Getting started with kinematics and projectile motion
80 replies · 11K views
actually, the "d" should have been "-2", so the it should have been:
-2/-4.905=t*t
2/4.905=t²
is the d (-) because it is falling?
Because you are starting from the shelf (y=0) to the ground (y=-2) and you use Vf-Vo for the difference.
So now you have "t", put it in your X equation to get the distance from the edge of the shelf where it falls. And Voila !
Physics is not that difficult you see :-)
be back in 10 minutes, corner store time for some beers.
ok, now i have
X
a=0
Vo=8m/s
V=8m/s
d=?
t=.64s
y
a=9.81
Vo=0
V=6.26
d=2m
t=.64s
I keep trying to plug the equation only to cancel out most of the numbers and get D=T
When and if you get back on here, could you just run me through the steps when approached with these types of problems? maybe give me another example I could run through? I really appreciate the help here-
d=Vo(or Vf it's the same) X t
remember, distance = velocity X time
You run a car at 100 mph for 2 hours. How much distance will you travel ?
d = 100 x 2 = 200 miles
agreed, i understand the d=v/t formula, its the bigger one, that deals with this entire problem that i keep tripping on.
d = 8 m/s X 0.64s
meters/seconds X seconds
seconds/seconds = nil
only meters stay in unit.
yea, after i reread the problem i saw that i kept the s. So 5.1m is the distance the ball will end up at when i reaches the floor.
Was it so difficult ? :-)
totally! ahah, ok so i have a similar problem which has the same horiz velocity of 8m/s but instead height of the table they give me time(.24s). Do i work the problem the same way?
or can i just use the D=v/t
I think you have all the information you need.
Switch the variable in Y and resolve with the X equation like you did.
d=8(.24)+1/2(o)(.24*.24)
so the height of the table is 1.92m tall
Hummm.. as I reread your question, it would be it be if I was the teacher I would ask for the height of the table.
yea the problem is looking for the height of the shelf/table
you again mixed the X and Y.
1.92m is where the ball will hit the ground from the shelf, horizontally.
ok so the variables i have are
Vo=8m/s
a=0
t=.24s
d=1.92m
a=9.81m/s/s
Gimme some minutes, I will draw something.
I won't be leaving anytime soon, so take all the time you need. lol thanks.
There.
See the big black line between X and Y ? That's on purpose. They are to be resolved SEPARATELY.
k, i ll try out the problem, give me a sec or 2
oops there's a error. it's "a = Vf X t² + Vo"
Sorry.
I was trying to make a good drawing lol
