Force on 10 Kg Block on 51° Inclined Plane
The discussion centers around calculating the force required to prevent a 10 Kg block from slipping on a 51-degree inclined plane, as well as the work done when an object is dragged up a ramp under a constant force. The scope includes theoretical and mathematical reasoning related to forces on inclined planes.
  • Exploratory, Technical explanation, Homework-related, Mathematical reasoning
  • One participant asks for help with the problem, indicating they have not made progress due to uncertainty about how to start.
  • Another participant suggests using a free body diagram to analyze the forces acting on the block and relates the weight vector to the components along the incline.
  • A participant proposes renaming force components for clarity, suggesting that the weight vector can be decomposed into components that balance the normal force and the force preventing slipping.
  • There is a mention of a second question regarding the work done when an object is dragged up a ramp, but no specific calculations or methods have been discussed for this part.
Participants express uncertainty about how to approach the problems, and there is no consensus on the methods to be used for solving them. Multiple viewpoints on the force analysis are presented without resolution.
Participants have not provided specific assumptions or mathematical steps, and the discussion lacks a clear progression towards a solution for either part of the problem.
This discussion may be useful for students or individuals interested in understanding forces on inclined planes and the application of free body diagrams in physics problems.
JessiMen
A 10 Kg block lies on a smooth plane inclined at 51 degrees. What force parallel to the incline would prevent the block from slipping?
Mathematics news on Phys.org
Can you post your progress so far, so our helpers can see how best to help?
oh I skipped this question in my review because i didnt know how to do it there is also a question b to it:
b) An object is dragged 6 m up a ramp under a constant force of 27 N applied at an angle of 32 degrees to the ramp. Calculate the work done
...And what have you been able to do so far?
-Dan
for this question nothing because i have no idea how to start it.
Okay, let's begin with a great tool used in physics called the free body diagram:
Okay, we wish to find the magnitude of the force $F$, which is equal in magnitude to $F_x$. We know the magnitude of $w$ (the weight vector) and we know $\theta$ where $\theta+\beta=\dfrac{\pi}{2}$...so can you use some trigonometry to relate $w$, $F_x$ and $\theta$?
It seems to me that the figure would be clearer if $F_x$ and $F_y$ are renamed into $w_x$ and $w_y$ (and $w_x$ changes the direction). As I understand, $\vec{w}=\vec{w}_x+\vec{w}_y$. The component $\vec{w}_y$ of $\vec{w}$ is counterbalanced by the normal force $\vec{n}$ and $\vec{w}_x$ is counterbalanced by $\vec{F}$. But $\vec{F}$ does not have a $y$ component.
  • · Replies 27 ·
11K
