible compared to the mass of the air trapped within it. He suggested that if the air inside such a sphere were heated even by one degree higher than the ambient temperature of its surroundings, the sphere could become airborne. He calculated that such a balloon could lift a considerable mass, and hence that 'mini-cities' or airborne towns of thousands of people could be built in this way. These 'cloud nines' could be tethered, or free-floating, or perhaps maneuverable so that they could 'migrate' in response to climatic and environmental conditions.
I came up with a formula for calculating the mass supported by such a sphere of air (as a function of temperature, height and radius), and just wanted to see if my math checks out.
http://designbyninjas.com/calculation.jpg
Also, since the air pressure is the same inside as out, would there be any feasible way to pressurize such a system?
Science news on Phys.org
Do you by chance recall the link to that?
Indeed, a large enough sphere could be used to build a floating city. Also, as a sphere gets bigger the mathematics of heating it up works out to be more and more economical. However, there is the issue of pressure difference. A sphere built to contain even a small pressure difference might need walls so thick it could end up defeating the purpose.
But you don't really need pressure difference or even temperature difference. Just replace the nitrogen in the air inside the sphere with helium. Helium too expensive? Then replace it with hydrogen; but include safety measures so as to avoid super-Hindenburg scenarios.
Not to burst anyone's bubble(pun intended) would anyone really want to live in a floating city that would be an ultimate, and easy, target for terrorists?
Yes!
Alternatively, it could be turned into a miniature Death Star. If fitted with electronic countermeasures and lots of missiles, it could be used to invade enemy territories...
The stress on the shell, due to buoyancy, is quadratic in radius. The cross-section area of the shell, however, given constant thickness, increases linearly. That means, at some point, you'll have to start increasing thickness of the shell linearly with the size. If you start scaling thickness linearly with the size, the mass of the shell goes up as a cube of the size, same as the mass of enclosed air.
In other words, no, it won't work.
Love this discussion, I summarized it on my blog, http://lawoftheair.com. While you mention the density and defense issues, you leave out low oxygen and the COLD.
