[FORTRAN] How did I screw up my code?
  • Topic: Fortran
  • Thread starter Thread starter Matterwave
    Code Fortran Screw
54 replies · 7K views
Homework Helper
Hi guys, there's a bug in my code which I've been trying to get rid of for the last 2 weeks. I'm completely out of ideas now on what it is so I have to turn to you guys for help. The code is here:
Fortran:
module helectron
  use params
  use parallel
!*  electron density parameters
  integer :: iprofile
!*  Ref: Full & Qian, astro-ph/0505240, Eqs. (71-74)
  ! solar mass in kg
  real(kind=reel8),parameter :: Msun = 1.98844d+30
  ! proton mass in kg
  real(kind=reel8),parameter :: Mproton = 1.67262171d-27
  ! plank mass in kg
  real(kind=reel8),parameter :: Mplank = 2.17645d-8
  ! mass of the neutron star in kg
  real(kind=reel8),parameter :: Mns = 1.4*Msun
  ! entropy per baryon in k_B
  real(kind=reel8),parameter :: Sb = 1.4d+2
  ! radius of neutrinosphere in cm
  real(kind=reel8),parameter :: Rnu = 1.1d+6
  ! temperature in cm**-1 at neutrinosphere
  real(kind=reel8),parameter :: T0cm = (Mproton*Mns)/(Mplank*Mplank) &
  & /Sb/Rnu
  ! electron fraction, Yevar used for variable electron fraction
  real(kind=reel8),parameter :: Ye = 1.d0
  real(kind=reel8) :: Yevar
  ! electron density at neutrino sphere in cm**-3
  real(kind=reel8) :: ne0 = Ye*(2.d0*pi*pi/45.d0)*T0cm**3/Sb
  ! baryon density at neutrino sphere in cm**-3
  real(kind=reel8) :: nb0 = (2.d0*pi*pi/45.d0)*T0cm**3/Sb
!  grid for electron density, baryon density and electron fraction
  integer :: iegrid
  real(kind=reel8),dimension(1000) :: rgrid,ryegrid,rhoegrid,rhoe2grid
  real(kind=reel8),dimension(1000) :: rhobgrid,rhob2grid,yegrid,ye2grid
!  mixing angles and masses
  real(kind=reel8) :: dm21sq,dm31sq,dm32sq
  real(kind=reel8) :: theta12, theta13, theta23,deltacp
  real(kind=reel8),dimension(nflavor,nflavor) :: hvac,hmix,hmass
  contains
  subroutine hvac_init
  if(nflavor.eq.2) then
  dm20= dm21sq
  cos2v = cos( 2.d0*theta13)
  sin2v = sin( 2.d0*theta13)
  if(myid.eq.0) then
  write(6,'(a20,1pe15.7) ') '2-flavor vacuum matrix'
  write(6,'(a20,1pe15.7) ') 'dm20 = ',dm20
  write(6,'(a20,1pe15.7) ') 'cos2v = ',cos2v
  write(6,'(a20,1pe15.7) ') 'sin2v = ',sin2v
  endif
  elseif(nflavor.eq.3) then
  c13=cos(theta13)
  s13=sin(theta13)
  c12=cos(theta12)
  s12=sin(theta12)
  c23=cos(theta23)
  s23=sin(theta23)
  hmix(1,1)=c12*c13
  hmix(1,2)=s12*c13
  hmix(1,3)=s13
  hmix(2,1)=-s12*c23-c12*s23*s13
  hmix(2,2)=c12*c23-s12*s23*s13
  hmix(2,3)=s23*c13
  hmix(3,1)=s12*s23-c12*c23*s13
  hmix(3,2)=-c12*s23-s12*c23*s13
  hmix(3,3)=c23*c13
  hmass(:,:)=0.d0
  hmass(2,2)=dm21sq
  hmass(3,3)=dm21sq+dm32sq
  hvac(:,:)=0.d0
  do i=1,nflavor
  do j=1,nflavor
  do k=1,nflavor
  do l=1,nflavor
  hvac(i,l)=hvac(i,l)+hmix(i,j)*hmass(j,k)*hmix(l,k)
  enddo
  enddo
  enddo
  enddo
  if(myid.eq.0) then
  write(6,'(a20,1pe15.7) ') '3-flavor vacuum matrix'
  write(6,'(a20,1pe15.7) ') 'dm21sq = ',dm21sq
  write(6,'(a20,1pe15.7) ') 'dm32sq = ',dm32sq
  write(6,'(a20,1pe15.7) ') 'theta12 = ',theta12
  write(6,'(a20,1pe15.7) ') 'theta13 = ',theta13
  write(6,'(a20,1pe15.7) ') 'theta23 = ',theta23
  write(6,'(a20,1pe15.7) ') 'cos(theta12) = ',c12
  write(6,'(a20,1pe15.7) ') 'sin(theta12) = ',s12
  write(6,'(a20,1pe15.7) ') 'cos(theta13) = ',c13
  write(6,'(a20,1pe15.7) ') 'sin(theta13) = ',s13
  write(6,'(a20,1pe15.7) ') 'cos(theta23) = ',c23
  write(6,'(a20,1pe15.7) ') 'sin(theta23) = ',s23
  write(6,'(a20,1pe15.7) ') 'deltacp = ',0.
