Getting matrix row count in MATLAB for a while loop
  • Topic: MATLAB
  • Thread starter elbarto
    Count Matlab
10 replies · 84K views · last reply
elbarto
Hi,
I am am trying to determine the number of rows in a matrix using matlab,
I usually use
>>[rows,cols]=size(X);
>>rows
but this requires me to do the operation in 2 steps which will not work in my application.
I need to be able to determine the number of rows in one step so I can use it as a parameter in a 'while' loop.
I have tried using rows(X), but I get an error message. I haven't been able to find a solution and my code has come to a stand still. Surely there has to be a function or easy way to do this?
Thanks
Elbarto
Assuming X is rectangular use:
rows = length(X(:,1));
Although I find it surprising that you cannot use the code you had been using before, just execute it before the while loop starts.
Thanks Crosson,
here is part of the code i needed it for:
while (3*num_nodes-DOF)<length(K_cols_s(1,:));
if restx(i)==1;
K_cols_s(:,i)=K_cols_s(:,i);
end
if restx(i)==0;
K_cols_s(:,i)=[];
restx(i)=[];
i=i-1;
end
i=i+1;
end
As you can see, I was deleteing columns within the loop so i couldn't define the number of columns before hand as it was changing inside the loop. There might be a better way to do it but I am very new to matlab, and I am just trying to learn as much as I can.
One problem I am haveing tho is, my program requires a lot of inputs from the command window, and it is easy to make a mistake when inputing the values when promted. Is there a easy way to rollback to the previous input if you make a mistake?
The program is for solving 2d frames and trusses useing the matrix stiffness method in case you were wondering.
Thanks
Elbarto
I just skimmed, but if you want to return the size of a row in one step use r_size = size(X,1).
for columns, use c_size = size(X,2)
where X is a matrix
Thanks FrogPad, I appreciate all the help with getting to know these operations in matlab.
I hope you don't mind If I ask one more question tho (Il post here so I don't clog the forum up with my amature questions).
I get an output like this from MATLAB after I run my program,
Rs =
0.0000
-1.0000
-1.0000
Where Rs is the reaction forces,
Is there any way I can get this to be displayed as,
F1x = 0.0000
F1y = -1.0000
M1 = -1.0000
I tried to make a vector called actions_Rs by doing the following,
>> actions_RS={'F1x' 'F1y' 'M1'}'
actions_RS =
'F1x'
'F1y'
'M1'
but when I try to put the 2 together I get
> {actions_RS num2str(Rs)}
ans =
{3x1 cell} [3x11 char]
This obviously isn't what I had in mind. I want to try and make it easy for other users to easily intemperate each reaction force.
Thanks in advance
Elbarto
So, I don't have MATLAB handy... so treat this as pseudo code.
So Rs is a vector, in the case it happens to be a column vector (it has 3 rows, and 1 column).
You can access each element of the vector like this:F1x=Rs(1,1)
F1y=Rs(2,1)
M1=Rs(3,1)
Or you can use a shorter notation and accomplish the same thing with:
F1x=Rs(1)
F1y=Rs(2)
M1=Rs(3)
Now when you do this at the console, you will have a scalar variable (F1x,F1y,M1 are scalars).
If you want to make string variables you can do something like this:
str1 = strcat('F1x', num2str(Rs(1)))
str2 = strcat('F1y', num2str(Rs(2)))
str3 = strcat('M1', num2str(Rs(3)))
I used the strcat function because I cna't remember the short hand for string concatination off hand.
Now we can make the code really cryptic and do these in less lines, but I don't think that would help anything.
Let me know if this helps, any more questions... just ask
Thanks FrogPad, I will have a play around with those functions and see if I can get them to suit my application. The reason I tried to put all the names ie F1x F1y M1 in a vector is I was intending to use a loop to concatnate the 2 strings as the number of members I solve for changes, so I can't explicitly write a code for F1x F1y M1.
If I refer to my initial attempt, I wanted to try the function with a for loop, something like
for i=1:num_members
supports_reactions(i)={actions_RS num2str(Rs)}
end
I haven't had anything to do with strings yet so this might be quite a learning curve.
Thanks for taking the time to help me out
Regards Elbarto
for i=1:num_members
end
Regards Elbarto
ahhh... I just wrote up a very nice response to help you out, and I got logged out somehow and lost all of it!
Let me very quickly try to repeat myself
can you build a matrix "A" that is:
[1 2 3]
[4 5 6]
Where F1x=1, F1y=2, M1=3
F2x=4, F2y=5, M2=6
you can then loop through this with:
for i=1:size(A,2)
B(i,1) = strcat('F', num2str(i), 'x=', num2str(A(i,1)))
B(i,2) = strcat('F', num2str(i), 'y=', num2str(A(i,2)))
B(i,3) = strcat('M', num2str(i), num2str(A(i,3)))
end
Thanks a lot FrogPad, that looks like it will work out well. I will let you know how I get on.
Thanks Again
Elbarto
hello,
i am new to matlab, i m writing a simple program,...
i want to ask that, i have a matrix
1 1 2 100
2 2 3 200
3 2 3 300
4 3 4 400
i want to save 4th column values for i=1:4 as k1=100,k2=200,k3=300,k4=400.
how we will program in MATLAB this.
thanks in advance
