How High Was the Tree from Which the Squirrel Fell?
  • Thread starter Thread starter Gazaueli
    Fall Free fall
The problem involves calculating the height of a tree from which a flying squirrel falls, using the equations of motion. The squirrel travels the last 2 meters of its fall in 0.2 seconds, leading to an initial velocity calculation of 10.98 m/s for the last segment. However, the professor's correction indicates the height of the tree is 6.15 meters, based on a different calculation for the initial velocity of the last 2 meters, which is 9.02 m/s. The discrepancy arises from the interpretation of the initial velocity and the application of the equations.
  • Understanding of kinematic equations, specifically d = vt + 0.5at² and v_f² = v_i² + 2ad
  • Basic knowledge of free fall and gravitational acceleration (g = 9.8 m/s²)
  • Ability to manipulate algebraic equations for solving physics problems
  • Familiarity with units of measurement in physics (meters, seconds)
  • Review kinematic equations in detail, focusing on their applications in free fall scenarios
  • Practice solving problems involving free fall and initial velocity calculations
  • Explore the concept of displacement and its relation to height in free fall problems
  • Investigate common mistakes in applying kinematic equations, particularly in sign conventions and unit conversions
Students studying physics, particularly those focusing on mechanics and kinematics, as well as educators looking for examples of common calculation errors in free fall problems.
Gazaueli
Free Fall simple question, Answer check ASAP please!
A flying squirrel falls from the top of a tree, without initial velocity. It travels the last 2 meters of its fall in 0.2s. What was the height of the tree?
d=\upsilon_{i}t + \frac{1}{2}at^{2}
\upsilon_{f}^{2}= \upsilon_{i}^{2} + 2ad
1. I first concentrated on the last 2 meters of the squirrel's fall by using the equation d=\upsilon_{i}t + \frac{1}{2}at^{2}. I rearranged it to find the initial velocity: \upsilon_{i}=\frac{d-(0.5)at^{2}}{t}
For initial velocity, I got
\upsilon_{i}=\frac{(2m)-(0.5)(-9.8m/s/s)(0.2)^{2}}{(0.2)}
\upsilon_{i}=10.98m/s
2. Now I focused on the rest of the squirrel's fall before the last 2m.
Here I used the equation: \upsilon_{f}^{2}=\upsilon_{i}^{2}+2ad and rearranged it to find d: d=\frac{\upsilon_{f}^{2}-\upsilon_{i}^{2}}{2a}
By substitution I got:
d=\frac{(10.98m/s)^{2}-(0m/s)^{2}}{2(-9.8m/s/s)}= -6.15m as displacement.
The displacement here can also be seen as the height, therefore H=6.15m
I then added 6.15m to the last 2m to get H=8.15m
The problem however is that in the corrections provided by my professor, his answer is that the height of the tree is 6.15m
His work looks like this:
\upsilon_{i} (last 2m)= \frac{2m}{0.2s}-\frac{(9.8m/s/s)(0.2s)}{2}= 9.02m/s
Did he forget to square the time here?
And in the second part he then calculates: d=\frac{(9.02m/s)^{2}}{2(9.8m/s/s)}+2m=6.15m
Can someone please check if I missed something, or if perhaps my prof's answer is incorrect?
Thank you!
Recheck that calculation. The value you've given corresponds to the impact speed at the ground, not the speed at 2m. Could be you've selected the result from a different calculation.
Thank you!
  • · Replies 34 ·
