Gauss-Codacci equation space-like foliation
  • Level: Graduate
  • Thread starter WannabeNewton
7 replies · 4K views · last reply
Hello! This is regarding problem 10.4 in Wald. Let ##(M,g_{ab})## be a space-time, ##\Sigma_{t}## be a one parameter family of space-like hypersurfaces foliating the space-time, and ##n^{a}## the unit normal vector field to the space-like hypersurfaces. We have the induced metric ##h_{ab} = g_{ab} + n_a n_b## on each ##\Sigma##, which acts as a projection operator, taking space-time tensor fields to tensor fields over ##\Sigma##. We also have an induced derivative operator ##D_a## associated with ##h_{ab}## which is defined by ##D_{e}T^{a_1...a_n}{}{}{}_{b_{1}...b_m} = h_{e}{}{}^{f}h^{a_1}{}{}_{c_1}...h^{a_n}{}{}_{c_n}h_{b_1}{}{}^{d_1}...h_{b_m}{}{}^{d_m}\nabla_{f}T^{c_1...c_n}{}{}{}_{d_{1}...d_m}## where ##\nabla_{a}## is the regular space-time derivative operator. Finally, define the extrinsic curvature ##K_{ab}## of ##\Sigma## with respect to ##n^{a}## by ##K_{ab} = h_{a}{}{}^{c}\nabla_{c}n_{b}##.
So problem 10.4 is to show that the Gauss-Codacci equation ##D_{a}K^{a}{}{}_{b} - D_{b}K^{a}{}{}_{a} = R_{cd}n^{d}h^{c}{}{}_{b}## holds. I keep getting stuck near the end of the calculation and it's starting to get quite frustrating :frown:
##D_{a}K^{a}{}{}_{b} = h_{a}{}{}^{c}h^{a}{}{}_{d}h_{b}{}{}^{e}\nabla_{c}K^{d}{}{}_{e} = h^{cf}h_{b}{}{}^{e}\nabla_{c}\nabla_{f}n_{e} + h^{c}{}{}_{d}h_{b}{}{}^{e}\nabla_{c}h^{df}\nabla_{f}n_{e}## and similarly ##D_{b}K^{a}{}{}_{a} = h_{b}{}{}^{c}h^{a}{}{}_{d}h_{a}{}{}^{e}\nabla_{c}K^{d}{}{}_{e} = h_{b}{}{}^{c}h^{ef}\nabla_{c}\nabla_{f}n_{e} + h_{b}{}{}^{c}h^{e}{}{}_{d}\nabla_{c}h^{df}\nabla_{f}n_{e}##. Now, ##h^{e}{}{}_{d}\nabla_{c}h^{df} = h^{e}{}{}_{d}n^{f}\nabla_{c}n^{d}## and ## h^{c}{}{}_{d}\nabla_{c}h^{df} = h^{c}{}{}_{d}n^{f}\nabla_{c}n^{d}## because ##\nabla_{a}g^{bc} = h_{ab}n^{b} = 0##.
Therefore, ##D_{a}K^{a}{}{}_{b} - D_{b}K^{a}{}{}_{a} = h^{cf}h_{b}{}{}^{e}(\nabla_{c}\nabla_{f}n_{e} - \nabla_{e}\nabla_{f}n_{c}) + h^{c}{}{}_{d}h_{b}{}{}^{e}n^{f}(\nabla_{f}n_{e}\nabla_{c}n^{d} - \nabla_{f}n_{c}\nabla_{e}n^d)##.
Using the Leibniz rule for ##\nabla_{a}## you can also put the equation in the form ##D_{a}K^{a}{}{}_{b} - D_{b}K^{a}{}{}_{a} = h^{cf}h_{b}{}{}^{e}(\nabla_{c}\nabla_{f}n_{e} - \nabla_{e}\nabla_{f}n_{c}) + h^{c}{}{}_{d}h_{b}{}{}^{e}n^{f}\nabla_{f}(n_{e}\nabla_{c}n^{d} - n_{c}\nabla_{e}n^{d})##.
As you can see, the final equation is antisymmetrized over ##e## and ##c## which, at face value, seems to be an issue because we want antisymmetrization over the indices on the space-time derivatives in order to get the Ricci tensor. I've tried everything but I can't seem to find a way to simplify the above equation any further. I tried using the fact that ##n^{a}## is hypersurface orthogonal, i.e. ##n_{[a}\nabla_{b}n_{c]} = 0##, in as many different ways as possible but nothing seemed to work. Plugging in ##h^{cf} = g^{cf} + n^{c}n^{f}## only seemed to make things worse so there must be a way to simplify it before having to plug in for ##h^{cf}##. All of the aforementioned issues apply to both forms of the equation written above. Does anyone have any hints / suggestions as to how I can show the desired result? Thank you very much in advance.
[Hm, I've always seen it spelled Codazzi...]
You've started with the derivative expressions on the LHS and tried to come up with the Ricci tensor. My suggestion is to go the other way. Easier, I think, to start with the Riemann identity
∇[μ∇ν] nσ = nλRλσμν
Contract both sides with something, hκν gσμ I guess, to get the RHS you want, and then try to manipulate the derivatives on the LHS into the desired expression.
