Galaxy with no dark matter? (NGC1052-DF2)
108 replies · 14K views
jerromyjon said:
Yes, I understand that. Electrons are repelled from protons and positrons are repelled from antiprotons. But when we are referring to say hydrogen and antihydrogen, there would be no net charge imbalance and therefore no attraction or repulsion due to charge. So what would make all the pieces annihilate unless electrons only attract positrons and not repel antiprotons? Or is there a sequence where fermions and bosons interact in succession?
If you mix a neutral Hydrogen and anti-Hydrogen gas, they'll still annihilate. They'll just do so more slowly. As they don't have a long-range attraction, you'll have to wait until two atoms randomly get close enough that their electron/positron shells start attracting one another. Once the electron/positron annihilate, there will be a bare proton/anti-proton which will attract one another strongly, and they'll annihilate pretty rapidly.
What happens next depends upon whether the energy from that annihilation escapes the gas or not. If the energy escapes the gas, then the remaining interactions will remain pretty slow. However, if it ionizes the gas, then that may result in an increase in reaction rates (but this may also cause the gas to disperse, making it less dense and slowing the reaction back down).
Astronomy news on Phys.org
What if they are larger atoms? Then there is no "outward dissipation" of the particles and they all annihilate quickly and completely? What if this galaxy is a rare mix of nearly equal proportions and that is why there is no "dark matter component" to be observed? I mean in that case GR is perfectly fine if annihilation and symmetry don't conflict with it, right? We'd be looking at sides of a coin in most galaxies and the rare spread of proportions... like this, where no dark matter or cosmological expansion is neccesary to model it...
Whatever you put together, as long as there is both matter and antimatter in it you will get annihilation. If it is dense enough to form a galaxy, this galaxy (which has no plausible mechanism of forming in the first place) will be immediately obvious to us due to its gamma ray emission.
Why exactly would you expect such a galaxy, which cannot even form, to have no dark matter?
<Moderator's note: Post approved as alternative to another thread. @Mike Johnson: Please read this discussion first to find out, whether your question has already been answered.>
Could dark matter fill 'empty' space, strongly interact with visible matter and be displaced by visible matter?
Could the reason for the mistaken notion the galaxy is missing dark matter is that the galaxy is so diffuse that it doesn't displace the dark matter outward and away from the galaxy to the degree that the dark matter is able to push back and cause the stars far away from the galactic center to speed up?
What if it's not that there is no dark matter connected to and neighboring the visible matter; it's that the galaxy is not well defined enough to displace the dark matter to such an extent that it forms a 'halo' around the galaxy?
Could a galaxy's halo be displaced dark matter and these types of galaxies are not coalesced enough to displace the dark matter into forming a halo?
[Moderator's note: response provided since this poster's question was moved here from a separate thread.]
No, because of the "strongly interact with visible matter" part. The whole point of dark matter is that it does not strongly interact with anything except through its gravity: no EM, no weak interaction, no strong interaction. If it did interact via any of those three mechanisms, we would have other ways of seeing that it was there besides its gravitational effect.
See post #8 for an example of a way dark matter and normal matter could be separated; note that it involves the normal matter interacting with other normal matter; it does not involve any interaction between normal matter and dark matter.
Stacy McGaugh makes an important observation about a paper on NGC1052-DF2 (the "dark matterless galaxy"), in which van Dokkum et al. measure the rms velocity dispersion for DF2 to be 8.4 km/s, with a 90% confidence upper limit of 10 km/s.
It turns out that this is greatly influenced by a key methodological point that is doubtful:
On closer reading, I notice in the details of their methods section that the rms velocity dispersion is 14.3 km/s. It is only after the exclusion of one outlier that the velocity dispersion becomes unusually low. As a statistical exercise rejecting outliers is often OK, but with only 10 objects to start it is worrisome to throw any away. And the outlier is then unbound, making one wonder why it is there at all.
McGaugh also notes that:
I’ve seen plenty of cases where the velocity dispersion changes in important ways when more data are obtained, even starting from more than 10 tracers. Andromeda II comes to mind as an example. Indeed, several people have pointed out that if we did the same exercise with Fornax, using its globular clusters as the velocity tracers, we’d get a similar answer to what we find in DF2. But we also have measurements of many hundreds of stars in Fornax, so we know that answer is wrong. Perhaps the same thing is happening with DF2? The fact that DF2 is an outlier from everything else we know empirically suggests caution.
