Why Does Telluric Acid Not Follow the Expected Pattern?
  • Thread starter Thread starter END
    Acid General
The discussion revolves around the chemical properties and structural characteristics of Telluric Acid, specifically why it does not conform to the expected formulaic patterns observed in other acids derived from polyatomic ions in the same group. Participants explore the implications of hydration and the nature of chemical bonding in relation to Telluric Acid.
  • One participant notes that the expected formula for Telluric Acid would be H2TeO4, similar to Selenic Acid, but points out that it is represented as Te(OH)6 instead.
  • Another participant references a source indicating that Tellurium trioxide can lead to various hydration products, suggesting that H2TeO4 can be viewed as a hydrated form of Telluric Acid.
  • A question is raised about whether H2TeO4·2H2O should be classified as a hydrate due to the inclusion of water molecules.
  • One participant challenges the simplification of chemical formulas, arguing that hydrates are often distinct compounds rather than merely variations of a single compound, using sodium bisulfite as an example.
  • Another participant discusses the bonding preferences of larger central atoms, suggesting that the structure of Te(OH)6 reflects a different bonding arrangement compared to metatelluric acids.
Participants express differing views on the classification and structural representation of Telluric Acid and its hydrates. There is no consensus on the implications of hydration or the nature of the chemical bonding involved.
Participants highlight the complexity of chemical structures and bonding, indicating that assumptions about hydration and structural similarities may not hold universally across different compounds.
END
According to Wikipedia, the proper chemical formula for Telluric Acid is Te(OH)_6.
From what I've learned in chemistry thus far, acids made from polyatomic ions within the same group follow a similar pattern. For example, Selenic Acid H_2SeO_4 is analogous to Sulphuric acid H_2SO_4. If this is the case, why is it that Telluric Acid differs from this pattern? I would expect its chemical formula to be H_2TeO_4, but apparently this represents Metatelluric acid which is the analogue of sulfuric acid and "is unknown." (Wikipedia)
Why is this the case?
Thank you!
Chemistry news on Phys.org
from http://tellurium.atomistry.com/telluric_acids.html
Tellurium trioxide gives rise to several hydration products which can all be regarded as telluric acids, but which are more conveniently considered as products of the further hydration of telluric acid, H2TeO4, the compound H2TeO4.2H2O (possibly an "ortho-" telluric acid, H6TeO6) being the most stable.
H2TeO4.2H2O can be written as Te(OH)6 making the water of hydration look like hydroxyl groups.
Thanks, Jim.
So would ##H_2TeO_4\cdot2H_2O## then be considered a hydrate due to the presence of water molecules within it?
In addition, how are we supposed to know that telluric acid is a hydrate? (i.e., that it has a ##nH_2O##)
I feel like you are trying to describe reality with simplified formulas, which won't work.
Hydrates often have well defined water molecules in the crystal lattice (and I believe that's the way you are trying to picture the telluric acid). But that's not the case here. We call observed substances "hydrates" because they differ by a water molecule, but they are actually different (although related) compounds. This is quite common - similar thing happens for example with sodium bisulfite and sodium metabisulfite.
In Group IV, carbonic acid is H_2CO_3, but silicic acid is H_4SiO_4 - metasilicic acid H_2SiO_3 is polymeric.
In Group V, nitric acid is HNO_3, but phosphoric acid is H_3PO_4 - metaphosphoric acid HPO_3 is polymeric.
The reason both cases being that the bigger central atom prefers bonding to more oxygens.
Same reasoning applies to tellurium and iodine - Te(OH)_6 has Te bonded to 6 equal oxygens, whereas metatelluric acids are polymeric structures where some oxygens are bonded to two tellurium atoms.
  • · Replies 19 ·
9K
