Fourier transform between variables of different domains
1 reply · 1K views
alec_grunn
I'm doing a research project over the summer, and need some help understanding how to construct an inverse Fourier transform (I have v. little prior experience with them).
1. Homework Statement
I know the explicit form of ##q(x)##, where
$$ q(x) = \frac{M}{2 \pi} \int _{- \infty}^{\infty} dz e^{-iMxz} C_q(z)
and want to find ##C_q(z)## using an inverse Fourier transform. As far as I can tell, there's no simple relationship between ##z## and ##x##. And the domain of ##x## is ##[0,1]##.
[/B]
Explicit form of ##q(x)##: ##q(x) = x^{1/5}(1-x)^3##.
I thought I would start with a substitution, since ##z## and ##M## are independent: ##\mu = Mz##. Therefore,
$$q(x) = \frac{1}{2 \pi} \int _{- \infty}^{\infty} d\mu e^{-ix\mu} \tilde{C}_{q}(\mu)
And from this relation I use the inverse Fourier transform to get
$$\tilde{C}_{q}(\mu) = \int _{0}^{1} dx e^{ix\mu} q(x)
$$ \Rightarrow \quad C_{q}(z) = \int _{0}^{1} dx e^{iMxz} q(x)
Is this reasoning sound? Any help is appreciated.
[/B]
Do you mean
$$q(x) = \begin{cases}
0 & x < 0 \\
x^{1/5}(1-x)^3 & 0 \leq x \leq 1 \\
0 & x > 1
\end{cases}
If so, the Fourier transform is
$$F(k) = \int_0^1 e^{ikx} q(x) \, dx$$
and the inverse Fourier transform is
$$q(x) = \frac{1}{2 \pi} \int_{-\infty}^{\infty} e^{-ikx} F(k) \, dk$$
If you do everything correctly the inverse Fourier transform should evaluate to ##0## if ##x < 0## or ##x > 1##, and to ##x^{1/5}(1-x)^3## if ##0 \leq x \leq 1##.
To see what is happening, look at the simpler example of
f(x) = \begin{cases}
0, & x< 0 \\
1, & 0 \leq x \leq 1 \\
0, & x > 1
\end{cases}
Computing ##g(k) = \int_0^1 e^{i k x} \, dx## is easy, and inverting to get
$$F(x) = \frac{1}{2 \pi} \int_{-\infty}^{\infty} g(k) e^{-ikx} \, dk$$
is also relatively straightforward. You will find that ##F(x) = 0## for ##x<0 \; \text{or} \; x>1##, and ##F(x) = 1## for ##0 < x < 1##.
However, the values of ##F(x)## at ##x=0## and at ##x=1## may differ from ##f(0)## and ##f(1)## for the usual reasons about the values of Fourier series/integrals at discontinuity points.
In fact:
$$F(x) = \begin{cases}
0,& x < 0 \\
1/2, & x = 0 \\
1, & 0 < x < 1 \\
1/2, & x=1 \\
0 , & x > 1
\end{cases}
Thus, ##f(x) = f(x),\, x \neq 0,1##.
