Given the weight composition, compute the partial pressures
This discussion focuses on calculating partial pressures from weight composition using molar fractions. The user successfully determined the number of moles for nitrogen (N2), oxygen (O2), and propane (C3H8) using the formulas: nN2 = 2 mol, nO2 = 1 mol, and nC3H8 = 0.2720 mol. The total moles (ntot) were calculated, leading to the molar fractions (χN2, χO2, χC3H8) and subsequently the partial pressures (PN2, PO2, PC3H8) using the equation P = χ * Ptot. The importance of units in calculations was also emphasized.
  • Understanding of molar mass calculations
  • Familiarity with the ideal gas law
  • Knowledge of stoichiometry
  • Basic algebra for manipulating equations
  • Study the ideal gas law and its applications in real-world scenarios
  • Learn about Dalton's Law of Partial Pressures
  • Explore advanced stoichiometry techniques for complex mixtures
  • Investigate the impact of temperature and pressure on gas behavior
Chemistry students, chemical engineers, and professionals involved in gas mixture analysis and thermodynamics will benefit from this discussion.
DottZakapa
a reactor contains a gas mixture of nitrogen, oxygen and propane at a total pressure of 5.00 atm. The weight composition of the mixture is 56 % nitrogen 32% oxygen 12% propane.calculate the partial pressures of the three gases.
gas laws
Hi can someone give an hand on understanding how to handle such kind of problems ?
can't come up with a valid solution.
if i do
##\frac {0,56}{2*14.00}## do i get the molar fraction of nitrogen?
ok finally got inspired.
##n_{N_2}=\frac {56}{2*14.00} = 2## mol
##n_{O_2}=\frac {32}{2*16.00} = 1##mol
##n_{C_3H_8}=\frac {12}{(3*12.01)+(8*1.01)}=0.2720## mol
In order to find the molar fraction:
##n_{tot}=n_{N_2}+n_{O_2}+n_{C_3H_8}##
##\chi_{N_2}=\frac {n_{N_2}}{n_{tot}} ##
##\chi_{O_2}=\frac {n_{O_2}}{n_{tot}} ##
##\chi_{C_3H_8}=\frac {n_{C_3H_8}}{n_{tot}} ##
In order to compute the partial pressures:
##P_{N_2}= \chi_{N_2} P_{tot}##
##P_{O_2}= \chi_{O_2} P_{tot}##
##P_{C_3H_8}= \chi_{C_3H_8} P_{tot}##
And this solves the problem
Looks correct. Remember units when calculating amount of substance.
  • · Replies 16 ·
