Efficiency of Energy Transfer in Swimming: Wall Kicking vs. Water Kicking
  • Thread starter Thread starter dibilo
The discussion centers on the efficiency of energy transfer in swimming when comparing wall kicking to water kicking. The consensus is that pushing off the wall results in a more efficient energy transfer due to the solid support it provides, leading to a faster initial speed through the water. In contrast, kicking in water involves drag resistance, which diminishes efficiency as the energy is partially converted into turbulence. Proper technique is crucial for maximizing energy transfer in both scenarios.
  • Understanding of kinetic energy (KE) and potential energy (CPE)
  • Knowledge of elastic and inelastic collisions
  • Familiarity with drag resistance in fluid dynamics
  • Basic swimming techniques and body positioning
  • Research the principles of kinetic and potential energy in swimming
  • Learn about elastic vs. inelastic collisions in sports physics
  • Study drag resistance and its effects on swimming performance
  • Explore advanced swimming techniques for efficient wall pushes
Swimmers, coaches, sports scientists, and anyone interested in optimizing swimming techniques and understanding the physics of energy transfer in aquatic environments.
dibilo
When a swimmer kicks the wall at the end of a swimming pool, he tends to travel further than those who does not kick the wall but applied the same amount of force kicking in water. Why?
Sorry really have no idea
This isn't a homework but a discussion between my buddy and me. My hypothesis is that when I kicked against the wall, there is more efficiency in energy transfer, CPE --> KE than when I kick in water.
His idea is that when kicking the wall, it is a more inelastic collision and when kicking in water, it is a more elastic one.
May I know whose idea is correct or are we both correct or are we both wrong?
Thanks a lot!
Neither, though arguably your view is closer.
Think about where the energy goes in the two cases.
When you push off the wall (not kick off the wall) and streamline correctly, you are moving faster through the water than you can swim, at least for a few meters. That is why you stay in the streamlined position for a few moments until your speed comes down to where it is equal to what you can maintain with your strokes.
https://blog.myswimpro.com/2022/11/22/how-to-push-off-the-wall-in-swimming-5-mistakes-to-avoid/
The wall is a solid support and the leg muscles used are the same that allow us to squat.
The water offers a drag resistance to the movement of the feet and lower legs, which is proportional to the square of the velocity of those respect to the water.
We could say that the mass of water surrounding your feet and legs is a support that moves away as you try to push on it, but that it moves less and supports more the faster you can push it.
Using the proper technique, the feet and legs try to quickly push aft as much mass of water as possible.
In that process, any lateral and forward movements only induce turbulence, which wastes muscular energy.
  • · Replies 16 ·
  • · Replies 25 ·
