What is the relationship between frequency and angular speed?
The discussion focuses on the relationship between frequency and angular speed, specifically in the context of a DVD drive rotating at 4800 rpm. The angular speed is calculated using the formula ω = 2πf, resulting in an angular speed of 4800 rpm being equivalent to 4800 * 2π radians per minute. Additionally, the linear speed at various distances from the center is determined using the formula v = rω, where r is the radius in centimeters. The conversion from centimeters per minute to kilometers per hour is also addressed.
  • Understanding of angular speed and frequency
  • Familiarity with the formula ω = 2πf
  • Knowledge of linear speed calculations using v = rω
  • Basic unit conversion skills (cm/min to km/hr)
  • Study the derivation and applications of the formula ω = 2πf
  • Explore linear speed calculations for circular motion
  • Learn about unit conversions between different speed measurements
  • Investigate practical applications of angular speed in mechanical systems
Students studying physics, particularly those focusing on rotational motion, as well as educators and anyone interested in understanding the principles of angular speed and linear velocity.
urekmazino
Hello there, I'm new here and i need some help on my home work.
A DVD drive rotates at an angular frequency of 4800 rpm. a) what is it's angular speed in rpm? b) at 4800 rpm, what is the linear speed (in knm/hr) of (i) the center point and points (ii) 5 cm and (iii) 6 cm from the center?
Thanks!
Mathematics news on Phys.org
Hi urekmazino.
(a) If a device rotates at $f$ revolutions per minute, it will go through $2\pi\times f$ radians in that time. Thus the formula between angular speed $\omega$ and frequency $f$ is
$$\omega\ =\ 2\pi f.$$
Note that whereas frequency (in this problem) is measured in revolutions per minute, angular speed is measured in radians per minute.
(b) The linear (or tangential) speed of a point at distance $r$ from the centre of revolution is $r\omega$, where $\omega$ is the angular speed. In this case, multiplying angular speed in radians per minute by radius in centimetres will give a linear speed in centimetres per minute. Can you convert it to kilometres per hour?
13K
  • · Replies 21 ·
20K
  • · Replies 20 ·
