Force around a horizontal circle
A car traveling around a horizontal curve at a constant speed of 13.3 m/s experiences a total force of 127 N due to friction. The discussion clarifies that while acceleration is zero for constant speed, centripetal acceleration is present because the direction of the velocity is changing. The relevant equation for centripetal force is ∑F = m * v^2 / r, where the force is proportional to the square of the velocity. By using ratios, it is determined that if the car's speed increases to 16.8 m/s, the total force would increase to approximately 160.4 N. Understanding the relationship between speed and centripetal force is crucial for solving such problems.
bearhug
A curve in a road forms part of a horizontal circle. As a car goes around it at constant speed 13.3 m/s, the total force on the car (due to friction with the road) has magnitude 127 N. If the driver would have been driving 16.8 m/s, what would the force have been instead?
∑F= mac = m* v^2/r This is the original equation I thought of using until I realized that I don't have r or m. When the problem mentions the total force as being 127N I assumed that was ∑F. Acceleration would be zero since speed is constant but that's not necessarily the same thing centripetal acceleration is it?
That's the right equation. Since r & m don't change, perhaps you don't need to know them. :wink: (Think ratios.)
Correct.
Acceleration means a change in velocity, which can be a change in speed or direction. (Velocity is a vector.) When something moves in a circle at constant speed it is most definitely accelerating! It's direction is continually changing: it is being centripetally accelerated. ("Centripetal" just means towards the center--in order for something to go in a circle a force must pull it towards the center. In this problem, friction provides the centripetal force.)
127N/13.3m/s = x/ 16.8m/s? x= 160.4 N
Careful: The force is proportional to the velocity squared.
Thanks for pointing that out. I appreciate it.
