General Solution of a Differential Equation with Given Solution y=e^x
20 replies · 3K views · last reply
Thumper88
Consider the differential equation:
[tex](x^2 + x) \frac {d^2y} {dx^2} - (x^2 - 2) \frac {dy} {dx} - (x + 2)y = 0[/tex]
Given that [tex]y = e^x[/tex] is a solution, what is the general solution of this equation?
I don't know where to start...please help :(
Since you are already given one solution, this would seem to suggest using the method of reduction of order...so assume an ansatz [itex]y_2(x)=v(x)y_1(x)=v(x)e^x[/itex] where [itex]v(x)[/itex] is an unkown function of [itex]x[/itex]...If you use the chain rule to find the first and second derivatives of [itex]y_2(x)[/itex] (they will involve [itex]v(x)[/itex] and its derivatives) and substitute them into your original DE, you can obtain a differential equation for [itex]v(x)[/itex] which should be easier to solve. Then just solve that DE and discard any solutions that make [itex]y_2(x)[/itex] linearly dependent on [itex]y_1(x)[/itex].
So I have the derivatives (u = v(x)):
[tex]y_2 = u y_1 = ue^x[/tex]
[tex]y_2' = uy_1' + y_1u' = ue^x + e^xu'[/tex]
[tex]y_2'' = uy_1'' + 2u'y_1' + y_1u'' = ue^x + 2u'e^x + e^xu''[/tex]
Putting these into the original DE...
[tex](x^2 + x)(ue^x + 2u'e^x + e^xu'') - (x^2 - 2)(ue^x + e^xu') - (x + 2)(ue^x) = 0[/tex]
Not sure where to go with it next...my teacher gave a hint that there will be integration of parts.
ok, well...to further things a little...
I distributed everything out and added like terms, leading to:
[tex]3u'x^2e^x + 2u'xe^x - 2u'e^x + u''x^2e^x + u''xe^x = 0[/tex]
Using the variable transformation, [tex]w = u'[/tex] and [tex]w' = u''[/tex]
[tex]3wx^2e^x + 2wxe^x - 2we^x + w'x^2e^x + w'xe^x = 0[/tex]
Still looks like a mess to me...?
yea, I'm at a halt here..really not sure what to do next.
You might want to check your algebra again; I get:
[tex]u'x^2e^x + 2u'xe^x + 2u'e^x + u''x^2e^x + u''xe^x = 0[/tex]
[tex]\Rightarrow e^x[u''(x^2+x) +u'(x^2+2x+2)] = 0[/tex]
[tex]\Rightarrow u''(x^2+x) +u'(x^2+2x+2)=0[/tex]
[tex]\Rightarrow w'(x^2+x) + w(x^2+2x+2)=0[/tex]
which, when you write [tex]w'=\frac{dw}{dx}[/tex], looks like a separable DE for w to me...you know how to deal with those don't you? :wink:
I redid the algebra by hand and got exactly what you got.
Separating the variables
[tex]-\frac {1}{w} dw = \frac {(x^2+2x+2)}{(x^2+x)}dx[/tex]
integrating both sides and solving for w I get:
[tex]w = \frac {((x+1) * e^-x)}{x^2} dx[/tex]
So now u = integral of w dx
I assume you mean: [tex]w=\frac{(x+1)e^{-x}}{x^2}[/tex]?...if so, then good...now solve for [itex]u(x)[/itex] using your definition of w(x): [itex]w(x)=u'(x)[/itex]...then finally solve for [itex]y_2(x)=u(x)e^x[/itex]...what do you get?
yea...i was editing the equation...still getting used to the code
[tex]u(x) = -4 e^{-x}[/tex]
so [tex]y_2(x) = -4 e^{-x} * e^x = -4[/tex]
correct?
so would the general solution just be:
[tex]y(x) = C_1 e^x + C_2[/tex]
Where -4 is included in the constant [tex]C_2[/tex].
correct?
nope, I get [tex]u(x) = \frac{e^{-x}}{x}[/tex]
give or take a constant multiplier.
...why don't you show me your work for integrate wdx?
[tex]u(x) = \int w dx[/tex]
[tex]u(x) = \int \frac {(x+1) e^-x}{x^2} dx = \int \frac {e^{-x}}{x} dx + \int \frac {e^{-x}}{x^2} dx[/tex]
[tex]\int u dv = uv - \int v du[/tex]
[tex]\int \frac {e^{-x}}{x} dx[/tex]
[tex]u = \frac {1}{x}[/tex] [tex]du = -\frac {1}{x^2}dx[/tex]
[tex]dv = e^{-x} dx[/tex] [tex]v = -e^{-x}[/tex]
[tex]\int u v' = \frac {1}{x}(-e^{-x}) - \int -e^{-x} * - \frac {1}{x^2} dx = -2e^{-x}[/tex]
Used same method for [tex]\int \frac e^{-x}}{x^2}dx[/tex] with different u du values, and got same answer, adding together got the [tex]-4e^{-x}[/tex]
arg...made some typos on my calculator...not getting those answers anymore.
Do you mean:
[tex]\int \frac {e^{-x}}{x} dx=\int uv'=\frac{-e^{-x}}{x}- \int \frac{e^{-x}}{x^2}dx[/tex]
...if so, there is no need to evaluate the integral on the right, since you are adding this to your other term:
[tex]\Rightarrow u(x) = \int \frac {e^{-x}}{x} dx + \int \frac {e^{-x}}{x^2} dx=\left(\frac{-e^{-x}}{x}- \int \frac{e^{-x}}{x^2}dx \right)+ \int \frac {e^{-x}}{x^2} dx=\frac{-e^{-x}}{x}[/tex]
...I'm having a hard time seeing where your 4e^-x came from, but this is the way you should have done it.
the -4e^-x came from using a minus sign instead of the negative key...
oh, lol...that's why I don't like using calculators :wink:
been a while since I've done any integration by parts...
ok...so with
[tex]u(x) = - \frac {e^{-x}}{x}[/tex]
[tex]y_2(x) = - \frac {e^{-x}}{x} * e^x = -\frac {1}{x}[/tex]
Sooo...
[tex]y(x) = C_1 e^x + C_2 (-x^{-1})[/tex]
that is correct, right? just checking, thanks for all the help!
Looks good to me :smile:
...although your prof might prefer that you make sure y1 and y2 are linearly independent by checking the Wronskian.