  write(6,'(a40,1pe15.7) ') '3-flavor mixing matrix '
  write(6,'(1p,3e15.7) ') hmix(1,1),hmix(1,2),hmix(1,3)
  write(6,'(1p,3e15.7) ') hmix(2,1),hmix(2,2),hmix(2,3)
  write(6,'(1p,3e15.7) ') hmix(3,1),hmix(3,2),hmix(3,3)
  endif
!  Do some unitarity checks on mixing matrix
  sumsq1 = sum(hmix(1,1:3)**2)-1.d0
  if(abs(sumsq1).gt.1.d-5) then
  write(6,*) ' Error sumsq1 = ', sumsq1
  stop
  endif
  sumsq2 = sum(hmix(2,1:3)**2)-1.d0
  if(abs(sumsq2).gt.1.d-5) then
  write(6,*) ' Error sumsq2 = ', sumsq2
  stop
  endif
  sumsq3 = sum(hmix(3,1:3)**2)-1.d0
  if(abs(sumsq3).gt.1.d-5) then
  write(6,*) ' Error sumsq3 = ', sumsq3
  stop
  endif
  traceo3=(hvac(1,1)+hvac(2,2)+hvac(3,3))/3.d0
  hvac(1,1)=hvac(1,1)-traceo3
  hvac(2,2)=hvac(2,2)-traceo3
  hvac(3,3)=hvac(3,3)-traceo3
  if(myid.eq.0) then
  write(6,'(a40,1pe15.7) ') '3-flavor vacuum Hamiltonian (traceless)'
  write(6,'(1p3e15.7) ') hvac(1,1),hvac(1,2),hvac(1,3)
  write(6,'(1p3e15.7) ') hvac(2,1),hvac(2,2),hvac(2,3)
  write(6,'(1p3e15.7) ') hvac(3,1),hvac(3,2),hvac(3,3)
  endif
  endif
  return
  end subroutine hvac_init
  subroutine helec_init(iprofile,spinco,filename,helecname)
  character*80 filename
  character*80 helecname
  character*80 rest
  character*1 first
  integer :: spinco
#ifdef mpi
  include 'mpif.h'
#endif
  helecname = ''
!  iprofile=1 or iprofile=2 are simple analytic profiles
  if(iprofile.eq.1) then
  helecname = 'Fuller and Qian 1/r**3'
  elseif(iprofile.eq.2) then
  helecname = 'Fuller and Qian 1/r**3 + exp '
  elseif(iprofile.eq.3) then
  if(spinco.eq.0) then
  if(myid.eq.0) then
  write(6,*) ' Reading electron density from ',filename
  write(6,*) ' Beginning of file '
  icomments=1
  open(unit=20,file=trim(filename))
  do while (icomments.eq.1)
  read(20,'(a1,a80)')first,rest
  if(helecname.eq.'') helecname=rest
  if (first.eq.'#') then
  write(6,'(a1,a80)') first,rest
  else
  icomments=0
  backspace 20
  endif
  enddo
!  read data file
  iend=0
  iegrid=0
  do while (iend.eq.0)
  iegrid=iegrid+1
  read(20,*,iostat=ierr) rgrid(iegrid), rhoegrid(iegrid)
  if(ierr.ne.0) then
  iend=1
  iegrid=iegrid-1
  close(20)
  endif
  enddo
  write(6,*) ' Electron density grid contains ',iegrid,'values'
  write(6,*) ' Beginning of rho_e grid '
  do i=1,min(5,iegrid)
  write(6,'(f15.7,e18.9)') rgrid(i),rhoegrid(i)
  enddo
  write(6,*) ' End of rho_e grid '
  do i=max(1,iegrid-4),iegrid
  enddo
! convert rhoegrid from ln(n_e*km^3) to ln (ne_e*cm^3)
!  conversion factor is 10**(-15)
  write(6,*) ' initial density = ',exp(rhoegrid(1)),' / km**3 '
  rhoegrid(1:iegrid)=rhoegrid(1:iegrid)-log(1.d15)
  write(6,*) ' converting to ln(rho_e*cm**3) = ',exp(rhoegrid(1)),' /cm**3'
!  end of if for myid = 0
  endif
#ifdef mpi
