Force on a diving bell port at 147m depth
  • Thread starter Thread starter BuBbLeS01
    Pressure
12 replies · 5K views
BuBbLeS01
A spherical diving bell containing a camera is in the ocean at a depth of 147 m. It has a flat, transparent, circular port with a diameter of 12.7 cm. Find the total force on the port (use ρsea water = 1025 kg/m3).
p = po + pgd
P = F/A
F = pA
So do I find the total pressure and then multiply it be the area? I get a really big number (2.00 x 10 ^ 8) which doesn't seem right?
No I don't think so cause it is worded differently and in our class they are all worded the same just different numbers...but that's weird its almost identical!
Sorry - I thought your comment meant you had solved it!
The area of the window is A = pi r^2
There is a column of water on top of it 147m high
So the volume of water sitting on the window is V = pi r^2 * depth
Add the density of water and you get the mass of water on the window.
V = pi * (0.127/2)^2 * 147 = 1.89m^3
Density is 1025 kg/m^3 so mass of water is 1900kg
Total force is F = mass * g = 18.7KN
Note there is also an extra 1 atmosphere of pressure pushing down on the surface of the water, but there is also an atmosphere of pressure inside the bell pushing out which cancel out.
this is the msg it gave me...
Calculate the total pressure at the given depth by adding up the atmospheric pressure (1.01e5 N/m2) plus the pressure due to the sea water. This assumes that there is no air in the bell, (probably a bad assumption).
Alternate method - the weight of the column of water = m g h = 1.47MN
Area A= pi r^2 = 0.0127m^2
Force = pressure * area = 1.47MN/m^2 * 0.0127m^2 = 18.67N
EDIT - then just add atmospheric pressure to the water pressure, answer should be 20KN.
I'm having deja vu and amnesia at the same time...I think I've forgotten this once before.
I don't understand I enter 0.02 N (it doesn't recognize units like KN or MN) and it says incorrect??
