Geometrical Proof: Prove Intersection Point on Line CM
  • Thread starter Thread starter franceboy
    Geometrical Proof
The discussion centers on proving that the intersection point of two lines formed by angles ∠ACM at A and ∠MCB at B lies on line CM in triangle ABC, with M as the midpoint of AB. Participants explore using Ceva's Theorem but express challenges in applying it effectively. Suggestions include leveraging the symmetry of the triangle and establishing relationships between segments BX, XC, CY, and YA. A proposed method involves marking the intersection points and demonstrating that the distances from M to these points are equal, leading to the conclusion that the intersection point is indeed on line CM. The conversation highlights the importance of geometric properties and theorems in solving the problem.
franceboy
Consider an triangle ABC with M as the middle point of the side AB.
On the straight line through AB you put the angle ∠ ACM at A and the angle ∠ MCB at B. Now you have two new lines. The new lines should be on the same side of AB as C.
Proof that the intersection point of the two new lines is located on the line through CM.
I wanted to use Ceva`s Theorem but I could not use it :(
I hope you can give me some advice.
You've generated some similar triangles there which should help, if you work out the scaling. Note that |AM| = |BM|
I don't understand. From your explanation you would have two new angles. In my drawing below I have labelled ∠ ACM as a and ∠ MCB as b.
What is Ceva's Theorem?
Hi Mark, this is the construction as I understand it:
Sorry thai i did not add a sketch but a GeoGebra sketch was not accepted as file.
Joffan your sketch is correct. I used the symmetry so that I " only" need to proof
BX / XC * CY / YA = 1
I determined all the angles and I found some similarities but they did not help to solve the problem.
Is Ceva' s theorem the right idea to solve the problem?
Maybe you could use Ceva's theorem - it seems a little overpowered.
I would proceed by marking X as the intersection of the new line from A with CM and Y as the intersection of the new line from B with CM. Then show that |MX| = |MY| and thus that X == Y
