Flywheel angular acceleration: finding tangential, radial, and resultant acceleration
  • Thread starter Thread starter bigtymer8700
    Angular
13 replies · 3K views · last reply
bigtymer8700
A flywheel with a radius of 0.300 starts from rest and accelerates with a constant angular acceleration of 0.600/s^2. i know how to solve for the atan but not for arad which is arad=w^2/r it ask Compute the magnitude of the tangential acceleration, the radial acceleration, and the resultant acceleration of a point on its rim at the start.
i know its 2pi=6.28rad all the way around and its acc. at .600rad/s^2 but i don't know where to go from there
Your problem is not clearly formulated. Write clearly what is to be found out. Show your attempt.
it says at the start so would thetaf and thetai be both 0?
That means final theta = 2*pi.
w^2 = 0^2 + 2*a*(2pi). So, you know final w(omega).
Now find the linear speed, at the circumference.
so that means w^2=0^2 +2(.600)(6.283) it comes out to be w=2.86 but it says its wrong
As I said previously, your problem was not clearly formulated. How much time or what is the total angle?
well if you use the w^2=Wo+2a(O-0o) its asking for the speed of the tip of the flywheel from the start so wouldn't the theta be 2xpi or just pi?
i agree with shooting star.. how long was it spun or what was its angular displacement?
and are u solving for the angular velocity or angular acceleration
By the way.. can u please explain what the units of atan and arad should be? it matters...
are atan and a rad angular acceleration or linear?
thats really where I am stuck on i solved the other parts of the problem asking for the atan arad at 60degrees and 120degrees but what value would i use for the start theta? 360 or 180, 0?
well it starts at 0... (rest), also answer my previous post.. because that's essential... and while you are at it.. write down the problem exactly verbatim. and your attempt :D
Hey bigtymer8700, you didn't put the D in the right place in your first post! Glad that you've understood.
