Gearbox with single input, double output (at different RPM)
  • Thread starter Thread starter kunalv
    Gears
10 replies · 4K views · last reply
kunalv
TL;DR
Designed & machined a gearbox with single input and double outputs at 90 degree to each other. Help needed with reducing the size
Hello,
For a trial project (can't give details on what the project is at the moment sorry!), I have designed a gearbox that takes input from a DC gearmotor at 150RPM, and provides 2 outputs as per the following:
1. 32rpm in the same axis as the input. This drives the pulleys and the belt
2. 460rpm at right angle (vertically down). This drives an impeller in the water
Please see the layout as per this
Hand-drawn gearbox layout sketch on lined paper showing a 112T spur gear, 88T helical gear, 24T spur gear, 25T helical gear, two bevel gears, a belt pulley, bearings, a gearmotor and a vertical impeller shaft.
The gearbox looks like this -
I have the following issues:
1. I have used 0.75 module gears, although I feel I can reduce the module and go for smaller gears. This will reduce the size of the gearbox & weight of the machine. Pls comment
2. Now the input gearmotor is connected to the 24Teeth Spur Gear in the middle of the gearbox. Can I re-design it to have the input gearmotor mounted near the top? See image below..
Hand-drawn gear train sketch in blue ink: a 75T spur gear fed by a 50rpm input, a 25T gear on a shared shaft meshing with a 24T gear, a bevel gear pair turning the drive vertically down to a 450rpm output.
The input gearmotor will be the 50RPM one at the top driving the 75 Teeth Spur gear in this layout. I am going to use PWM to vary the speed of both outputs.
Comments/Suggestions/Corrections are welcome please. Thank you!
Are speeds important here?
What ranges are acceptable?
Replace the 150 RPM, 75T helical cut spur gear on the input shaft, with a 46T bevel gear. That 46T bevel, drives a 15 tooth bevel gear on the vertical output shaft, at 460 RPM.
Faster DC gear-motors are smaller and cheaper.
Mount a 460 RPM gear-motor at the top, driving the vertical output shaft directly. Reduce the main shaft through a bevel bear to drive the 32 RPM belt output.
Sorry for the delay in my response, been busy with a lot of things and had to take some trials with the existing gearbox.
Speeds are important. Ranges acceptable are 40-60RPM and 400-500RPM.
In my illustration, the input gearmotor of 50RPM is actually connected to the top gear i.e 75T helical which drives the 25T helical gear @150RPM. Another 75T Helical is mounted on this shaft which then drives another 25T helical @450RPM. Here the Bevel gears of 1:1 ratio are proposed to take the 450RPM drive to the Impeller on the vertical shaft.
Won't a 46T bevel driving a 15T bevel reduce the torque at the 15T bevel shaft?
Not sure I understood this. Please help me out!
Yes, it will reduce torque, but it will increase RPM, so power is the same.
I try to avoid situations where a gear train increases RPM, (and lube problems).
A higher RPM motor is a better investment.
Why gear down, then gear up again, when a direct drive, multi-pole AC motor, near 450 RPM, is available?
Yes but how will a horizontally mounted 450RPM gearmotor be able to transmit that 450 RPM vertically downwards (at right angle using bevel) AND give me 50 RPM in the same axis as the gearmotor? I thought about this but I am unable to think of a geartrain that will enable this.
For eg. I will connect a 1:1 bevel gear set to transmit the 450RPM at 90 degrees. But how will I get the 50RPM drive ?
I could connect a 1:9 spur/helical set to get the output, but I am afraid the driven gear here will be too large.
The motor would be mounted, with axis vertical, where the top of the gearbox is in your original design. A vertical shaft directly drives the impeller below.
A bevel gear on that shaft drives the 50 RPM output shaft to the belt. That is a 9:1 ratio, so is probably best done with a two stage reduction.
An alternative would be a worm gear, but that would be difficult at 9:1.
A vertical axis 900 RPM motor, could drive an 18:1 worm and wheel, that drives the 90° belt output shaft, without the use of bevel gears. The impeller would then need a 2:1 speed reduction.
Smallest issue with this.. if I mount the motor vertically (shaft pointing downwards), this will increase the total height of my gearbox (and machine). the input motor has to be mounted horizontally :headbang:
What i meant by 'top' is actually where the topmost shaft is located. there are 3 shaft, currently in the video you can see the gearmotor in the 2nd shaft (the one in the middle). I was wondering if the gearmotor can be connected to the topmost shaft. Sorry if I was unable to make myself clear
Last 30 minutes, I have been trying to use ChatGPT to help me with the geartrain and I guess this isn't as easy as I had thought initially as even the damn AI is struggling haha
You want a different solution, but you are trapped in a local minimum. You have to escape the trap, which is why I make silly suggestions.
ChatGPT will not help you design or optimise a gearbox. Experience, in dismantling broken gearboxes, is an essential prerequisite. Learn from others mistakes.
Unfortunately, a worm has a high reduction ratio, but it does have 90° shafts.
How many of these gearboxes do you intend to manufacture?
Line drawing of a V belt drive: a V belt pulley connected by a V belt to an electric motor on the right, with a gear box or machine below the pulley on the left.
That is an irrational constraint on the solution.
Your gearbox is quite tall, and houses much expensive complexity. If you throw out most of that complexity, the gearbox height will collapse, and there will be more than sufficient space for the motor, in the place of the old gearbox.
Why must you have so many gears? Why not just use two gear motors?
Is there some reason why the impeller must be mechanically locked to the belt speed?
I ask again. How many of these gearboxes do you intend to manufacture?
