Building a Bike Generator: How to Increase Electricity Output?
  • Thread starter Thread starter Meseria
    Generator
Building a bike generator involves using a copper coil and magnets, but it's crucial to understand that this setup is not a simple DC generator; it functions as a permanent magnet synchronous machine requiring rectification for DC output. Increasing the length of the copper coil may not directly correlate to increased electricity output, as voltage depends on speed, while torque and power are influenced by both speed and current. Attempting such a project without adequate knowledge can be dangerous, and commercially available generators are typically more reliable and efficient. For practical purposes, using a salvaged alternator may provide better results than a DIY generator. Proper construction and maintenance are essential for longevity, making commercial options more appealing for most users.
Meseria
Hey,
I am looking to build a generator that goes on a bike stand so when i ride my bike on the stand it will produce electricity.
Im planning on having a copper coil with magnets inside spinning. This is a dc generator right? Well, anyways... i know if i spin the magnets faster it will produce more electricity. Can i increase the amount of copper in the coil in order to produce more electricity? Like if my coil is 500 ft long and i have 2 1" x 3" x 1" rectangle magnets spinning at 100 rpm i should produce x electricity. If i spin faster will i get a higher voltage or amperage? How much more electricity can i produce if my coil is 1000 ft long and i use the same magnets and same 100 rpm?
I would think that its a function of the inductance of the coils, which isn't necessarily a simple equation as a function of coils and length. A quick google gives for a circular loop:
r\cdot \left(ln \frac{8r}{a} - 2 + Y \right)
Where r is the loop radius, a is the wire radius, and I have no idea what Y is.
First: Don't ever attempt a project like this that could potential produce fatal voltages if you don't know what you are doing. You obviously do not have the skills or knowledge to attempt a project like this so I suggest you just go buy something that is commercially available.
Second: What you described is not a DC generator, but a permanent magnet synchronous machine. In order to get DC you will need to rectify the output.
Third: You can't model a generators power output with speed alone. Voltage is a function of speed, torque a function of current, and power a function of both. In the case of double-fed machines its also a function of the input electrical work.
What do you plan to do with this power anyway? Charge a car battery?
its like a simple generator but larger. I had made one before in class a long time ago where we wound some copper around a plastic bottle, then spun a magnet inside and had the two ends of the wire connected to a small light bulb and when you spun the magnet it would light up the bulb. Its called induction right? Well all i want to do is build a larger one that can charge batteries, make my tv turn on and other stuff like that.
Unless you have a better reason than you have described, save some time and money and buy a commercially available unit. If this is a "relearning exercise" for instruction go for it!,.
Even if you were able to build a generator which produced the voltage and current you require, it would be a miracle if it lasted a week. Without close tolerances and proper bearings it will wear out fast. A used alternator from a junkyard would be a far better source than anything you can make. Commercially available gens and alts are the result of tens of thousands of designs, manufacturing techniques, wire coatings, diode size tests,etc,fan size for cooling,etc,etc.
What mathematics software should engineering students use? Is it correct that much of the engineering industry relies on MATLAB, making it the tool many graduates will encounter in professional settings? How does SageMath compare? It is a free package that supports both numerical and symbolic computation and can be installed on various platforms. Could it become more widely used because it is freely available? I am an academic who has taught engineering mathematics, and taught the...
12K
