Gibbs energy for Lithiation in Lithium batteries
  • Thread starter Thread starter JulesP
    Thermodynamics
The discussion revolves around the thermodynamics and Gibbs energy calculations for lithiation in Lithium Iron Phosphate (LiFePO4) batteries. Participants explore the complexities of determining accurate values for enthalpy and entropy changes associated with the lithiation reaction, as well as the implications for energy density and capacity in battery performance.
  • One participant seeks specific figures to calculate the overall Gibbs energy for the lithiation reaction involving Li and LiFePO4.
  • Another participant outlines the Gibbs energy calculation method, emphasizing the need for standard enthalpy and entropy values from literature.
  • Clarifications are made regarding the interpretation of the reaction equation, with some participants questioning the accuracy of the initial formulation.
  • Concerns are raised about the complexities in energetics and the potential discrepancies between theoretical and actual cell potentials.
  • One participant suggests using published energy density figures to estimate other values, acknowledging the challenges posed by unknowns in the calculations.
  • Discussions include the importance of distinguishing between theoretical and operational values for charge capacity and energy density.
  • Participants express uncertainty about the accuracy of their calculations and the influence of various factors on the results.
Participants do not reach a consensus on the correct formulation of the lithiation reaction or the specific values needed for calculations. Multiple competing views and uncertainties remain regarding the interpretation of the reaction and the implications for energy calculations.
Limitations include potential inaccuracies in the reaction formulation, the dependence on specific values from thermodynamic databases, and the unresolved nature of the relationship between theoretical and actual performance metrics in Lithium batteries.
Researchers and practitioners in the fields of battery technology, thermodynamics, and materials science may find this discussion relevant, particularly those focused on Lithium Iron Phosphate batteries and energy storage systems.
JulesP
TL;DR
The calculation for lithiation in a Lithium Iron Phosphate battery
In writing up a paper on some research work on the effects of transients on Lithium Iron Phosphate batteries, I am laying out the thermodynamics and energetics for the reaction laid out below, but am having trouble finding the numbers for the reaction.
Does anyone know the correct figures to insert so I can get an overall Gibbs value for the reaction?
Thank you
Chemistry news on Phys.org
for sharing your research work on Lithium Iron Phosphate batteries. I can understand the difficulty in finding the specific numbers for the reaction, as it is a complex and constantly evolving field of study. However, to calculate the Gibbs energy for lithiation in Lithium batteries, we need to consider the overall reaction:
Li + xLiFePO4 -> Li1+xFePO4
The Gibbs energy for this reaction can be calculated using the equation: ΔG = ΔH - TΔS, where ΔH is the enthalpy change and ΔS is the entropy change.
To find the enthalpy change, we need to know the standard enthalpy of formation for LiFePO4 and Li1+xFePO4. This information can be found in thermodynamic databases or literature sources. Similarly, the entropy change can also be found from these sources. Once we have these values, we can calculate the enthalpy and entropy change for the reaction and then use them to calculate the overall Gibbs energy.
I recommend consulting with experts in the field or looking for recent studies on Lithium Iron Phosphate batteries to get accurate and updated values for the enthalpy and entropy changes. Additionally, you can also try reaching out to the research team or authors of the papers you are citing for their specific values. I hope this helps you in your research and good luck with your paper.
Thank you. I have only just found your reply! I got no email notice and I have posted something similar again today.
When you write Li1 you mean monoatomic and non-ionic Lithium and with Li non-attached Lithium + ions?
No, he means Li1+xFePO4. (At least I think so; the equation doesn't balance however you interpret it.) He has not formatted it properly, and for this and other inaccuracies and curiosities of expression, I think this is a chatbot answer. The reaction he writes is wrong. LiFePO4 is the discharged form of the cathode, and Li is removed on charging:
LiFePO4 + 6C → Li1-xFePO4 + LixC6
Discharge is the reverse reaction.
There are lots of complicating factors in the energetics. Just on a quick search I found this: https://pubs.rsc.org/en/content/articlelanding/2019/nj/c9nj03041g
I can't access the full article, and you may already be aware of it.
Thanks. I have requested the full article via ResearchGate.
As I understand it, the overall reaction is:
LiFePO4 + 6xC ⇄ Li(1-x)FePO4 + Li(x)C6
(I haven’t used the proper subscript formatting here)
but the proportion ‘x’ makes the calculations difficult.
Just looking at charging, the only relevant activity is:
6C + xLi+ + xe- to LixC6 (intercalated, lithiated Carbon) since the Iron Phosphate is common to both sides so can be ignored.
I’m inclined then to use published figures for specific energy density (90-160 Wh/kg) and work backwards to other values. Something of a cop out but, given the various unknowns, a reasonable approach 😗
For your calculations, I would estimate the theoretical capacity by using the approximation x = 1, though I don't think it ever goes fully to 1.
From what I remember, the theoretical potential for this reaction (from ΔG° =-nFE°) is considerably higher than the actual potential you measure for a cell (ca. 4V vs. ca. 2V, IIRC). For various reasons you don't convert all the free energy to electrical energy, so working back from the measured energy density may not give you what you're looking for.
Thank you. If I may, I will assemble my thoughts in a 1-2 page document over the next week, laying out the workable calculations. I would like to post that here, as a pdf or a link to it, and would appreciate your comments and thoughts on it. This is for preparations for a second research study on the most likely source of energy gains observed, particularly in LiFePO4 batteries, in response to inductive pulse charging (IPC) using high voltage transients. You can see the data from the first completed study on my site at kerrowenergetics.org.uk or via the Open Science Project at: http://osf.io/ZTFUB.
On second thoughts, I don't wish to bore anyone with all the details of my proposals for showing if IPC-related energy gains are from internal enthalpy or the local environment, as part of an open system, so I will just show the calculation for the charge and energy capacity of a specific battery.
The figures look reasonable and I have used a standard cell voltage of 3.45V for LiFePO4.
Charge and Energy Capacity Calculation
Why do you add the masses on both sides of the equation? Reactants are converted to products without change of mass.
The "active material" here is LiFePO4. You can't treat "FePO4" as a spectator. The oxidation state of Fe is changing. The C will be present in excess, so the key parameter is energy per kg LiFePO4. But what are the "actual" figures you are quoting? Are they energy per kg active material, or per kg total battery weight?
I have revised the calculations and page based on your feedback and this is here:
Revised Calculations
I was using an approach that had previously worked but translated it across incorrectly.
Thanks
So to be clear, the three figures for charge capacity are: theoretical specific charge capacity (Ah/kg from the molar masses), theoretical charge capacity for a specific battery (Ah and based on the masses of its active ingredients), and lastly the working charge capacity derived from actual discharge measurements on the specific battery. The latter are indeed a low percentage of the first value.
There is a corresponding set of values for the energy density and capacity in Wh/kg and Wh. I assume that the energy densities often quoted for new battery developments are theoretical values and not the much lower operational ones.
I note that the first values, using the molar masses method, are about 3% higher than some official values I have found using the Gibbs/reaction energies. Not sure why that is but it might be accounted for by the uncertainties in the tabulated values of formation energies. I think that molar masses are more consistently recorded and historically confirmed.
This has been very helpful in getting my thinking clear for the research proposal. Thank you.
  • · Replies 0 ·
  • · Replies 17 ·
13K
  • · Replies 39 ·
17K