  call mpi_bcast(iegrid,1,mpi_integer,0,mpi_comm_world,ierr)
  call mpi_bcast(rgrid,iegrid,mpi_double_precision,0,mpi_comm_world,ierr)
  call mpi_bcast(rhoegrid,iegrid,mpi_double_precision,0,mpi_comm_world,ierr)
#endif
  if(myid.eq.0) then
  write(6,*) ' setting up spline'
  endif
  call spline(rgrid,rhoegrid,iegrid,1.d31,1.d31,rhoe2grid)
  if(myid.eq.0) then
  write(6,*) ' done setting up spline'
  endif
  elseif(spinco.eq.1.or.spinco.eq.2) then
  if(myid.eq.0) then
  write(6,*) ' Reading baryon density from ',filename
  icomments=1
  else
  icomments=0
  backspace 20
  endif
  enddo
!  read data file
  iend=0
  iegrid=0
  iegrid=iegrid+1
  read(20,*,iostat=ierr) rgrid(iegrid), rhobgrid(iegrid)
  if(ierr.ne.0) then
  iend=1
  iegrid=iegrid-1
  close(20)
  endif
  enddo
  write(6,*) ' Baryon density grid contains ',iegrid,'values'
  write(6,*) ' Beginning of rho_b grid '
  write(6,'(f15.7,e18.9)') rgrid(i),rhobgrid(i)
  enddo
  write(6,*) ' End of rho_b grid '
  enddo
! convert rhobgrid from ln(n_b*km^3) to ln (nb_e*cm^3)
  write(6,*) ' initial density = ',exp(rhobgrid(1)),' / km**3 '
  rhobgrid(1:iegrid)=rhobgrid(1:iegrid)-log(1.d15)
  write(6,*) ' converting to ln(rho_b*cm**3) = ',exp(rhobgrid(1)),' /cm**3'
  endif
#ifdef mpi
#endif
  if(myid.eq.0) then
  endif
  call spline(rgrid,rhobgrid,iegrid,1.d31,1.d31,rhob2grid)
  if(myid.eq.0) then
  endif
! end of if for spinco = 1 or 2
  endif
! end of if for iprofile = 1,2, or 3
  endif
  return
  end subroutine helec_init  subroutine varelec_init(varelecfracf,elecprofilef,filename,efname)
  integer,intent(in) :: varelecfracf,elecprofilef
  character*80 efname
  character*80 rest
  character*1 first  efname = ''
!  varelecfracf = 0 means constant elecfrac, 1 means analytic profile, 2 means read from file
!  elecprofilef = 1 means linear electron fraction
  if(varelecfracf.eq.0) then
  efname = 'Constant electron fraction'
  elseif(varelecfracf.eq.1) then
  efname = 'Analytic profile '
  elseif(varelecfracf.eq.2) then
  if(myid.eq.0) then
  write(6,*) ' Reading electron fraction from ',filename
  icomments=1
  if(efname.eq.'') efname=rest
  else
  icomments=0
  backspace 20
  endif
  enddo
!  read data file
  iend=0
  iegrid=0
  iegrid=iegrid+1
  read(20,*,iostat=ierr) ryegrid(iegrid), yegrid(iegrid)
  if(ierr.ne.0) then
  iend=1
  iegrid=iegrid-1
  close(20)
  endif
  enddo
  write(6,*) ' Electron fraction grid contains ',iegrid,'values'
  write(6,*) ' Beginning of Y_e grid '
  write(6,'(f15.7,e18.9)') ryegrid(i),yegrid(i)
  enddo
  write(6,*) ' End of Y_e grid '
  enddo
  endif!  end of if for varelecfracf=0,1,2
  endif
  return
  end subroutine varelec_init
  subroutine elecfracsplint(ryegrid,yegrid,r,Yevar)
  real(kind=reel8),intent(in) :: r
