Gaussian center not average value?
The discussion centers on the misunderstanding of the average value of a Gaussian function, specifically when centered at x=2. The user initially expected the average of the Gaussian P2(x)=e^(-(x-2)^2) to be 2, but calculated it as 2 times the square root of pi. The correct probability density function (PDF) for a normal distribution is provided, emphasizing that the average value is dependent on the normalization of the function. The average x can still be computed for non-normalized functions, but requires adjustment for the lack of normalization.
  • Understanding of Gaussian functions and their properties
  • Knowledge of probability density functions (PDFs)
  • Familiarity with integrals and their applications in statistics
  • Basic concepts of normalization in probability theory
  • Study the properties of Gaussian distributions, focusing on mean and variance
  • Learn about normalization of probability density functions
  • Explore the concept of expected value in statistics
  • Investigate the implications of non-normalized functions in statistical analysis
Statisticians, data scientists, and students in mathematics or physics who are dealing with Gaussian distributions and their applications in probability and statistics.
DocZaius
I put this under statistics because of your knowledge of the Gaussian.
I have run into an elementary problem. I was considering what the average value, <x>, is for a Gaussian with an x offset, and got results which don't make sense to me.
First, it is obvious that for P1(x)=e^(-(x^2)) the average is 0. The integral of x*P1(x) from -inf to inf is zero.
So I decided to center the Gaussian at x=2: P2(x)=e^(-(x-2)^2). I was expecting an average of 2, but instead got 2 times the square root of pi! The integral of x*P2(x) from -inf to inf is 2*sqrt(pi)...
I thought, well perhaps this has to do with the infinities lying on either side, and the plus side starting at higher values than the minus side...So I decided to see the average for the Gaussian centered at 2 from x=0 to x=4. Surely that must be 2, it is clearly symmetric in that interval. Turns out that x*P2(x) from 0 to 4 is (according to Wolfram Alpha) still 2*sqrt(pi).
Can anyone explain why this last Gaussian's average x isn't 2?
Thanks.
You have the wrong PDF. The PDF for a normal distribution with mean \mu and standard deviation \sigma is given by
p(x) = \frac 1 {\sigma \sqrt{2\pi}} \exp\left(-\frac 1 2 \left(\frac {x-\mu}{\sigma}\right)^2\right)
A couple of examples for a mean of 2:
1. \sigma=1:
p(x) = \frac 1 {\sqrt{2\pi}} \exp\left(-\frac 1 2 (x-2)^2\right)
1. \sigma=1/\surd 2:
p(x) = \frac 1 {\sqrt{\pi}} \exp\left(-(x-2)^2\right)
I am attempting to look at the average x for the function I brought up. (It's from a quantum textbook). I understand it is different from the one you wrote. Can you explain my problems with the function I wrote?
My problem is that the intuitive idea that a Gaussian centered at x=a would have an average x of a is clearly wrong, but in the case where I look at a symmetric interval around it, I don't understand how that can be the case.
Your function is not a PDF. Calculate \int_{-\infty}^{\infty} p(x)\,dx for your function. It won't be one.
Is the concept of "average x" only applicable to functions whose integrals at infinity are 1? I don't see why that must be the case.
I am aware that my function does not count as a probability function since it doesn't integrate to 1 at infinity, but it seems to me that one could still devise an "average x" from it by weighing all its x's with f(x) inside the integrand.
If your function f(x) is not normalized (i.e., \int_D f(x)\,dx \ne 1 where the integral is over some applicable domain such as -∞ to +∞) you can still compute an average, but you will need to account for the fact that the function is not normalized. In your case,
\bar x \equiv \frac{\int_{-\infty}^{\infty} xf(x)\,dx}{\int_{-\infty}^{\infty} f(x)\,dx}
Thanks!
  • · Replies 18 ·
  • · Replies 25 ·
14K
