Galactic Rotation and Energy-Momentum Tensor
  • Context: Graduate
  • Thread starter Thread starter Christian Thom
    Momentum Tensor
The discussion centers on the impact of galactic rotation on the energy-momentum tensor, drawing parallels with the Kerr model for black holes. It highlights that while general relativity (GR) effects are typically negligible in galaxy modeling, incorporating the angular momentum of the galactic disk can reveal frame dragging effects. A referenced paper, "General Relativity versus Dark Matter for rotating galaxies," argues that GR can account for galaxy rotation curves without invoking dark matter. However, the validity of this claim remains an open question in the scientific community.
  • Understanding of general relativity (GR) principles
  • Familiarity with the Kerr black hole model
  • Knowledge of Newtonian gravity and its limitations
  • Basic comprehension of the energy-momentum tensor
  • Read the paper "General Relativity versus Dark Matter for rotating galaxies" on arXiv
  • Explore the implications of frame dragging in rotating systems
  • Investigate the role of angular momentum in galaxy dynamics
  • Study the differences between Newtonian and relativistic models of gravity
Astronomers, physicists, and researchers interested in galaxy dynamics, dark matter alternatives, and the application of general relativity in astrophysics.
Christian Thom
TL;DR
Is the momentum part of the energy/momentum tensor taken into account in the modelling of the movements of the stars in galaxies ?
Galaxies are very large rotating bodies, so it seems that, as with the Kerr model for black holes, there could be an effect of this global rotation on the energy momentum tensor in the more dense regions of the galaxy that could in turn affect the space-time in the vicinity of the object and so the movements of the stars, with maybe an impact on the evaluation of the dark matter quantity.
Kerr black holes are vacuum solutions, so the stress-energy tensor is zero everywhere.
In modeling galaxies, GR effects are typically negligible so a Newtonian model of gravity is used.
Thank you.
Does the angular momentum of the internal mass need to be accounted for so the frame dragging is included?
Depends how precise you want to be. The usual modelling of galaxies is Newtonian because GR effects are negligible and adding them in simply increases the complexity of the model without making any measurable change to the output. But if you wanted to make the effort, you would need to include the rotation of the galactic disc if you wanted to see frame dragging effects.
GR can be used to make the rotating galaxy not need dark matter to make the velocities constant in the outer rim of the galaxy. Newtonian gravity does not account for the local frame dragging of the local stars to the test star. Here is a paper that shows that dark matter is not needed when GR is used and the angular momentum of the galactic disk is used. https://arxiv.org/abs/2207.04279 titled
General Relativity versus Dark Matter for rotating galaxies​
Even when the stress-energy tensor is zero, the metric of the rotating galaxy contains the angular momentum of the rotating galaxy which does pull the rim stars along at a higher velocity rate than Newtonian gravity allows.
We have had a previous thread on this paper:
https://www.physicsforums.com/threa...ng-gr-explains-dark-matter-phenomena.1016800/
The short version is that it is not clear that the claim of this paper, that the GR frame dragging effect due to rotation is sufficient to account for galaxy rotation curves without dark matter, is correct; it's still an open question. It's a very interesting proposal but it can't be taken as mainstream accepted science, at least not at this point.
  • · Replies 38 ·
  • · Replies 21 ·
  • · Replies 21 ·
