Fraction Algebra Rusty Need Help on Equation
  • Thread starter Thread starter bluestar
    Algebra Fraction
The discussion revolves around simplifying the equation E_n and verifying its correctness, particularly in relation to the fractions involved. Participants noted discrepancies in the simplification process, especially regarding the substitution of r_n and the use of Planck's constant versus Dirac's constant. A key point of contention was the balance of the equation, with some calculations leading to incorrect conclusions about equality. The conversation highlights the importance of careful verification in algebraic manipulations, especially in complex equations. Ultimately, the group seeks clarity on the original formulas to resolve the inconsistencies.
bluestar
I was reading and came across a formula that didn’t look right so I tried to simplify the left side to match the right side; however, my fraction algebra is a little rusty and could use some guidance. I did get the 2 fractions to a common denominator; however, the best I could do was factor out an r. Here is the formula:
<br /> E_n=\frac{n^2h^2}{2\mu r_n^2}- \frac{e^2}{4\pi\epsilon_0 r_n}=-\frac{e^4\mu}{8\epsilon^2_0 n^2h^2}<br />
The equation can be found in context at the following link, which should take you to page 173, equation (5.40) is on page 172.
http://books.google.com/books?id=Fn...esnum=21&ved=0CJQBEOgBMBQ#v=onepage&q&f=false
Stochastic Simulations of Clusters: Quantum Methods in Flat and Curved Spaces By Emanuele Curotto
Mathematics news on Phys.org
It looks like you're supposed to substitute rn from Eq. 5.39 into Eq. 5.40. However, I've tried it two different ways and I am not getting the RHS. I end up getting this:
\frac{n^2h^2}{2\mu r_n^2}- \frac{e^2}{4\pi\epsilon_0 r_n}=-\frac{e^4\mu}{32\pi^2\epsilon^2_0 n^2h^2}
Note that I'm not familiar with the material in the book you referenced, so it is quite possible that there is something that I am missing.
Inserting the values for r was helpful because it gave us more variables to work with. Here is how far I was able to take it. Close, but still off a little, (might as well be a kilometer)
<br /> r_n=\frac{4\pi \epsilon_0 n^2h^2}{\mu e^2}<br />
Now I inserted the value for r
<br /> E_n=\frac {\left(n^2h^2\right)\left(\mu e^2\right)^2}{\left(2\mu \right)\left(4\pi \epsilon_0 n^2h^2 \right)^2} - \frac{\left(e^2\right)\left(\mu e^2\right)}{\left(4\pi \epsilon_0\right)\left(4\pi \epsilon_0 n^2h^2\right)} =-\frac{e^4\mu }{8\epsilon^2_0 n^2h^2}<br />
Now expanding the squared brackets
<br /> E_n=\frac {n^2h^2 \mu^2 e^4}{2\mu 16 \pi^2 \epsilon_0^2 n^4h^4 } - \frac{e^4\mu }{4\pi \epsilon_0 4\pi \epsilon_0 n^2h^2} =-\frac{e^4\mu}{8\epsilon^2_0 n^2h^2}<br />
Now combining variables
<br /> \frac {\mu e^4}{32\pi^2 \epsilon_0^2 n^4h^4} - \frac{\mu e^4 }{16 \pi^2 \epsilon_0^2 n^2h^2}= -\frac {e^4\mu}{8\epsilon_0^2 n^2h^2}<br />
this looks correct. in the book you quoted, the formulae for En and rn are in terms of hbar, not h, which turns the 32π2hbar2 into 8h2.
There was a typo in the denominator in the first term of the last equation in Bluestar's last post. That equation should look like the following:
<br /> E_n=\frac {\mu e^4}{32\pi^2 \epsilon_0^2 n^2h^2} - \frac{\mu e^4 }{16 \pi^2 \epsilon_0^2 n^2h^2}= -\frac {e^4\mu}{8\epsilon_0^2 n^2h^2}<br />
Next factor out all variables in the left side that are found in the right of the equal sign
<br /> E_n=\frac {\mu e^4}{8 \epsilon_0^2 n^2h^2} \left( \frac{1 }{24 \pi^2 } -\frac {1}{8\pi^2} \right) = -\frac {e^4\mu}{8\epsilon_0^2 n^2h^2}<br />
Inverse the factored out variables and move to right side.
<br /> E_n=\frac{1 }{24 \pi^2 } -\frac {1}{8\pi^2} = -\frac {e^4\mu}{8\epsilon_0^2 n^2h^2}\frac {8 \epsilon_0^2 n^2h^2}{e^4\mu } <br />
Reduce right side to 1
<br /> E_n=\frac{1}{24\pi^2}=\frac{1}{8\pi^2}=1<br />
Simplify equation
<br /> 8 = 24 ...or... <br /> 1 = 3<br />
It would appear the equation in the book, referenced earlier does not balance out.
Hey Deveno, I went back and looked at both formulas with my laptop and still didn’t see the hbar. Could be the resolution of the laptop is not so great. When first working this problems I wondered if those were Planck’s constants or Dirac’s constants. Subsequent to your note I posted some follow-up work on the formula and found it does not balance. Even though Dirac’s constant should have been used it still does not change the imbalance in the numeric constants. But, check it out if you want and let's see.
wait a minute...you factor 32 as 8*24 and 16 as 8*8?
you should have:
\frac{1}{4\pi^2} - \frac{1}{2\pi^2}
on the left, at this point
no, it reduces to negative 1
Simplify equation
what i get that you ought to have, is:
\frac{-1}{4\pi^2} = -\frac{\hbar^2}{h^2}
which makes perfect sense.
What a silly mistake. All I can say is that it was late, I was in a rush and didn’t double check my work which I always try to do. Anyway, what you got does make sense and does balance out.
From you answer I see you used h and hbar. Thus, I am still working with a handicap because I cannot determine which terms are h and which terms are hbar in the original equation in the book. Deveno, would you kindly post the original formulas (5.40) and (5.39) so I can see which terms contain h and hbar. Please... Thanks
here is a magnified version of the equations in question (click on the thumbnail to see the larger version).
Deveno, THANKS!
Appreciate the help.
