Gravitational field between two planets.
The discussion revolves around determining the point at which the net gravitational field between two planets, Planet A and Planet B, is zero. The participants explore the relationship between the distances from a test mass to each planet and the gravitational forces involved.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Assumption checking
  • Participants discuss algebraic approaches to isolate the distance from the test mass to Planet A, questioning the validity of their assumptions and the implications of negative values in their calculations. Some suggest focusing on magnitudes of forces rather than directions.
The conversation is active, with participants sharing their reasoning and calculations. Some have provided guidance on isolating variables and simplifying expressions, while others express uncertainty about their results and seek clarification on their approaches.
Participants are working under constraints typical of homework assignments, such as avoiding numerical solutions and focusing on algebraic expressions. There is an ongoing discussion about the assumptions regarding the forces acting on the test mass.
harelo
[SOLVED] Gravitational field between two planets.
Planet B and Planet A are separated by a distance of R.
At what distance will the net gravitational field be 0, express R in terms of Planet A.
HINT: Use Gravitational Force.
Since I don't need a numerical value for this, I had an algebraic approach to it, and since I know that if Fg = 0 then G would be = 0.
Fga = -Fgb
Gmamo/Ra^2 = -(Gmbmo/(Ra-R)^2
Where Ra is the ratio from the test mass to Planet A, and mo is the test mass
However, after I try all my algebraic arrangements to isolate Ra, I always end up square rooting a negative number, which is impossible.
What am I doing wrong?
PS: Anything that is not bolded is a subscript. Sorry about the messy report, the superscripts and subscripts aren't working properly for some reason :S
If the distance between the test mass and one planet is x then the other distance is R-x
If the mass of the test mass is B then the force between the test mass and one planet is the same as the test mass of the other planet and the test mass
so that
[tex]\frac{GMB}{x^2}=\frac{GmB}{(R-x)^2}[/tex]
reducing to
[tex]\frac{M}{x^2}=\frac{m}{(R-x)^2}[/tex]
[tex]\frac{M}{m}=\frac{x^2}{(R-x)^2}[/tex]
[tex]\frac{M}{m}=(\frac{x}{R-x})^2[/tex]
You should be able to get this answer using only magnitudes of the force vectors. You want to find the Ra, where the magnitude of both fields is zero, which you should be able to find with the negative problem. Try working with only magnitudes and not working with the negative sign.
M being the mass of planet A and m being the test of Planet B I'm assuming?
and where did the negative that was there go to?
Sorry I just want to understand the problem before I do it blindlyG01, I went under the assumption that the forces should be equal in magnitude but different in direction, I don't think that's a wrong assumption, right?
so that
reducing to[tex]\frac{M}{x^2}=\frac{m}{(R-x)^2}[/tex]
[tex]\frac{M}{m}=\frac{x^2}{(R-x)^2}[/tex][tex]\frac{M}{m}=(\frac{x}{R-x})^2[/tex]
How does doing almost all the calculations for the OP actually help them in the end?
That is definitely a correct assumption, but you shouldn't have to worry about direction here. The forces will ALWAYS be opposite in direction along the line between the planets, so the only thing changed by the position in this case is the magnitude of each force.
So, you can say that you want to find the position where the magnitudes are equal, since the direction will always be correct. Thus, this is why the minus sign will disappear, since we are setting the magnitudes of each force equal to each other.
Does this make sense?
Yeah that makes perfect sense, so let's recap:
but by having:
I understand that you divide out the gravitational constant and the test mass, leaving us with
and by cross multiplication, you get
However, after this point, I am not sure how you would go ahead and isolate that X. perhaps:
[tex]\sqrt(\frac{M}{m})=\frac{x}{R-x}[/tex]
But I'm somewhat lost after there :S
EDIT
After further factoring, I ended up with this:
[tex]\frac{R\sqrt(\frac{M}{m})}{1+\sqrt(\frac{M}{m})}=x[/tex]
Am I right or am I completely out to lunch?
Try this:
Take the inverse of both sides of your last line. Then, can you divide through by the lonely x that will be in the denominator on the one side? This should help isolate it.
Not sure if my edit appeared on time or not, but:
I don't get that answer. Can you show your factoring? Maybe my answer is just simplified more and we're both right, but I can't tell from your end result.
Will do
I multiply the B radius to both sides
[tex](R-x)\sqrt(\frac{M}{m})=x[/tex]
I expand (R-x) out of the brackets
[tex]R\sqrt(\frac{M}{m})-x\sqrt(\frac{M}{m})=x[/tex]
Move the expanded x to the other side
[tex]R\sqrt(\frac{M}{m})=x+x\sqrt(\frac{M}{m})[/tex]
Factor out the x
[tex]R\sqrt(\frac{M}{m})=x(1+\sqrt(\frac{M}{m}))[/tex]
Divide out to isolate x
Ok. That work looks correct to me. I agree with your answer. Good job!
Thank you :) would you mind sharing what your answer was with me tho? I'd like to know if you had another approach
No problem. Here is how I obtained my answer:
[tex]\sqrt{\frac{M}{m}}=\frac{x}{R-x}[/tex]
Invert both sides:
[tex]\sqrt{\frac{m}{M}}=\frac{R-x}{x}[/tex]
Split the right side into two fractions:
[tex]\sqrt{\frac{m}{M}}=\frac{R}{x}-\frac{x}{x}[/tex]
[tex]\sqrt{\frac{m}{M}}=\frac{R}{x}-1[/tex]
It should not be too hard to solve for x from here.
You should get the same answer either way.
yeah just tried with made up values and I got the same answer, thanks a lot for the help :)
Anytime! Good Work!
  • · Replies 23 ·