McGaugh (the leading authority on MOND) notes that the correctly calculated MOND prediction, including the External Field Effect is:
σ = 14 ± 4 km/s.
van Dokkum, et al., incorrectly calculated a MOND prediction of 20 km/s.
So, the evidence that this is really a no dark matter phenomena galaxy is not strong, and the evidence that it contradicts MOND is likewise weak.
[Moderator's note: This was posted in a separate thread while this thread was closed. Since the thread is reopened, this post and its responses have been moved here.]
ohwilleke said:
σ = 14 ± 4 km/s.
That is not much better than no prediction at all (the 2 sigma range covers everything from 22 km/s to 6 km/s, a factor of nearly 4), and it is unclear how many of the assumptions that went into that number are included in the uncertainty.
I don't think it is fair to call it incorrectly. They used a different assumption (e.g. a larger separation from the other galaxy is sufficient).
The outlier has a very large uncertainty and a very large separation from the rest. Using an unweighted rms doesn't make sense. As far as I understand the original paper they don't remove it, they just assign a smaller weight to it according to the larger uncertainty. Which is the most reasonable thing to do.
That is true. It is, however, key to understanding the dynamics of the galaxy. Ignore MOND. It's still important to the dynamics what the relationship between DF2 and NGC1052 is. And that's far from clear.
One way to look at this galaxy is that there is a discrepancy between the distance we infer from the dynamics, about 8 MPc, and the distance we infer from standard distance measures. The authors' favor the larger distance, which means the dynamics is odd, and it's interpreted as zero gas and zero dark matter (or worse, some gas and negative dark matter :devil: ). While I tend to agree with them, a closer distance would change their results (the authors say this as well) and would explain the anomalous brightness of the globulars. You would have to understand why DF2's light profile is 40-45% too smooth (the SBF distance measurement), but that's the only discrepant result left in this view.
Moderator's note: A number of off topic posts have been deleted and the thread has been reopened. Please keep discussion within the bounds of peer-reviewed literature relevant to this particular galaxy.
phinds said:
It would make no sense at all to believe that gravity acts one way for normal matter and another way for dark matter.
Why? We don't even know if dark matter is matter at all? We assume it is because we see gravitational effects in space-time. But that only matter can cause gravitational effects in space-time is itself an assumption.
Only in the sense that the Einstein Field Equation itself is an "assumption"; that is, we are "assuming" that General Relativity applies. Since GR has been experimentally confirmed to many decimal places this seems like a reasonable "assumption" to make; moreover, nobody has any other theory of gravity that makes any different "assumption" about what can cause gravitational effects, yet still makes correct predictions.
We know that DM is matter because it clumps, at least around galaxy clusters, in a way that massless particles such as photons do not. In fact, it clumps more than neutrinos, as far as we can tell, and neutrinos are not massless, so we conclude that DM consists of particles even more "massive" than neutrinos [if we can use that word for neutrinos!].
Matter is certainly not the only thing that can cause gravitational effects: Any form of energy will do. Matter is the densest form of energy, but 1 joule of photons have the same effect as 1 joule of matter (times c^2).
This is not an assumption. Like any statement in natural science, this a provisional statement, subject to refutation based on observation. But it is already based on an enormous number of observations, so as conclusions go, it is exceptionally firm.
Labeling an unknown gravitational phenomena a form of matter, tends to narrow one's thinking about the problem, and put it in a box. Does it not? We haven't had to contend with an potential alternate theory of gravity until the confirmation that the effects of "dark matter" exist.
This is not necessarily true. The main issue is how DM behaves and for a DM candidate that is thermally produced in the early Universe, you typically need it to be heavier than neutrinos to constitute cold dark matter. However, thermal production at a relatively late stage is not the only possibility. A very popular DM candidate these days is axion DM, which is very appealing from many perspectives. Axions typically have very (very!) light masses and the corresponding DM halos are not built from particles as much as from coherent states, i.e., essentially classical fields.
You are missing large pieces of evidence for the DM component actually behaving like matter. All of the gravitational effects that we observe of DM have exactly the same equation of state parameter as ordinary matter, i.e., pressureless, with an energy density that scales as ##a^{-3}##. If it behaved in any other way it would not be called dark matter.
I'm not sure we are clear that DM clumps around galaxy clusters. It would make more sense that matter (galaxy clusters) tends to clump around regions of space-time where "dark matter" is more prevalent?
Structure formation typically starts with the coalescence of dark matter structures that act as gravitational potential wells for galaxy formation. However, I don't think the order of things is what @JMz considered the important part of his post.
