Forces on two masses hanging vertically from strings
6 replies · 3K views · last reply
shawli
I just wanted to double check my logic on something! If two masses are held vertically by two strings like so:
[ceiling]
[string #1]
[mass #1]
[string #2]
[mass #2]
...then what forces are acting on mass #1?
My free body diagrams are below, could someone double check if they're correct? (You'll need pretend they are rotated 90degrees clockwise!).
for mass 1:
Tension in string 1 <------ [mass#1]------>Tension in string 2 AND mass1*gravity
for mass 2:
Tension in string 2 <------ [mass#2]------>(mass1+mass2)*gravity
for both masses:
Tension in string 1 <------ [mass#1 and mass#2]------>(mass1+mass2)*gravityDo these make sense?
Feedback is appreciated (:
shawli said:
for mass 1:
Good!
for mass 2:
The weight of mass 1 acts only on mass 1, so it doesn't belong here.
for both masses:
Good!
Ah, thank you!
So, just conceptually, the weight of mass 1 acts transmits as a force to mass 2 only through the the string between them? And this ends up translating into the "force of tension in string 2"? (mass 1 just pulls up on mass 2)
I think you have things a bit backwards.
The weight of mass 1 has no effect (even indirectly) on mass 2. You could take string 2 and attach it directly to the ceiling (without mass 1 or string 1) and the the tension will be the same.
Now the weight of mass 2 is transmitted to mass 1 via the tension in string 2, which in turn adds to the tension in string 1. But yes, the only way that the weight of mass 2 can affect mass 1 is via the string between them.
Thank you Doc Al! I'm glad I asked because I see the flaw in my logic now -- there is no way for mass 1 to act on mass 2.
Thanks again!
By the way, is there any way for me to mark this thread as "solved"?
shawli said:
Thanks again!
You are most welcome.
Unfortunately not. (But anyone reading this will know that it's 'solved'.)
