What Is the Fundamental Frequency of a Modified Stretched Wire?
The discussion centers on calculating the fundamental frequency of a modified stretched wire, initially vibrating at 369Hz. The wire's length is reduced to one third, its diameter is tripled, and its tension is doubled. Participants clarify the impact of these changes on the frequency formula, emphasizing the correct interpretation of the factors involved, particularly the relationship between diameter and radius. The original poster struggles with the calculations, specifically how to adjust the frequency based on the modified parameters. Ultimately, the conversation helps refine the understanding of the formula and corrects the approach to finding the new frequency.
dantechiesa
A stretched wire vibrates in its first normal mode at a frequency of 369Hz. What would be the fundamental frequency if the wire were one third as long, its diameter were tripled, and its tension were increased two-fold?
f = 1/2L * squareroot(Ft/u)
[/B]
Can someone explain what I've done wrong?
369 = 1/2L * Sroot(Ft/u)
L is 1/3, so 1/2L becomes 3/(2L)
The Ft is doubled, but the u needs to be broken down further.
m/l = u
l is 1/3
m = dv
d stays the same, so v is the relevant one.
V = pi r2h
r is tripled, so the V increases by a factor of 9. However, since the h (aka l) also changes by a third. Total change of V is x3.
so, 3*m / (l/3)
All together,
Sroot ( 2Ft / (9u)
However, 369 * (3/2) * Sqroot (2/9) is wrong. ( = 260.922402258)
Thanks.
You had a factor of 1/2L. Now you have a factor of 3/2L. So you don't multiply by 3/2.
Likes dantechiesa
Diameter is tripled
In the formula for V , r is the radius , so since diameter is tripled, radius goes up by x1.5.
Radius and diameter are in proportion. If one is tripled, so is the other.
Likes Delta2
Oh would you multiply by 3 only? Since the 1/2 was already apart of the equation?
ALso, does the remaining work with the square root seem right?
Thanks.
Likes Delta2
Yes
Likes dantechiesa
mjc123 said:
Yes
Thanks a lot!
  • · Replies 26 ·
10K
