- 42,895
- 983
gerechte23 added this to a thread on a different problem. I am starting a new thread for it
Why do you think you ought to be able to resolve it? That looks to me like a very nasty non-linear equation.
Hold on, I was assuming that the "x" in your equation was the independent variable. Did you mean it simply as "times"? (unlikely- by the time you are doing differential equations you should know better!
IF that was what you meant, then since the independent variable does not appear explicitely, we can use "quadrature". Let v= Y'. Then Y"= V'= dV/dx= (dV/dY)(dY/dx)= V(dV/dY) so the equation becomes the separable first order equation Y^2V dV/dY= C which can be written V dV= CdY/Y^2 and integrates to (1/2)V^2= -C/Y+ D where D is the constant of integration. Now, since V= Y', we can write that as the first order equation (1/2)(Y')^2= -C/Y+ D= (DY- C)/Y or Y'= 2(DY- C)/Y, again a separable equation.
\frac{YdY}{DY- C}= 2dx
To integrate the left side, let u= DY- C so that du= Ddy and we have
\frac{1}{D}\frac{du}{u}= 2dx
That is easy to integrate.
Of course, that only works if you meant Y2Y"= C. If your really meant xY2Y"= C with x the independent variable, I'm afraid it cannot be integrated in terms of elementary functions.
Hello, I am calculating a very important thing. But to find it, I should be able to resolve this equation. Y^2xY’’=C (C: Real number). Please help me solve it. Thanks in advance!
(YY)xY''=C (C:Real nnumber)