  real(kind=reel8),intent(out) :: Yevar
  real(kind=reel8),dimension(1000),intent(in) :: ryegrid,yegrid
  integer :: igrid
  igrid=0
  do
  if(r.ge.ryegrid(igrid)) then
  igrid=igrid+1
  if(igrid.ge.999) then
  write(6,*) ' Error: Exceeded electron fraction grid '
  stop
  endif
  else
  exit
  endif
  enddo
  Yevar=(yegrid(igrid)-yegrid(igrid-1))*r/(ryegrid(igrid)-ryegrid(igrid-1))+yegrid(igrid)- &
  &  (ryegrid(igrid)*yegrid(igrid)-ryegrid(igrid)*yegrid(igrid-1))/ &
  &  (ryegrid(igrid)-ryegrid(igrid-1))
  return
  end subroutine  function helec(r,e,iphi,iprofile,spinco,varelecfrac)
  implicit real(kind=reel8) (a-h,o-z)
  real(kind=reel8),dimension(nflavor,nflavor,2) :: helec
  integer :: spinco,varelecfrac,iprofile
  real(kind=reel8) :: he,hence
!  henc is neutral current term that must be added back in if spin coherence is used
  real(kind=reel8),intent(IN) :: r,e
  real(kind=reel8) :: gs  !statistical weight
  real(kind=reel8) :: r3  ! (r/Rnu)**3
!  integer init/0/
!  save init
  helec(:,:,:)=(0.d0,0.d0)
  Yevar=.4
!initialize variable electron fraction
  if(varelecfrac.eq.0) then
  Yevar = .4d0
  elseif(varelecfrac.eq.1) then
  Yevar = elecfrac(r,1)
  elseif(varelecfrac.eq.2) then
  call elecfracsplint(ryegrid,yegrid,r,Yevar)
  endif!*  Ref: Full & Qian, astro-ph/0505240, Eqs. (71-74)
  if(iprofile.eq.1.or.iprofile.eq.2) then
  gs = 5.5d0  !statistical weight
  r3 = (r*1.d5/Rnu)**3
  he = 2.d0*gs*gfermiort2*ne0/r3
  elseif(varelecfrac.eq.1.or.varelecfrac.eq.2) then
  he = 2.d0*gs*gfermiort2*nb0*Yevar/r3
  endif
  henc = gs*gfermiort2*nb0*(1.d0-Yevar)/r3
  endif
  endif
!  for iprofile=2 add an exponential decaying term
!  with large rho_e near surface
! electron density in g/cm**3
  heexp=2.7d12*exp(- (r-11.d0)/0.18d0)
!  multiply by
!  electron fraction = 0.4
!  Avagadro's number= 6.023d23=ava
!  to get density in 1/cm**3
  he=2.d0*heexp*0.4d0*ava*gfermiort2 + he
  he=2.d0*heexp*Yevar*ava*gfermiort2 + he
  endif
  henc = heexp*ava*gfermiort2*(1.d0-Yevar) + henc
  endif
  endif!--------------------------
  rlog=log(r)
  call splint(rgrid,rhoegrid,rhoe2grid,iegrid,rlog,rhoelog)
  he=2.d0*gfermiort2*exp(rhoelog)
  call splint(rgrid,rhobgrid,rhob2grid,iegrid,rlog,rhoblog)
  he=2.d0*gfermiort2*exp(rhoblog)*Ye
  henc=gfermiort2*exp(rhoblog)*(1.d0-Ye)
  he=2.d0*gfermiort2*exp(rhoblog)*Yevar
  henc=gfermiort2*exp(rhoblog)*(1.d0-Yevar)
  endif
  endif
  endif
  hm=dm20/(4.d0*e)*cos2v
  hm2=dm20/(4.d0*e)*sin2v
  helec(1,1,1)=.5d0*he-hm
  helec(1,2,1)=hm2
  helec(2,1,1)=hm2
  helec(2,2,1)=-.5d0*he+hm
  helec(1,1,2)=-.5d0*he-hm
  helec(1,2,2)=hm2
  helec(2,1,2)=hm2
  helec(2,2,2)=.5d0*he+hm
!  the factors of .5 come from removing the trace
  elseif(spinco.eq.1) then
  helec(1,1,1)=he-hm-henc
