Grade 11 Thermodynamics Question
The discussion revolves around a thermodynamics problem involving the interaction of steam and ice, specifically the final temperature resulting from adding 50 g of steam at 150 degrees Celsius to 50 g of ice at -5 degrees Celsius. Participants are exploring concepts related to heat transfer, phase changes, and energy conservation.
  • Participants discuss various approaches, including calculating energy changes in stages and sketching energy vs. temperature graphs. Questions are raised about the energy released by the steam and the energy needed to raise the temperature of the ice.
Some participants are attempting to clarify their understanding of the problem by breaking it down into stages and addressing specific questions posed by others. There is an ongoing exploration of the calculations involved, with some guidance offered regarding the need to check values for specific and latent heats.
Participants note discrepancies in initial temperature assumptions and specific heat values, indicating potential misunderstandings in the setup of the problem. There is a sense of urgency as the original poster is preparing for an upcoming test.
The Spanglock
You add 50 g of steam at 150 degrees centigrade to 50 g of ice at negative five degrees centigrade. What is the final temperature?
Q = mLfv
Q = mcΔT
Qg = Ql
Q1 + Q2 = -Q3 - Q4
mLf + mcΔT = -mLv + mcΔT [ΔT will be negative, making the symbol positive in front]
(0.05)(3.4x105) + (0.05)(4200)(Tf+ 5) = (0.05)(2.26x106) + (0.05)(4200)(Tf - 150)
210Tf + 18 050 = 210Tf -154 600
And I think that here you can see the issue. I asked my instructor since I previously had ...= -mLf - mcΔT, but that gave -232 degrees centigrade.
I'm hoping someone on here can help me. I always get stuck with these problems and the test is in two days, meaning I need to really understand these types of exercises or I'm screwed [these are ranked as the highest marked].
Thanks for any help you can offer! :smile:
You can try doing it by stages ... The energy from the steam is used to heat the ice.
How much energy would be released lowering the steam temperature to 100deg?
How much energy is needed to raise the ice temperature to 0deg?
Is the first number bigger or smaller than the second one?
You can also try sketching a graph of energy vs temperature ... you will have two lines, one for energy released by the steam and the other for energy needed by the water. The two lines will have sloping and horizontal sections ... and they should cross somewhere.
I sketched a graph, which my instructor looked at. He said it's good and that I'm on the right track, but I don't know what it is I'm doing wrong. I tried fiddling with the positive and negative signs to see if I could at least get a reasonable answer with no luck. I just tried to do it in some stages and it didn't work as well. I have never been stuck on a problem so long before in my life.
OK - show me the stages ... please answer the questions in post #2.
I did each one individually, as my teacher taught me to do. I'm not sure if this is what you meant, but I'll show you anyway.
Q1 = mLf = (0.05)(3.4x106) = 17 000
Q2 = mcΔT = (0.05)(4200)(Tf+5) = 210Tf + 1050
Q3 = -mLv = -(0.05)(2.26x106) = -113 000
Q4 = mcΔT = (0.05)(4200)(Tf -160)
Then I subbed them in. Is this what you meant? Do all the calculations separately then combine them? Or did I misinterpret?
No, when I say please answer the questions in post #2 I mean answer the questions in post #2.
None of those lines answer the questions in post #2?
Lets do it one at a time:
1. How much energy is released lowering the steam to 100deg?
The idea here is to make sure you understand the process.
Aside: check your values for specific and latent heats ... check units etc.
i.e. I have L_f = 334 kJ/kg = 3.34x105 J/kg
from http://www.engineeringtoolbox.com/water-thermal-properties-d_162.html
Compare with yours.
The numbers in post #5 seem to assume the initial temp of the steam is 160deg (that is not what post #1 says) and that the specific heats are the same across phase changes, and that all the steam and all the ice ends up as water.
