Force - boxes connected by strings
  • Thread starter Thread starter firework218
    Force Strings
3 replies · 5K views
firework218
Three boxes are connected by strings of constant length. (A--B--C--> F) An applied force F acts horizontal in the positive x direction. mc=5kg, mb=2mc, ma=2mb. The coefficients of static and kinetic friction are 0.2 and 0.1 respectively and are the same for each box. The boxes are initially at rest.
1) What is the magnitude of the maximum force that can be applied without causing the boxes to move?
2) The magnitude of the applied force is varied until the boxes are moving to the right at a constant speed of 2m/s. What is the magnitude of the force when the boxes are moving at this constant speed?
3) The magnitude of the applied force is varied until the boxes are moving to the right at a constant speed of 2m/s. What is the magnitude of the tension in the string connecting A and B?
4) The applied force is adjusted so that the boxes accelerate to the right at a rate of 2m/s^2. What is the magnitude of the applied force?
F=ma
mc=5kg
mb=10kg
ma=20kg
mtotal=35kg
us=.2
uk=.1
1) 20*9.8 + 10*9.8 + 5*9.8 = 343
343*.2 = 68.6N
2) and 3) I'm not really understanding. I know F=ma, but a isn't given; v=2m/s. And I don't even know where to begin with tension.
4) F=35*2 = 70N
Thanks for your help in advance.
F=ma
mc=5kg
mb=10kg
ma=20kg
mtotal=35kg
us=.2
uk=.1
343*.2 = 68.6N
What is the value of a when the blocks are moving at a constant speed?
Draw a Free Body Diagram of Block A, which is moving at constant speed.
4) F=35*2 = 70N
That's the NET force, not the applied force.
Welcome to PF!:smile:
"What is the value of a when the blocks are moving at a constant speed?"
a at constant speed = 0m/s^2?
"Draw a Free Body Diagram of Block A, which is moving at constant speed."
fw=20 down, fn=20 up
v=2m/s right, uk=.1 left
that's about all i got.
"That's the NET force, not the applied force."
Fapp= 35*2 + 0.1*35 = 73.5?
yes, so proceed as you did in part a, except change the friction coefficients.
fw down is 20*9.8 N, fn up is 20*9.8 N. But what are the forces in the x direction? The velocity v = 2 m/s is not a force, and its value is not relevant in this problem. Only the fact that v is constant is relevant (a = 0).
Almost correct, you again forgot to convert the total mass to total weight when calculating the friction force.
