Galvanometer Spring Weakness and Current Adjustment
  • Thread starter Thread starter Jodi
    Galvanometer
The discussion centers on calculating the new current required for full-scale deflection of a galvanometer when its restoring spring weakens by 26.4%. Originally, the galvanometer required 36.8 µA for full deflection. The relationship between the deflection angle and current is defined by the equation Deflection angle = kI, where k is the spring constant. As the spring constant k decreases due to weakening, the current I must increase to maintain the same deflection angle, leading to the conclusion that the new current can be derived using the equation k'I' = kI.
  • Understanding of galvanometer operation and principles
  • Familiarity with direct variation equations
  • Basic algebra for manipulating equations
  • Knowledge of current measurement in microamperes (µA)
  • Study the principles of galvanometer mechanics and spring constants
  • Learn about direct variation and its applications in electrical circuits
  • Explore the effects of mechanical wear on electrical instruments
  • Investigate methods for calibrating galvanometers after spring adjustments
Electronics engineers, physics students, and technicians involved in the maintenance and calibration of galvanometers will benefit from this discussion.
Jodi
Hi; Could someone please help me with the following question: If the restoring spring of a galvanometer weakens by 26.4% over the years, what current will give full-scale deflection if it originally required 36.8uA? Thanks for your help.
You need to make some assumption here about the construction of a galvanometer. I am going to assume you have an ideal case where the angular deflection of the needle is directly proportional to the current because the magnetic field is constructed to achieve that condition, as illustrated here
http://hyperphysics.phy-astr.gsu.edu/hbase/magnetic/galvan.html
You can then write a direct variation equation that says
The "weakening of the spring" is saying that k is diminished by 26.4%. So what has to happen to I to achieve the former deflection?
Are you saying to do 0.264 x 36.8E-6? Because that doesn't give me the right answer. Thanks.
No. To have the same deflection angle, the product of k times I must not change. If k is reduced by some fraction, the current is going to have to increase. Let k' and I' be the "new" values for the weakened spring and k and I be the "old" values that gave the same deflection. Then
k'I' = kI
A little bit of algebra from here will get you to the answer.
9K
9K
  • · Replies 23 ·
10K
15K