  helec(1,2,1)=hm2
  helec(2,1,1)=hm2
  helec(2,2,1)=hm-henc
  helec(1,1,2)=-he-hm+henc
  helec(1,2,2)=hm2
  helec(2,1,2)=hm2
  helec(2,2,2)=hm+henc
!  can not "remove trace" as the spin coherence Hamiltonian is already traceless
  endif  elseif(nflavor.eq.3) then
!  1 is electron flavor neutrino
!  2 is mu flavor neutrino
!  3 is tau flavor neutrino
  helec(:,:,1)=hvac(:,:)/(2.d0*e)
  helec(:,:,2)=hvac(:,:)/(2.d0*e)
!  add electron potential, keep it traceless
  helec(1,1,1)=helec(1,1,1)+2.*he/3.d0
  helec(2,2,1)=helec(2,2,1)-  he/3.d0
  helec(3,3,1)=helec(3,3,1)-  he/3.d0
  helec(1,1,2)=helec(1,1,2)-2.*he/3.d0
  helec(2,2,2)=helec(2,2,2)+  he/3.d0
  helec(3,3,2)=helec(3,3,2)+  he/3.d0
!  if(init.eq.0) then
!  write(6,*) ' Hamiltonian, R,E,he = ',r,e,he
!  write(6,*) ' Neutrinos '
!  write(6,'(1p,3e17.9)') helec(1,1:3,1)
!  write(6,'(1p,3e17.9)') helec(2,1:3,1)
!  write(6,'(1p,3e17.9)') helec(3,1:3,1)
!  write(6,*) ' Anti-Neutrinos '
!  write(6,'(1p,3e17.9)') helec(1,1:3,2)
!  write(6,'(1p,3e17.9)') helec(2,1:3,2)
!  write(6,'(1p,3e17.9)') helec(3,1:3,2)
!  init=1
!  endif
!  again, this hamiltonian will already be traceless
  helec(1,1,1)=helec(1,1,1)+he-henc
  helec(2,2,1)=helec(2,2,1)-henc
  helec(3,3,1)=helec(3,3,1)-henc
  helec(1,1,2)=helec(1,1,2)-he+henc
  helec(2,2,2)=helec(2,2,2)+henc
  helec(3,3,2)=helec(3,3,2)+henc
  endif     endif
  return
  end function helec
  function elecfrac(r,elecprofile)
!  We can choose from a variety of functional forms for the electron fraction
  real(kind=reel8) :: elecfrac
  integer,intent(in) :: elecprofile
  if(elecprofile.eq.1) then
  if(r.lt. 9.d+2) then
  elecfrac=.1d0
  elseif(r.ge. 9.d+2 .and. r.le. 5.d+3) then
  elecfrac=(.3d0*r/4.1d+3)+.03415d0
  elseif(r.gt. 5.d+3) then
  elecfrac=.4d0
  endif
  elseif(elecprofile.eq.2) then
  elecfrac=.4d0
  else
  elecfrac=.4d0
  endif
  return
  end function elecfrac
  end module helectron
Sorry for the long piece of code.
Basically what I've added to this piece of code is the ability to have a variable electron fraction. The integer varelecfrac is an input which can be 0, 1, or 2 depending on what kind of a variable electron fraction I want to have. My code runs fine if I set varelecfrac equal to 0 or 1, but when I set it equal to 2 it doesn't evolve correctly.
I am completely baffled because I set the electron fraction grid to be 1 for all radii but the code still runs differently if I set varelecfrac equal to 2 than equal to 1 or 0 (in both scenarios the electron fraction has been set to 1 for testing purposes).
In fact, I even wrote a line Yevar=1.d0 right after I call elecfracsplint, thereby overriding all ability for the code to mess around with Yevar and the code STILL runs differently.
