Geometric and Physical Interpretation of Diagonalization
Simultaneous diagonalization of matrices in quantum mechanics indicates that the corresponding Hermitian operators are compatible, meaning they commute and can be measured simultaneously without uncertainty. This compatibility allows for a common eigenvector basis, where states have definite values for both observables represented by the matrices. While it is true that there is no uncertainty relation between the observables, they are generally independent rather than one being a function of the other. The discussion also touches on the importance of eigenvectors in matrix analysis, noting that while a non-unitary matrix can still diagonalize an operator, using normalized eigenvectors is often preferred for clarity. Understanding these concepts is crucial for grasping the foundational principles of quantum mechanics.
hliu8
I am a second year student in quantum mechanics. I heard in lecture that simultaneous diagonalization of matrices is important in quantum mechanics. I would like to know why is it significant when two matrices can be simultaneous diagonalized, and what is the geometric and physical interpretation of simultaneous diagonalization of matrices in quantum mechanics and in physics in general.
Thank you for everyone's help.
The physical interpretation of this result is that if you can simultaneously diagonalise two matrices then the corresponding operators (if the matrices in question are Hermitian) are compatiable. This means that they commute since it is possible to find a commom eigenvector basis for both of the matrices. Ultimately, this means that one can simultaneously measure both of those observables on the quantum system of interest. Thus, in this case there should be no uncertainty relation between the operators and one can be expressed as a function of the other.
Likes Matiasss
To put it a little more physically, (hermitian) matrices represent observable physical quantities. If you have a state which, when acted upon by a matrix, returns itself multiplied by a constant, that state has a definite value of the observable associated with the matrix. A compete set of such states will diagonalize the matrix.
If a common set of states can diagonalize two matrices simultaneously, it means that those states have definite values of both observables. So, the statement that there is no uncertainty relation between the observables is quite correct. However, it is not the case that one can be expressed as a function of the other. In general, the observables are independent (like the energy and angular momentum of the electron in a hydrogen atom).
Likes Matiasss
It's often useful, when studying a matrix, to look at the eigenvectors. Even better if you can choose a basis whose vectors are all eigenvectors.
So, if two matrices can be simultaneously diagonalized...
while diagonalizing an operator A with a matrix S (formed from eigenvectors of A), does S need to be unitary (i.e., whether I have to form it with the NORMALIZED eigenvectors)? Even if S is not unitary, A gets diagonalized.
I am slowly going through the book 'What Is a Quantum Field Theory?' by Michel Talagrand. I came across the following quote: One does not" prove” the basic principles of Quantum Mechanics. The ultimate test for a model is the agreement of its predictions with experiments. Although it may seem trite, it does fit in with my modelling view of QM. The more I think about it, the more I believe it could be saying something quite profound. For example, precisely what is the justification of...
  • · Replies 52 ·
  • · Replies 376 ·
22K
  • · Replies 292 ·
12K
  • · Replies 179 ·
15K
  • · Replies 37 ·