Orodruin said:
This is not necessarily true. The main issue is how DM behaves and for a DM candidate that is thermally produced in the early Universe, you typically need it to be heavier than neutrinos to constitute cold dark matter. However, thermal production at a relatively late stage is not the only possibility. A very popular DM candidate these days is axion DM, which is very appealing from many perspectives. Axions typically have very (very!) light masses and the corresponding DM halos are not built from particles as much as from coherent states, i.e., essentially classical fields.You are missing large pieces of evidence for the DM component actually behaving like matter. All of the gravitational effects that we observe of DM have exactly the same equation of state parameter as ordinary matter, i.e., pressureless, with an energy density that scales as ##a^{-3}##. If it behaved in any other way it would not be called dark matter.
But isn't it true we only are seeing gravitational effects on space-time and not DM actually behaving like matter? I would agree the first assumption to make is that it is an effect caused by a form of matter we can't interact with. But that should not be the end point. Dark Matter may turn out to be a feature of space-time rather than having an effect on it.
What do you think "behaves like matter" means in this context? Essentially your statement in this context reads "isn't it true that we see X and not X?"
No. As @Orodruin has pointed out, calling it "dark matter" is just a way of describing its equation of state. And that is an observable, not an assumption. In other words, "dark matter" is just shorthand for "something that has a matter equation of state, and doesn't interact electromagnetically, but we don't know its microscopic composition". In other words, it makes no assumptions about what it is, it just describes the properties we have so far observed it to have.
No. We see that it has the matter equation of state; its density varies like the inverse cube of the scale factor.
No, it can't, because a feature of spacetime would have to have a density that is constant; it could not vary. We already have a name for this: "dark energy" (or "cosmological constant"). And we already have separate observations that tell us what the density of dark energy is, separate from the density of dark matter.
No, it isn't. In General Relativity, energy, momentum, pressure, and twisting forces all act as sources for gravity. For most familiar matter, mass is always the dominant component because mass energy is so huge. For extremely dense objects or relativistic particles, the other components become significant.
The problem is that dark matter clusters. If dark matter is composed of any kind of particle, then those particles can't move too fast or else they won't cluster (this is why the known neutrinos can't make up dark matter: they move far too quickly due to their small masses). This means that the two primary competing theories to explain dark matter are:
1) A weakly-interacting particle with non-zero mass and low temperature. This can be achieved either through a neutrino-like particle which is very massive (typical estimates are around dozens to hundreds of times the mass of a proton per particle), or through the particles having some specific mechanism to achieve low temperatures despite having low masses (axions fall into this category).
2) Modified gravity. The proposal here is that if gravity behaves differently at very large distances compared to terrestrial experiments, then that might explain the discrepancies.
Currently, modified gravity theories appear to be incapable of fitting observational data without introducing some form of dark matter. Thus, dark matter appears to be the most likely solution to the puzzle.
I think it is worth thinking of axions as a different type of dark matter altogether as it is essentially a classical field and not really particle dark matter (note that this does not mean you cannot find axion particles! That DM would be a coherent state does not exclude single particle states). A good axion in cosmology review where this argument is made can be found here (it is pretty big so it might take some time to download).
Its clear that space time is not constant density, hence the variance of gravitational effects that have resulted in galaxy clusters.
Yes I am aware of the multiple ways gravitational effects can manifest itself, but what are referring to is how these gravitational effects result in the observable universe, so not sure how twisting forces are revenant here in regards to forming galaxy clusters. It relates to how space time reacts to massive objects, and how matter and energy react to the "bending" of space time. Dark matter may not be a particle at all.
Please, define in mathematical terms what it means for space-time to have density.
I.e., typically, density is taken to mean the amount of some quantity contained in a unit of space. What does it mean if you say there's a quantity of space-time per unit of space?
We see X. Where X = gravitational effects on space-time in turn effecting matter and light. We know that matter can have this effect on space-time. But am I wrong or we really don't really understand what makes up space-time, and why massive objects cause it to bend?
No. You are wrong in your nomenclature. What "matter" means in this context is just "something that have these effects on spacetime".
That is a good question. The energy density of space-time, is always measured to be the same locally, only marginally less that matter. This constant density results in the constant speed of light locally.However this density is relatively different depending on the local curvature of space-time due to gravity.
Then please, answer it. It's the term you're using to build an argument. Please, indicate what observations make it clear that it's not constant?
You've now introduced an additional new term: energy density of space time. Please define it. What measurements, which you mention, show it to be always the same locally?