I am totally baffled at this point. I don't even know what else to try debugging.
iprofile is set to 3, spinco is set to 0 or 1 and the problem persists regardless of what I set spinco to. If I set spinco to 0, the code should actually not worry about this variable electron fraction at all since in that case it should be reading an electron density grid directly instead of a baryon density grid. But this problem persists! What is happening...T_T
I apologize for the implicit variables in this code. It was written this way when I got it.
I count 567 lines of code.
In the varelec_init() subroutine? Some detail on what "doesn't evolve correctly" means would be helpful. Presumably something untoward is happening after this code (if I'm in the right subroutine). In terms of the code and variables, what should be happening but isn't. You need to be more specific than the code "runs differently."
Fortran:
  if(myid.eq.0) then
  icomments=1
It's extremely difficult to follow this code as there is absolutely no indentation to make it easy to spot the bodies of each if.. elseif clause.
I can only see the end result, and that is the wave function. Basically what happens with varelecfrac equals 0 or 1 is that the terms in the wave function evolves slowly. When varelecfrac is set to 2 the wave function makes a sudden jump in evolution at around 901km (the simulation starts at 900km). The probability for a type 1 neutrino to evolve to a type 2 neutrino in the varelecfrac equals 0 or 1 case takes about 200-300km to grow from 0 to .001 whereas in the varelecfrac equals 2 case it takes 1km.
The point is though that right now I have it set up so that no matter what I set varelecfrac (and spinco for that matter) equal, the code should be running (essentially) the same exact thing. But it is not.
I'm a bit confused here. If I understand correctly, you mean this part of the code
Fortran:
  Yevar = .4d0
  endif
Shouldn't Yevar = 0.4d0 for all cases to be the same?
By the way, the first part of elecfracsplint is very inefficient. Instead of going through the list of points until you find the where the desired position is with respect to the list, you should use a bisection method.
Fortran:
  Yevar = .4d0
  endif
Well 1 or .4 it shouldn't make a huge difference, but yeah I set it equal to .4 as well and the code runs differently. I rewrote the code so it read like this:
Fortran:
  Yevar = .4d0
  Yevar = .4d0
  endif
Fortran:
  Yevar = .4d0
  Yevar = .4d0
  endif
But when varelecfrac = 1, Yevar is not necessarily 0.4.
Yeah it goes from .1 to .4...don't worry about the varelecfrac=1 for right now. The difference between .1 and .4 and 1 is significant, but not enough to make the wave function evolve 300+ times faster. varelecfrac=1 and varelecfrac=0 cases evolve similarly because the effects which are very sensitive to electron fraction I have not added to the code yet. The problem is that the code runs very very differently when varelecfrac=2, even if I manually set Yevar=.4.
I first thought that I might have typo'd some of the arrays and perhaps overwrote my rhobgrid array with a yegrid array or something, but I looked through the code several times and did not find such an error.
Then my suggestion is to comment out the call to elecfracsplint to see if anything nefarious is going on in that subroutine.
Ok, I commented out that line and the glitch is still present...:(
My hunch is the error occurs in varelec_init because I've basically tried everything in the helectron and elecfracsplint to check to make sure it wasn't messing around with the actual electron fraction. I've even written code that basically just says "write(6,*) Yevar" inside helec and seen that the electron fraction is initially normal. The problem with this method is helec gets called tens of thousands of times at each radial step so if I put a write statement inside it and don't stop the code it will literally run me out of hard drive space saving this text file lol.
EDIT: I checked Yevar at r=950 and it was still 1...so...
Assuming that your hunch is correct about the error occurring in varelec_init(), it's not surprising to me that you get different behavior when varelecfrac is 2 as compared to when the values are 0 or 1. The only thing that is happening when varalecfrac is 0 or is 1 is that efname gets set to either 'Constant electron fraction' or 'Analytic profile', respectively. All the rest of the action in this subroutine occurs when varalecfrac is 2.
Here is the block of code in varalec_init() starting with the check to see if varalecfrac equals 2.
I have added indentation to your code to make it more readable.
One thing that stands out to me is the backspace command 14 lines down. Per some Oracle docs for Fortran 77 that I found, "The BACKSPACE statement positions the specified file to just before the preceding record." Is there some reason for doing this? A comment would be useful giving an explanation for why this is needed.
