What is the force exerted by a laser pulse on a target?
  • Thread starter Thread starter Kara386
    Force Laser
The discussion focuses on calculating the force exerted by a laser pulse on a target, specifically a pulse with a frequency in the visible spectrum, a duration of 5×10−15 seconds, and approximately 1019 photons. The total energy of the photons is calculated using the equation E = hc/λ, resulting in an energy of 3.6×10−19 J. The momentum change is determined using p = ħk, where k = 2π/λ, and the force is derived by dividing the total momentum by the pulse duration.
  • Understanding of photon energy calculations using E = hc/λ
  • Knowledge of momentum and its relation to force
  • Familiarity with the concept of laser pulses and their properties
  • Basic grasp of quantum mechanics, specifically the relationship between wavelength and momentum
  • Study the derivation of the equation E = hc/λ in detail
  • Learn about the principles of momentum in quantum mechanics
  • Explore the concept of laser pulse duration and its effects on energy transfer
  • Investigate practical applications of laser force calculations in physics and engineering
Students in physics, particularly those studying optics and quantum mechanics, as well as researchers and engineers working with laser technology and energy transfer systems.
Kara386
A target is hit by a laser pulse. The frequency of the pulse is in the visible spectrum, it has duration ##5\times 10^{−15}## s and it contains approximately ##10^{19}## photons. Estimate the force exerted by the pulse on the target, given the pulse is completely absorbed by the target.
I think a reasonable wavelength in the visible spectrum would be ##550##nm. I can calculate the total energy of the photons that hit the target by using ##E = \frac{hc}{\lambda}## and then multiplying by ##10^{19}##. I get ##3.6\times 10^{-19}##J, and don't know where to go from there.
Alternatively I suppose I could use force = change in momentum / change in time. Then I'd use ##p = \hbar k## where ##k = \frac{2\pi}{\lambda}##. If that's the correct approach, to get the total change in momentum I just multiply the momentum expression by ##10^{19}##, right?
Thanks for any help!
That will give you the total momentum. You'll then have to convert it to a force.
By dividing the total momentum by the duration of the pulse?
Yes.
haruspex said:
Yes.
Brilliant, thanks! :)
  • · Replies 23 ·
  • · Replies 19 ·
