Gravitational force and acceleration in General Relativity.
371 replies · 59K views
starthaus said:
Physics is not pasting together stuff you glean off the internet.
If your definition of physics is showing how you derive your conclusions, then you are not doing physics in this thread, because you have yet to shown how you derived your results from the standard Schwarzschild equations of motion.
Several times you have stated that your final results differ from the equations I gave in #1. Now you have begrudgingly admitted that the equations in #1 are correct that means the results you have obtained are wrong.
You also stated the results obtained by Moller differ from the results obtained by Dalespam. Now that you have admitted Dalespam's results are correct, you are in fact saying the results given by Moller are wrong. Are you going to write to Moller and explain to him where he is going wrong?
I am keen to learn. Post your derivation and I will see what I can learn from it.
kev said:
In order to differentiate dr/ds we need to know its value. This can be obtained from the Lagrangian (with [itex]d\phi[/itex] set to zero).
There is no reason to set [itex]d\phi=0[/itex]. You loose one set of equations of motion for no reason whatsoever.
[tex]L = \frac{1}{2} = \frac{1}{2} \left( \alpha \left(\frac{dt}{ds}\right)^2 - \frac{1}{\alpha}\left(\frac{dr}{ds}\right)^2 \right)[/tex]
(See section 13.1 of http://people.maths.ox.ac.uk/~nwoodh/gr/gr03.pdf )
Solve for dr/ds:
[tex]\frac{dr}{ds} \; = \; \sqrt{ \alpha^2 \left(\frac{dt}{ds}\right)^2 - \alpha}[/tex]
What do you mean "solve for dr/ds"? There is no equation.
Physics is not a collection of hacks.
kev said:
Now convert to ds to dt to get the coordinate result:
[tex]\frac{d^2r}{dt^2} = \frac{d^2r}{ds^2}\left(\frac{ds}{dt}\right)^2 \;[/tex]
Why on Earth would anyone do such an elementary calculus mistake? Do you plan to learn differentiation any time soon?:lol:
starthaus said:
Why on Earth would anyone do such an elementary calculus mistake? ...
Yep, I slipped at at the last step. This is how it should done.
Assuming initial conditions of a stationary particle at infinity that radially freefalls:
[tex]1 = \alpha \left(\frac{dt}{ds}\right)^2 - \frac{1}{\alpha}\left(\frac{dr}{ds}\right)^2[/tex]
Solve for dr/dt:
[tex]\frac{dr}{dt} \; = \; \alpha \sqrt{\frac{2M}{r}} = \left(1-\frac{2M}{r}\right) \sqrt{\frac{2M}{r}}[/tex]
Differentiate dr/dt with respect to t:
[tex]\frac{d^2r}{dt^2} \; = \; \frac{d(dr/dt)}{dr} * \frac{dr}{dt} \;=\; \left(\frac{2m}{r^2}\sqrt{\frac{2M}{r}} -\frac{m}{r^2} \frac{\alpha}{\sqrt{2M/r}}\right) \alpha \sqrt{\frac{2M}{r}} \; = \; \frac{-m}{r^2} \left(1-\frac{2M}{r}\right) \left(1-\frac{6M}{r}\right)[/tex]
This is the correct equation for the Schwarzschild coordinate acceleration of a radially free falling particle, initially at rest at infinity.
Now it your turn to stop being a coward and show your derivation from the equations of motion for the proper/ coordinate acceleration of a stationary particle in Schwarzschild coordinates. My guess is that we will never see it, because you realize by now that your derivation was wrong.
What gives you this idea? What is the connection to the Lagrangian you put up before?
Solve for dr/dt:
No, it isn't.
The equations of motion are all the way back in post #2. For someone who makes so many mistakes, you are quite abusive.
What gives you the bright idea that you can set the Lagrangian to a number?
starthaus said:
No, it isn't.
That exact equation is given here http://www.mathpages.com/rr/s6-07/6-07.htm
Do you think that reference is wrong? What do you think the equation should be?
You gave the equations of motion which is effectively giving nothing because they are standard and quoted in hundreds of online references. However you claim to be able to teach me how to derive the proper and coordinate acceleration of a stationary particle from those equations of motion, which would be impressive if you could actually do it but so far you have come up with nothing.
I got the idea from here: http://people.maths.ox.ac.uk/~nwoodh/gr/gr03.pdf section 13.1
L = constant. ... Since s is proper time, [itex]g_{ab}\dot{x}^{a} \dot{x}^{b} = 1[/itex], and therefore the third conservation law is L = 1/2 .
That suggests to me that the Lagrangian is a constant.
Anyway, I can do it a different way and obtain the same result.
Using units of G=c=1 the Schwarzschild metric is;
[tex]ds^2 = (1-2M/r)dt^2 - (1-2m/r)^{-1} dr^2 - r^2 d\phi^2[/tex]
Divide both sides by ds^2.
[tex]\frac{ds^2}{ds^2} = (1-2M/r) \frac{dt^2}{ds^2} - (1-2m/r)^{-1} \frac{dr^2}{ds^2} - r^2 \frac{d\phi^2}{ds^2}[/tex]
[tex]1 = (1-2M/r) \frac{dt^2}{ds^2} - (1-2m/r)^{-1} \frac{dr^2}{ds^2} - r^2 \frac{d\phi^2}{ds^2}[/tex]
The correct result has already been derived eons ago by using covariant derivatives. Look up Dalespam's post.
You just asked for the equations of motion, I told you that I derived them at post #2. You got exactly what you asked for.
because they are standard and quated in hundreds of online references. However you claim to be able to teach me how to derive the proper and coordinate acceleration of a stationary particle from those equations of motion, which would be impressive if you could actually do it but so far you have come up with nothing.