Fortran:
     if(myid.eq.0) then
        icomments=1
           else
              icomments=0
              backspace 20
           endif
        enddo
!       read data file
        iend=0
        iegrid=0
           iegrid=iegrid+1
           if(ierr.ne.0) then
              iend=1
              iegrid=iegrid-1
             close(20)
           endif
        enddo
        enddo
        enddo
   endif
  endif
I'm not sure what the backspace is for, it was in the original code that I got... I just modified the portion to read also an electron fraction. I can comment that out and see what happens.
EDIT: Ok, so I commented out the backspace and what happened was that the code read one less line of the electron fraction...I have 8 values in the grid but it read only the last 7.
I'm not saying that the backspace thing was the root of your problem -- it's just that I didn't understand what its purpose was (and there are no comments to help a reader who is unfamiliar with the code).
Did you understand the rest of my comment, the part where I said that virtually everything in varelec_init() is going on when varelecfrac is 2? The parts for varelecfrac values of 0 and 1 are essentially no-ops, doing nothing more than setting a couple of strings. It's no wonder that varelecfrac == 2 behaves differently than for the the other two values.
Yes, but what varelec_init() does is set the values of ryegrid and yegrid for the interpolation of the electron fraction. If the interpolation is not used, as when elecfracsplint is commented out, there should be no difference. Anyway, a good way to check if the problem is in varelec_init is to change
if(myid.eq.0) then
to
if(.false.) then
such that that part of the code is not executed, in conjunction with commenting out the call to elecfracsplint.
I notice also that the values of ryegrid and yegrid are not propagated to the other processors. Only myid = 0 will have the correct values.
if(myid.eq.0) then
to
if(.false.) then
You are right, I have not parallelized the code yet. I am currently running this code on a single core. I will comment out the call to varelec_init and see what happens.
EDIT: Ok, so I commented out varelefrac_init and the call to elecfracsplint and set Yevar=1 and the bug went away. I think the problem is in varelecfrac_init then...not sure what though.. =/
A general debugging hint. Put write statements in at key points and examine the outputs till you can narrow the problem down. Concentrate on key interfaces to begin with and compare the working examples with the bad examples.
Another general hint: before you make signficant changes, make a backup (much better: use a version control system). If you really screw it up, you can look at all code changes, or go back to the last working version and implement new things in smaller steps to see what goes wrong.
And can you fix Planc[/color]k's name in variables please? Every future editor of that code will hate you for misspelled names as variables.
The answer to the question "How did I screw up my code?" is in the title: FORTRAN[/size]
And can you fix Planck's name in variables please? Every future editor of that code will hate you for misspelled names as variables.
I never noticed that misspelling lol...but it's not mine, it was there when I got the code. I'm not sure which parts of the code uses that variable, so to fix this misspelling I'll have to look through all the other modules to figure out where I have to fix it. I'll get on that eventually.
I think I have the problem narrowed down to the varelecfrac_init subroutine in the code, but as that subroutine should only initialize an electron fraction grid, I'm not sure what kind of write statements I can make to verify the variables. I have already written write statements for the electron fraction itself when the actual electron fraction is figured out in helec, and there are no problems with it, also the varelecfrac_init subroutine itself has write statements to show the grid that I inputted and there's no problems there...so I'm kind of at a loss. =/
Oh my...so I actually edited out the part in varelecfrac_init that read in an electron fraction grid and just set the grid manually myself. The bug is exactly the same...
I even cranked up the electron fraction to 100 and the results did not change. This is so baffling!
It seems that if varelecfrac_init is called, no matter what I set the electron fraction to, the results are the same..
There is no varelecfrac_init subroutine, at least in the code that you posted at the start of this thread. Is there such a sub in some other module that you didn't show us?
I'm sorry, I've been calling it the wrong name. I meant varelec_init.
varelec_init() doesn't call any other routines in the module, and none of the other routines (functions/subs) call varelec_init(). Where in your code does varelec_init() get called?
It might be useful to draw a tree-like structure that shows how all of the functions and subs in the module get called, presumably from your main program. Once you have that nailed down, you can investigate whether each subroutine/function is being called with the right parameters, and that when each of these routines exits, the arrays contain appropriate values.