You're most likely right; I just wrote it the way Wald spelled it but I have no knowledge of the actual spelling. Sorry about that.
∇[μ∇ν] nσ = nλRλσμν
Ok cool, I didn't even think of doing it the way you suggested so let me try that and see how it goes. Funny enough, Wald's "hint" for the problem is "(Hint: Evaluate the left-hand side...)" lol (page 268 problem 4 if you're interested). Thank you very much Bill, I'll try what you said and hopefully it works out better!
Well Bill, your method worked. It ended up giving the solution in just a few lines. I had thought that only math textbooks contained hints which took you in the longest and most difficult path to a solution but it looks like Wald has written a physics textbook that does the same :smile: .
Here's how it worked out: using ##\nabla_b n_{c} = K_{bc} - n_{b}n^{d}\nabla_{d}n_{c}## we find that [tex]h^{e}{}{}_{a}h^{f}{}{}_{b}h^{g}{}{}_{c}n^{d}R_{efgd} = 2h^{e}{}{}_{a}h^{f}{}{}_{b}h^{g}{}{}_{c}\nabla_{[e}\nabla_{f]}n_{g} \\<br /> = D_{a}K_{bc} - D_{b}K_{ac} - h^{e}{}{}_{a}h^{f}{}{}_{b}h^{g}{}{}_{c}n^{d}\nabla_{d}n_{g}\nabla_{e}n_{f} + h^{e}{}{}_{a}h^{f}{}{}_{b}h^{g}{}{}_{c}n^{d}\nabla_{d}n_{g}\nabla_{f}n_{e} \\ = D_{a}K_{bc} - D_{b}K_{ac} + h^{e}{}{}_{a}h^{g}{}{}_{c}n^{d}\nabla_{d}n_{g}K_{be} - h^{f}{}{}_{b}h^{g}{}{}_{c}n^{d}\nabla_{d}n_{g}K_{af} \\ = D_{a}K_{bc} - D_{b}K_{ac} +h^{g}{}{}_{c}n^{d}\nabla_{d}n_{g}K_{ba} - h^{g}{}{}_{c}n^{d}\nabla_{d}n_{g}K_{ab} \\ =D_{a}K_{bc} - D_{b}K_{ac}[/tex]
where, in the last step, I used the fact that ##K_{ab}n^{b} = 0## and that ##K_{[ab]} = 0##.
Thus, ##D_{a}K^{a}{}{} _{b}- D_{b}K^{a}{}{}_{a} = h^{f}{}{}_{b}h^{ge}n^{d}R_{efgd} = h^{f}{}{}_{b}n^{d}R_{fd}## after using the fact that ## n^{e}n^{g}n^{d}R_{efgd} = n^{e}n^{(g}n^{d)}R_{ef[gd]} = 0##.
Thank you again Bill!
Hey WNB sorry to bring up an old thread but above you said
[tex]2h^{e}{}{}_{a}h^{f}{}{}_{b}h^{g}{}{}_{c}\nabla_{[e}\nabla_{f]}n_{g} \\<br /> = D_{a}K_{bc} - D_{b}K_{ac} - h^{e}{}{}_{a}h^{f}{}{}_{b}h^{g}{}{}_{c}n^{d}\nabla_{d}n_{g}\nabla_{e}n_{f} + h^{e}{}{}_{a}h^{f}{}{}_{b}h^{g}{}{}_{c}n^{d}\nabla_{d}n_{g}\nabla_{f}n_{e} \\[/tex]
aren't you missing the terms [tex]h^{e}{}{}_{a}h^{f}{}{}_{b}h^{g}{}{}_{c}n^{d}[n_f\nabla _e\nabla _dn_g-n_e\nabla _f\nabla _dn_g][/tex]. one of the terms comes from eg. [tex]\nabla _e\nabla _fn_g=\nabla _e(K_{fg}-n_fn^d\nabla _dn_g)[/tex] Then ignoring the curvature term and the derivative of [itex]n^d[/itex] we have [tex]\nabla _e(n_f\nabla _dn_g)=\nabla _en_f\nabla _dn_g+n_f\nabla _e\nabla_dn_g[/tex]. Or does this disappear for a reason I haven't seen?
tommyj said:
...aren't you missing the terms [tex]h^{e}{}{}_{a}h^{f}{}{}_{b}h^{g}{}{}_{c}n^{d}[n_f\nabla _e\nabla _dn_g-n_e\nabla _f\nabla _dn_g][/tex]...
But anyways, these terms get combined with the ##\nabla_{a}K_{bc}## terms to form the ##D_a K_{bc}## terms. Try it out.
P.S. I'm still working on that other problem with Maxwell's equations.
Holy ish. I was just writing the thing out on here as I was still stuck, and I was just expanding things to make sure i copied it down correctyl when i realized I mixed up some letters. I see now that when you expand out all the others terms with the h's they all go to zero. Friday morning wasted but got there in the end, thanks!
Haha I know that feeling. That's what happened to me with problem 7.5.
