B Is Gravity Really Just Curved Spacetime?
The discussion centers on the concept of gravity as curved spacetime and how it affects stationary objects. It explains that while objects may appear to be stationary, they are actually moving through time, which influences their interaction with gravity. The analogy of ants on a sphere illustrates how two objects can be drawn towards each other due to the geometry of spacetime, even if they seem stationary. Participants clarify that gravity acts on all masses, pulling them together unless countered by another force. The conversation emphasizes the importance of understanding time as a dimension in this context to grasp how gravity operates in general relativity.
Andreas C
Ok. I get that objects seem to fall because of curved spacetime, when they're actually just moving in straight paths. I get the example of ants walking in straight lines on the surface of a sphere, thinking that something attracts them to each other. What I don't get is how the "ants" are "attracted" to each other without walking. What that means is, how is a stationary object attracted to another stationary object? I don't get this.
You're thinking of curved space only. In curved spacetime, stationary objects are effectively moving along the time axis at speed c, so the curvature of free fall paths as the object moves through time accelerates it even if it isn't moving in space.
Likes Andreas C
Start with the first scenario you posited. An object "seems to fall because of curved spacetime". Now expand it to encompass the "falling" object and the object towards which is it falling. Now you have exactly the scenario in your question. Two objects "attract" each other because of the space-time geometry between them. If they are stationary relative to each other, that means that there is a force involved that is keeping them apart. In your first part, you said they are moving towards each other with means no, or small, other force. In the part where you say they are stationary you have (without realizing it) posited another force. A good example of this is you standing on the surface of the Earth. the force keeping you from falling into the Earth towards the center is the electrostatic repulsion of your feet with the ground. If you jumped out of an airplane, there would be no such force so the space-time geometry would cause you to move towards the center of the Earth.
Ah ok, I think I get it now. So it moves in time, but it doesn't in space.
You don't have to be affected by a force in order not to be moving relative to another object... I think you misunderstood what I said.
Oh? How do you figure that? Give me an example
Yes, initially. But due to the space-time geometry it deviates from the purely temporal direction, and starts moving in space.
Likes nnunn, Andreas C and Nugatory
You are nearly there, you already have it in terms of space. Two ants at the equator will approach each other as they move towards the "North pole". Now think of the latitude as a time axis, and you have rudimentary "gravitation".
Likes Andreas C and Frimus
Why would that be the case? Can't two bodies be stationary in space? Since when? I think you're using the conclusion from what I want explained to explain it to me. Anyway, my question was explained.
Oh, I think I get it now, I can picture it now in 2 spatial dimensions, I obviously can't in 3 :)
No, they cannot. Gravity will pull them together unless they are kept apart by some other force. Any other examples? (hint ... there aren't any).
You can visualize a curved 2D space-time, but one of the dimensions needs to be time, so you actually have just 1 spatial dimension (like the straight vertical fall in the video I posted above). Correctly visualizing it for 2 spatial dimestions + time (for example to show orbits as geodesics) is difficult,
That's what I am saying. You are using the conclusion coming from what I want explained to explain it.
-How can bodies be "pulled together" due to spacetime geometry by gravity in GR if they are stationary?
-They can't be stationary.
Why can't they be stationary?
-Because they are pulled together by gravity.
You probably misunderstood my question.
Must have.
Likes Andreas C
Ah, no, I only visualized the concept of 2 particles on a 2-d surface being attracted to each other, nothing more complicated than that! I imagined something like 2 balls inside a sphere. The height of the sphere is time. Ok, it's not accurate, it's just the concept that I wanted to visualize, thanks!
That's fine. For two bodies pulled together along a straight line one spatial dimension is enough (the one along that line). The 2nd dimension on your sphere is time.
But what you are visualizing here is how particles of negligible mass are pulled together by the gravity gradient of a bigger mass (tidal gravity), not how masses attract each-other with their own mass.
I would say that the idea of gravity as curvature only works when you think that we reside in 4-dimensional spacetime, rather than 3-dimensional space. And furthermore, every object has a nonzero velocity in the time-direction (we are all moving into the future).
If you think of time as a dimension like space, then how gravity works is perhaps easier to understand. When you say that an object is "stationary", that only means that the spatial components of its velocity are zero, but the time component of its velocity is nonzero: It is moving into the future. Now, add gravity, and that path becomes bent--it starts moving purely in the time direction, but bends to start moving in a spatial direction, as well.
Because they age into the future; see post #17 for details.
Sure. I just wanted to realize the concept.
Yeah, that was explained by Jonathan Scott and A.T.
There is no such thing as a time axis in spacetime.
Time is the distance traveled on a particular world line, each world line has its unique sense of time.
That is actually a meaningless statement in GR. World lines extend all the same way but world lines could approach from opposite directions in some models. So which direction is the future?
Likes nnunn
I think that there might be exotic solutions of the equations of GR for which there is no consistent way to assign a notion of "future" to timelike paths, but in our universe, there is a unique notion of "the future".
stevendaryl said:
.. in our universe, there is a unique notion of "the future".
You don't know that!
You're right, that there is no such thing as a time axis, but at every point in spacetime, we can pick 4 independent axes such that one of them is timelike and the others are spacelike. And the point is that the spacetime path of any particle will have a nonzero "velocity" with respect to any timelike axis.
Okay, all the evidence points to a Big Bang cosmology that does have a unique directionality in time. The model could be wrong, of course, but just about any non-tautological statement could be wrong.
Likes nnunn
Remember that 4D spacetime is curved, not 3D space. A stationary object in spacetime is a line, not a point. A stationary object in space is moving into the future.
As long as the particle has mass.
Which mathematical object are you referring to here? The norm of the tangent vector to the particle's worldline? If so, MeJennifer's statement that this only applies to a massive particle is correct. However, the norm is invariant and you seem to be talking about something that could change from one inertial frame (choice of timelike axis) to another, so I'm not sure exactly what mathematical object you are referring to.
The component of the 4-velocity of the particle in the "time" direction. Mathematically, let e_\mu be any basis for which e_0 is timelike and e_j is spacelike, for j \neq 0. Let U^\mu be a particle's 4-velocity expressed in this basis. Then U^0 \neq 0. I think that's true. If so, it's a statement that is true in any locally Minkowskian frame, but it's not clear how to express it as a statement about invariants.
  • · Replies 27 ·
  • · Replies 76 ·