It would also be helpful to put together some small files as inputs, and hand-simulate what should happen vs. what actually happens. For the "what actually happens" part, a debugger would be very useful. Are you using some sort of debugger?
The main code calls varelec_init, and it only calls it once. That is the only place varelec_init is ever called.
If I comment out that call then messing around with the electron fraction "Yevar" actually changes the results around. If I keep that call, the results appear to always be the same bugged result no matter what I set "Yevar" to later.
Ok so it looks like if I comment out just this portion of the code in varelec_init:
Fortran:
  iend=0
  iegrid=5
  iegrid=iegrid+1
  read(21,*,iostat=ierr) ryegrid(iegrid), yegrid(iegrid)
  if(ierr.ne.0) then
  iend=1
  iegrid=iegrid-1
  close(21)
  endif
  enddo
The bug is gone...so it has to be something weird happening with ryegrid and yegrid. But even if I set those 2 grids manually the bug is still there...any ideas?
I have a hard time following the code you're posting, as there is no indentation. I hope there is some indentation in the code you're working with. Anyway, here is that section with reasonable indentation.
Fortran:
iend=0
iegrid=5
   iegrid=iegrid+1
   if(ierr.ne.0) then
      iend=1
      iegrid=iegrid-1
      close(21)
   endif
enddo
Some comments:
1. Why does iegrid start off at 5? There should be a comment in the code that explains this "magic number."
2. At the start of the while loop, it reads ryegrid(1) and yegrid(1).
3. If no read error occurs, it continues reading pairs of numbers ryegrid(2) and yegrid(2), etc., until ierr gets set to some nonzero value. After that, the code sets iend to 1, decrements iegrid, and closes unit 21. It then exits the do loop.
Are you confident that the ryegrid and yegrid values being read in are the right ones? You could add a write statement right after the read statement to echo the values read to the console. If the file is really large, you could follow my earlier suggestion of using a smaller file that you craft, and see if that's giving you the right values.
Also, are you using a debugger? They are invaluable for chasing down bugs.
The code came to me not-indented...=[
Sorry, this was left in after I commented out this whole section. It usually starts at 0, but I didn't want the write statements later to spazz out since they occur in do loops that go from 1 to iegrid so I just set it to 5.
In fact, right after this section of code is a section for write statements to show me what ryegrid and yegrid are (you can see them in the original post) and I verified that they are inputted right. The grid I'm using right now only has like 8 values which I'm using for debugging purposes. The weird thing about this bug is if I replace this entire section of code with something like
Fortran:
do i=1,10
ryegrid(i)=500*i
yegrid(i)=.1*i
enddo
The same exact bug occurs as when I'm reading these values from a text file.
I am not using a debugger...I don't actually know of one a chunk of code like this..
Then do yourself a favor and fix it! I take it that you now own this code. It behooves you to transform it from this write-only crap that some barely literate programmer cobbled together, to code that can be understood at a glance. They had to do it this way back in the 60s, but we're in a new millennium now.
Fortran:
do i=1,10
ryegrid(i)=500*i
yegrid(i)=.1*i
enddo
So if the code is reading the values correctly, then it seems to me that the problem is either with the values in the file, or in some other part of the program that does something with this grid stuff.
Part of "I don't actually know of one a chunk of code like this" is missing. If you have access to a debugger you should be using it. Get the docs for whatever debugger you have available and learn how to set a breakpoint in the main program. Being able to single-step through your code is extremely valuable. I wish there had been a debugger in the first programming class I took back in '72. It would have made things a lot easier.
This is why I'm totally stumped. The only other part of the program that uses these grids is in the subroutine elecfracsplint where it uses these grid values to extrapolate a Yevar at each radius. But even commenting out the (one and only) call to elecfracsplint does not fix the bug! T___T
Thanks for your advice by the way, I will try to get to it.
Using a small set of data (like your input file with 6 elements, I think you said), tell us what you expect the code to produce as output, and what it actually produces as output. The more precise information about what is happening you can provide, the better chance we have of figuring out what the problem is.
Earlier I asked you this:
Your reply was this:
I said I didn't understand the last part of what you said. What does "I don't actually know of one a chunk of code like this" mean?
Just about any debugger would let you set a breakpoint in your main program (or anywhere else in any of the called subroutines and functions), and then start single-stepping through your code.
Also, what compiler are you using?
