Focal Length & Position of an object.
The discussion focuses on calculating the focal length and position of a lens required to create a half-size image of a 2.0-cm-diameter spider located 3.0 m from a wall. Using the thin-lens equation, the focal length was determined to be 0.261 cm. The position of the lens, measured from the wall, was calculated to be 0.1305 cm. Key corrections were made regarding the use of object distance and image size in the calculations.
  • Understanding of the thin-lens equation (1/f = 1/s + 1/s')
  • Knowledge of magnification equations in optics
  • Familiarity with the concept of object distance (s) and image distance (s')
  • Basic principles of lens optics and image formation
  • Study the derivation and application of the thin-lens equation
  • Learn about magnification and its relationship to object and image sizes
  • Explore different types of lenses and their properties
  • Investigate practical applications of lens calculations in photography and optics
Students in physics, particularly those studying optics, as well as educators and anyone interested in understanding lens behavior and image formation.
frederickcan
A 2.0-cm-diameter spider is 3.0 m from a wall.
(a) Determine the focal length of a lens that will make a half-size image of the spider on the wall.
(b) Determine the position (measured from the wall) of a lens that will make a half-size image of the spider on the wall.
thin-lens equation
1/f= 1/s + 1/s'
(a) Used s and s' in the thin-lens equation to find the focal length:
1/2.0cm + 1/0.3cm = 3.83
f= 1/3.83 = .261cm
(b) .261/2 = .1305
For part (a) (Worry about part (b) later)
An additional equation you need is the magnification. It will allow you to use the fact that the image is half the size of the object. What is that equation? Also, you use 2.0 cm for s. You can't do this. Quantity s is the the distance of the spider from the lens. Quantity 2.0 cm is the size of the spider's of the image on the wall.
Also, what is the 0.3 cm in your attempt represent? If it is a mistakenly substituted 3.0 m, then it should not be there. The 3.0 m given in the problem is the distance from the object to its image, i.e. s + s'.
Can you put it together?
