What is the relationship between force and potential in particle interactions?
The relationship between force and potential in particle interactions is defined by the interaction potential, V(𝑥₁−𝑥₂), between two repelling particles, referred to as particles 1 and 2. The force vectors are calculated using the gradient of the potential, where F₁₂ = -∇₁V(𝑥₁−𝑥₂) and F₂₁ = -∇₂V(𝑥₁−𝑥₂) = -F₁₂, confirming Newton's Third Law. The x, y, and z components of the force vectors are derived from the negative gradient of the potential with respect to each coordinate. This discussion clarifies the distinction between scalar potentials and vector forces.
  • Understanding of interaction potentials in physics
  • Knowledge of vector calculus, specifically gradients
  • Familiarity with Newton's Laws of motion
  • Basic concepts of particle dynamics
  • Study the mathematical formulation of gradients in vector calculus
  • Explore the implications of Newton's Third Law in multi-particle systems
  • Learn about different types of potentials, including scalar and vector potentials
  • Investigate applications of interaction potentials in molecular dynamics simulations
Physicists, students of classical mechanics, and researchers in fields involving particle interactions and dynamics will benefit from this discussion.
Tim667
TL;DR
Slight confusion about vectors from a potential
Suppose I have some interaction potential, u(r), between two repelling particles. We will name them particles 1 and 2.
I want to find the force vectors F_12 and F_21. Would I be correct in saying that the x-component of F_12 would be given by -du/dx, y-component -du/dy etc? And to find the components for the other force vector, would this simply be the negative of the first vector?
So F_12 would be given by (-du/dx, -du/dy, -du/dz) and F_21= (du/dx, du/dy, du/dz)?
Thank you
Tim667 said:
Summary: Slight confusion about vectors from a potential
Suppose I have some potential, u(r), between two repelling particles. We will name them particles 1 and 2.
Thank you
You need to be careful. Normally with a potential you have a particle moving under the influence of an external force. In this case technically you have a different potential for each particle.
I see, I should specify that this is an interaction potential between the two particles
Okay. Of course. As long as you define ##r## the right way round, what you have looks right. I must be getting tired.
That's okay. I think I was confused because potentials are usually scalar functions, and I wasn't sure you could get vectors from them
Yes, the gradient takes a scalar function of position and generates a vector function of position.
An interactian potential usually takes the form ##V(\vec{x}_1-\vec{x}_2)##. The force on particle 1 is
$$\vec{F}_{12}=-\vec{\nabla}_1 V(\vec{x}_1-\vec{x}_2)$$
and on particle 2
$$\vec{F}_{21}=-\vec{\nabla}_2 V(\vec{x}_1-\vec{x}_2)=-\vec{F}_{12}.$$
Newton's 3rd Law holds, because the potential only depends on the relative vector ##\vec{r}=\vec{x}_1-\vec{x}_2##.
  • · Replies 28 ·
11K
