Gauss' Law for nonconducting sphere
The discussion focuses on applying Gauss' Law to determine the electric field around a nonconducting sphere with a hollow cavity. The sphere has a uniform charge density (ρ) and a radius of R=15, while the cavity has a radius of a=5 and is offset by a distance b=6. Participants clarify that the electric field is influenced by the symmetry of the charge distribution, particularly along the y and z axes, which leads to cancellation of the electric field in those directions. The key takeaway is that superposition of electric fields from symmetric charge distributions simplifies the analysis.
  • Understanding of Gauss' Law and its mathematical formulation
  • Familiarity with electric field concepts and charge distributions
  • Knowledge of symmetry in physics, particularly in electrostatics
  • Ability to perform vector analysis in three-dimensional space
  • Study the application of Gauss' Law in non-symmetric charge distributions
  • Learn about electric field superposition and its implications in electrostatics
  • Explore the concept of electric flux and its calculation through various surfaces
  • Investigate the effects of charge distribution symmetry on electric fields in different geometries
Students and educators in physics, particularly those studying electrostatics, as well as professionals in electrical engineering and applied physics who require a deeper understanding of electric fields and charge distributions.
armolinasf
There is a nonconducting solid sphere with uniform charge density rho and radius R=15 but it has a smaller hollow spherical cavity of radius a = 5, it is not centered: the distance between the center of the larger sphere is a distance b = 6
I'm trying to find the electric field at a point (1) a/2 to the left of the cavity's center and (2) a distance a/2 above the cavity's center.
I figured that since gauss' law states that E=q(enc)/(eps*A), the electric field would be zero in all three vector directions since there is no charge enclosed in the region, however there is an electric field in the i direction for both (1) and (2) - according to my solutions guide - and I can't see why since there seems to be no charge enclosed.
Thanks for the help.
the charge distribution outside the Gaussian surface is not symmetrical, so you cannot use that argument. Its going to be slightly more difficult than that. What principles do you think you can use to make this problem easier?
So for my argument to work the outer charge distribution has to be symmetrical? Why is that exactly?
But taking that into consideration I can see that it is symmetrical with respect to the y and z axes which would explain why the electric field has an x component only.
I know that there is a superposition of forces involved but I'm having difficulty seeing exactly how/where it applies
If you use a Gaussian surface inside the cavity, and don't use symmetry arguments, then what exactly does Gauss' law tell you?
Yes, superposition is the key to making this problem easier. you need to think outside the box a little bit, but once you realize the trick, you won't forget it again :)
Gauss' law relates flux and charge and flux measures the electric field over a given area. Symmetry arguments are used to define the area through which the electric field "flows" correct? so if there is not enough symmetry to define a solvable integral then it doesn't allow you to define flux and so gauss' law doesn't tell you anything.
Am I on the right track there?
As far as the problem goes...
Since there is a symmetry about the y and z axis the flux entering and exiting must be equal and hence the electric field in those directions must cancel and equal zero.
I tried finding the field of a sphere that included the point I was interested in using E = (rho*b)/(3 * eps) and got the correct answer, but I still don't feel like I understand this problem...
Yes, pretty much. Gauss' law for charge distributions without symmetry still does tell us something, but it doesn't give us a simple integral.
hmm. I'm not sure what you mean here. Do you mean that if we imagine a small Gaussian cube inside the cavity, then the flux over the faces perpendicular to the x-axis will cancel due to symmetry? But the question asks us to calculate the electric field at a point which is not on the x axis. So I am not convinced by this argument.
You used E = (rho*b)/(3 * eps) to get the answer? But that is the answer already (without the direction).
A hint: In this question, we want a symmetric charge distribution. Or at least a superposition of two symmetric charge distributions, right? So for this problem, we could view it either as one non-symmetric charge distribution, or...
  • · Replies 22 ·
