Force of Falling Objects at a Height
The discussion revolves around understanding the force exerted by a falling object, specifically a ball dropped from a height into a spring. Participants explore the implications of Newton's 2nd Law, gravitational acceleration, and the dynamics of energy transfer during the impact with the spring.
  • Participants examine the relationship between the height from which the ball is dropped and the force upon impact, questioning whether the force is solely dependent on weight or if it varies with height. They discuss the role of momentum in deformation and the conditions under which the spring force is considered.
There is ongoing exploration of the concepts involved, with various interpretations of the forces at play during the collision with the spring. Some participants have offered insights into the nature of spring forces and energy conservation, while others express confusion over the original poster's calculations and reasoning.
Participants note the complexity of the problem due to the non-constant nature of the spring force and the challenge of applying certain equations under these conditions. There is also mention of the need for additional variables, such as time, in the context of impulse.
Samei
: [/B]I'm curious to know why and how one would account for the force of a falling object dropped from a height. If I apply Newton's 2nd Law, force is only dependent on acceleration. So in a straight vertical drop, this acceleration is only gravity. But is it not that a bowling ball dropped from a skyscraper will have more force crashing down into the ground than the same ball dropped from only half a meter of a height?
Here is my problem: If I drop a ball into a spring from a given distance x, the spring will compress. Assume that the ball sticks to the spring. After impact, the spring will eventually have a restoring force to counteract that force. But how much is that force? It is not equal to the weight of the ball, is it? (In this case, the spring is massless. Only mass of the ball (m), spring constant (k), and distance of the ball from spring (x) is given.)
: [/B]F = m * a, F (spring) = -kx, W = KE2 - KE1, Conservation of Energy, W = Fd
: [/B]W = KE2 - KE1
KE2 = mgx by conservation of energy, x is the height
KE1 = 0, because ball is being dropped
W = KE2 = mgx
and F = W/d
Substituting,
F = (mgx)/d
d = x + n, n is the distance the spring is compressed due to the weight of the ball
I am unsure how to solve for n.
F = (mgx)/(x+n) = -kn
I'm stuck here. It looks like a quadratic, but it looks incorrect.
Once I solve for n, I would have -kn, which is the restoring force.
Can someone help me? Thanks in advance!
Firstly , the reason for any and all deformation after collision is pretty much only dependent on momentum , and not force .
It depends . Which instant are we talking about ? If we speak of the instant at which it just touches the spring , it will be zero .
If we speak of the instant at which net force on the object is zero , yes , it will be equal to mg .
Your solution ... I can't understand what you have done .
Correct.
Doesn't W = mg(x+n) ?
Also doesn't the spring do work on the mass as well?
paisiello2 said:
Correct.
The solution seems wrong .
: [/B]W = KE2 - KE1
W = KE2 = mgx
and F = W/d
Substituting,
F = (mgx)/d
F=W/d only when the force is constant.Is the spring force constant here?
No you are confusing the acceleration and deceleration phase. The "acceleration" that determines the impact force is the deceleration when it hits the ground not the acceleration on the way down (that's constant if you ignore air resistance).
Perhaps continue with the COE theme and google "Energy stored in a spring".
Sorry for the delay, but I'm back!
At the instant it touches the spring, then it will be zero. But what about after it compresses the spring? Since it pushes down the spring, I imagine it would gain more force. I wasn't sure of my equations either, but my main thoughts were of the fact that spring force (-kn) is equal to the force applied to it (the spring).
paisiello2 said:
Correct.
Because it compresses the spring, right? So it is x (height) and n (compressed distance). The spring does work through its restoring normal force.
Not sure about this, but I am going to say it acts like a "standard" spring, so spring constant is constant (k).
I just read a post regarding this, with the author summarizing it as the "fall doesn't kill you, but the deceleration (impact) does". I have since attempted to apply his strategy but found that I could not. I could use Impulse, but I am lacking t (time), and possibly other variables.Thanks to everyone who replied. I am still working on it. Right now, I am looking at using Impulse, although I am thinking Work-Energy Theorem should explain this. Am I overcomplicating this problem?
I really do appreciate the input, especially since my textbook does not explain this. :)
Stage spring constant is definitely constant.But the spring force is proportional to the compression in the spring.This means the force is not constant.Now F=W/d(This is what you've used.)is only valid for a constant force,hence it won't work here.
Oh, ok. That would explain why it did not seem right. So it looks like I'll have to use another set of equations then. I'll post what I'll find, which may take a moment or so. I'm looking at Impulse right now.
Alright. So, impulse was not the solution.
It turns out that I only need to use conservation of energy.
Here is my redo with same variables applied: mgx = Total E = KE1
Again, x is the height, m is the mass of the ball, and k is the spring constant as the given. n will be the compression of the spring.
At the instant it touches the spring, KE1 = mgn + 0.5kn^2 + KE2
KE2 = 0, since the ball stops at max compression.
KE1 = mgn + 0.5kn^2
It is a quadratic again. But solvable for n with given information.
Once I obtain this n, I simply plug it into -kn and I will have my restoring force.
I realize that there might be collision (inelastic/elastic) elements here. I just made up this problem to understand some topics so it is a bit flawed. Is the solution right, at least conceptually? I may ask another similar problem again if it helps.
KE1 = mgn + 0.5kn^2
Yes it is correct.
Ellispson said:
Yes it is correct.
Thank you!
  • · Replies 17 ·
  • · Replies 22 ·
