For this Partial Derivative -- Why are different results obtained?
26 replies · 6K views · last reply
Silvia2023
dF(x,y)/d(1/x)
dF(x,y)/d(1/x)
Given a function F(x,y)=A*x*x*y, calculate dF(x,y)/d(1/x), to calculate this derivative I make a change of variable, let u=1/x, then the function becomes F(u,y)=A*(1/u*u)*y, calculating the derivative with respect to u, we have dF/du=-2*A*y*(1/(u*u *u)) replacing we have dF/d(1/x)=-2*A*x*x*x*y
On the other hand, if we create the same original function, but as a function of (1/x), F(x,y)=A*(1/x)*(1/x)*x*x*(x*x) *y we derive with respect to (1/x) we have dF/d(1/x)= A *x*x*x*y Why are different results obtained?. Maybe I am wrong in something simple, but fundamental. Could you help me?
Best regards
Silvia
Silvia2023 said:
Homework Statement: dF(x,y)/d(1/x)
Relevant Equations: dF(x,y)/d(1/x)
Best regards
Silvia
Think about the chain rule. ##\frac{\partial F}{\partial x} = \frac{\partial F}{\partial u} \cdot ?##
Thanks for your answer; I'm thinking about the chain rule, but that doesn't answer my question about why the difference between these 2 ways, one with a change of variable and the other replacing the variable with respect to which I want to derive the function in the original function
I cannot figure out what you are trying to do in the second part.
The function definition says to form the product of A, the square of the first argument, and the second argument. So wouldn't F(u, y) be ##Au^2y##?
In any case, what you want is this:
$$\frac{\partial F(x, y)}{\partial (1/x)}$$
Per the chain rule
$$\frac{\partial F(x, y)}{\partial (1/x)} = \frac{\partial F(x, y)}{\partial x} \cdot \frac{dx}{d(1/x)}$$
The 2nd fraction on the right side is the reciprocal of ##\frac d {dx}\left(1/x\right)##.
Using this logic I get exactly what you got.
I can't make sense of this, either.
Mark44 said:
So wouldn't F(u, y) be Au2y?
No, the OP was correct. F(u,y)=Ay/u2
I don't see why -- The function is given as ##F(x, y) = Ax^2y##, so ##F(3, y) = A(3)^2y## and ##F(u, y) = Au^2y##. You can't just willy-nilly change the role of the function parameters.
You are overthinking it. The OP defined u=1/x.
So ##F(u, y) = Au^2y = A(1/x)^2y = F(1/x, y)##
Am I missing something?
The OP is doing a change of variables, not a substitution.
No, that's not correct. If you insist on writing ##F((1/x), y)## instead of doing the much more convenient change of variable you did already, then you will have
F((1/x), y) = A \frac{1}{(1/x)} \frac{1}{(1/x)} y
Applying the chain rule to this will work the same as the change of variable version you already did.
In the second part I am building the same original function, but with (1/x), if you look closely it is the same function as the original, the 2 elements of (1/x) are canceled with x*x and the original function remains, this is F(x,y)= A*((1/x)*(1/x)*x*x)*x*x*y , and then I differentiate with respect to (1/x)...............dF(x,y)d(1/x)=A*x*x*x*y
It is not obvious how you got that answer. See post 11 for the proper way to go along that path.
If you are going to treat this as a function of ##(1 / x)## and differentiate it, then you need to write it as:
F((1/x), y) = A (1 / x) (1 / x) \frac{1}{(1 / x)} \frac{1}{(1 / x)} \frac{1}{(1 / x)} \frac{1}{(1 / x)} y
(And of course the obvious thing to do here before differentiating would be to cancel out factors of ##(1 / x)## to get the simpler expression I gave in post #11.)
In other words, you cannot treat ##x## as a variable independent of ##(1 / x)##. To do things properly you have to either write ##F## entirely in terms of ##x##, or entirely in terms of ##(1 / x)##. You can't mix the two and pretend that ##F## is a function of ##x## and ##(1 / x)## separately.
In other words, I give another example:
F(x,y)=B*x*x*y*y*y=B*(x*y)*(x*y)*y
dF(x,y)/d(xy)= B*x*y*y I handle the product of x by y as a single variable, it is the same as I want to do in the previous case, but with the factor (1/ x)
Ok, I understand what you mean, thanks
Post 11:
This may seem obvious to you, but you lost me here. Since ##F(x, y) = Ax^2y## why wouldn't ##F(1/x, y)## be ##A(1/x)^2y## or ##A\frac y {x^2}##?
As I wrote before, with the substitution u = 1/x, ##F(u, y) = Au^2y = A(1/x)^2y## which equals ##A\frac y {x^2}## if we undo the substitution.
Again, is there something I'm missing here?
Same questions with regard to post 15:
PeterDonis said:
$$F((1/x), y) = A (1 / x) (1 / x) \frac{1}{(1 / x)} \frac{1}{(1 / x)} \frac{1}{(1 / x)} \frac{1}{(1 / x)} y$$
You're right. The others are using physicists' math and abusing notation.
  • Love
It's a simple change of variable, but using the notation ##(1 / x)## for the new variable instead of ##u## to make clear the functional relationship to the old variable.
Now you're the one that's lost me. Undoing the change of variable should recover the original form of the function. If ##F(x, y) = A x^2 y##, and ##u = 1/x##, then ##F(u, y) = A (1 / u^2) y##, not ##A u^2 y##. Then undoing the variable change means setting ##x = 1 / u## and going back from ##F(u, y) = A (1 / u^2) y## to ##F(x, y) = A x^2 y##.
Because, as I put it in post #15, ##(1 / x)## is not independent of ##x##, so you can't just plug ##(1 / x)## into the formula for ##F(x, y)## as if it were a separate, independent variable.
Per the chain rule
Note that here you are, correctly, treating ##(1 / x)## as a function of ##x##, not an independent variable.
Randomly bumped into this thread, but I think what Mark is trying to point out is basically, that if you have a function ##f(x)##, and you want to perform a substitution ##x = \tfrac{1}{u}##, what you get is not a function ##f(u)##, but rather a function ##g(u) = f(\tfrac{1}{u})##. Meaning that with ##f## we define a certain functional relation, which changes after substitution, and so if we just write ##f(u)##, we don't account for this change(or we do maybe, but we abuse the notation and so we gotta be aware of what we're doing).
This is effectively the same thing that's pointed out later in Peter's post, where he comments on ##x## and ##\tfrac{1}{x}## being dependent.
So in your scenario: ##F(x,y) = Ax^2y##, you perform the substitution, and you find ##F(\tfrac{1}{u},y) = A\tfrac{1}{u^2}y##, you have to substitute both inside ##F## and outside, not just on one side, because that's incorrect. If you write it this way, you see that you can't evade using chain rule, which you evaded in your first post and that was the mistake.
Hello, I need solve this Functional equation, thanks
Silvia2023 said:
Hello, I need solve this Functional equation, thanks View attachment 356141
@Silvia2023 -- Please post this new problem in a new thread here in the schoolwork forums, and show your work so that we can offer you help. You must show your work in order to get help here.
I will also send you some tips for how to post math equations at PF using LaTeX. This thread will remain closed.
