Friction Coefficient, F1 corners
The discussion focuses on calculating the tyre friction coefficient for Formula 1 corners, specifically at the Gilles Villeneuve circuit in Canada. The equation Fc=mu*Fnormal is utilized, where Fnormal includes both downforce and the car's weight. A maximum friction coefficient (mu) of 1.7 is mentioned, but it varies by corner, leading to negative downforce values in some calculations. Participants emphasize that lateral grip changes during braking and acceleration, and recommend Carrol Smith's book "Tune to Win" for further understanding of these dynamics.
  • Understanding of tyre friction equations, specifically Fc=mu*Fnormal
  • Knowledge of downforce dynamics in racecars
  • Familiarity with lateral grip variations during cornering
  • Basic proficiency in Excel for calculations and data analysis
  • Research the impact of downforce on tyre friction in Formula 1
  • Learn about the effects of braking and acceleration on lateral grip
  • Explore advanced tyre modeling techniques for racecar dynamics
  • Read "Tune to Win" by Carrol Smith for insights on racecar performance
Race engineers, motorsport analysts, and anyone involved in the design and optimization of Formula 1 vehicles will benefit from this discussion.
al_garnett
I am using the tyre friction equation Fc=mu*Fnormal to calculate the downforce required for each corner of the Gilles Villeneuve circuit in Canada.
Fnormal composes of the downforce and weight of the car.
mu has a maximum value of 1.7, however this value will vary from corner to corner right?
this is resulting in negative values for downforce in some corners.
Does anyone know a way of calculating the tyre friction coefficient for each corner without needing the Fnormal force?
All of my calculations are on the attached excel spreadsheet.
Could you explain a mechanism that the friction coefficient could change from corner to corner?
Where did you get your value of 1.7?
It sounds like you are assuming the car is at the limit of it's lateral grip for every corner, through the entire corner.
Lateral grip is decreased during braking or acceleration.
Downforce is a function of forward velocity.
Racecars do not follow a circular arc around corners or have constant speed.
Carrol Smiths "Tune to win' is a great, easy reading book that'll clear up some misconceptions.
Remember that the friction equation you are using says,
Ffriction <= mu * Fnormal
The friction force can certainly be less than the product mu * Fnormal.
10K