I can do it in three lines.
You obviously know nothing about Lagrangian mechanics.
Yep, you don't.
So, what do you do next? We already know the correct result, ir is [itex]-\frac{m}{r^2\sqrt{1-2m/r}}[/itex]
It can be derived either through covariant derivatives or , more directly, through using the metric.
You know that is not true, as I have asked you many times to derive the proper and coordinate acceleration of a stationary particle from the equations of motion, as you claim to be able to do.
Lets see it then!
For your convenience, here is the start of your derivation;
starthaus said:
You need to start with the metric:
[tex]ds^2=\alpha dt^2-\frac{1}{\alpha}dr^2-r^2d\phi^2[/tex]
[tex]\alpha=1-\frac{2m}{r}[/tex]
From this you construct the Lagrangian:
[tex]L=\alpha (\frac{dt}{ds})^2-\frac{1}{\alpha}(\frac{dr}{ds})^2-r^2(\frac{d\phi}{ds})^2[/tex]
From the above Lagrangian, you get immediately the equations of motion:
[tex]\alpha \frac{dt}{ds}=k[/tex]
[tex]r^2 \frac{d\phi}{ds}=h[/tex]
whre h,k are constants.
From the first equation, we can get immediately:
[tex]\frac{dt}{ds}=\frac{k}{1-\frac{2m}{r}}[/tex]
From the above, we can get the relationship between proper and coordinate speed:
[tex]\frac{dr}{ds}=\frac{dr}{dt}\frac{dt}{ds}[/tex]
Differentiate one more time and you will obtain the correct relationship between proper and coordinate acceleration.
Lets see it then!
The first two equations are your own personal hacks, I never wrote them.Let me give you the correct start that solves the problem in three lines:
[tex]\vec{F}=-grad\Phi[/tex]
where [tex]\Phi[/tex] is the potential that you can read straight off the metric. You have two more lines to write, see if you can do it all by yourself, I have already shown you how to do that for centripetal acceleration, you only need to copy the method.
The equation given in the reference is for the coordinate acceleration of a free falling particle. It is not wrong. It differs from Dalespam's result, because his result is for the proper acceleration of a stationary particle, which is more relevant to this thread. Both equations are right in their own contexts.
Noob question here: why is the lagrangian
[tex]L = \frac{1}{2}g_{ab}\dot{x}^a\dot{x}^b[/tex]
? Shouldn't it be
[tex]L = \sqrt{g_{ab}\dot{x}^a\dot{x}^b}[/tex]
since it's the path length we want to maximize?
I tried it that way and got different equations of motion. I'm not sure what to do with them now though! I think I prefer the derivation posted by DaleSpam a couple of pages ago.
Just curious. Prefer it to what? So far Dalespam is the only person to give a derivation of the acceleration of a stationary particle, in this thread.
To getting it from the lagrangian. I nearly did it but I was just saying the one with 4-vectors looks much easier.
I see you now want to move the goal posts. Back in #2 and #4 you started a derivation using the Lagrangian and "left it as an exercise" for me to complete. That normally implies that you know how complete the derivation starting with the Lagrangian and the equations of motion, but despite many requests you have been unable to do so and now you want to do it using covariant derivatives (already done by Dalespam) or using potentials. Now if you want to do it doing using potentials that is fine and I would be glad to see it because I have never aproached the problem from that angle, but for future reference, if you set people "exercises" you should be able to complete the exercise yourself.
I managed the lagrangian derivation, the answer I got was
[tex]\frac{d^2 r}{dt^2} = -\frac{m}{r^2}\alpha\left( 1 - \frac{3}{\alpha^2} \left( \frac{dr}{dt}\right)^2\right)[/tex]
I think that agrees with the other results in this thread, depending on the initial velocity. Does that seem right to anyone? I am not quite sure how to interpret it though. This isn't a proper acceleration is it? So it only applies to free falling particles. But is it equal and opposite to the proper acceleration required to stay a fixed distance from the black hole as well?
I too completed the "lagrangian derivation" and sent copies of my derivation to Dalespam and DrGreg to check over for me. I will post the derivation here in a day or two, but I thought I would first give Starthaus the opportunity to show that he is not full of "it" and show he can complete the derivation he started and left for us to complete as "an exercise".
starthaus said:
This is very wrong. You need to start with the metric:[tex]ds^2=\alpha dt^2-\frac{1}{\alpha}dr^2-r^2d\phi^2[/tex]
[tex]L=\alpha (\frac^2{dt}{ds})-\frac{1}{\alpha}(\frac^2{dr}{ds})-r^2(\frac{d\phi}{ds})^2[/tex]
The correct Lagrangian (see above) is derived directly from the metric.
From the Lagrangian, you get the equation of motion (see above).
There is a third Euler-Lagrange equation, that I have left for last:
[tex]2\frac{d}{ds} (1/\alpha \frac{dr}{ds})-[\frac{2m}{r^2}(\frac{dt}{ds})^2-(\frac{dr}{ds})^2 \frac{d}{dr}(1/\alpha)-2r(\frac{d\phi}{ds})^2]=0[/tex]
The above, for [tex]\frac{dr}{ds}=0[/tex] produces:
[tex]\omega^2=\frac{m}{r^3}[/tex]
i.e. Kepler third law.
For a complete derivation of acceleration in rotating frames, see the other thread.
On the other hand, if the motion is radial, i.e. [tex]\frac{d\phi}{ds}=0[/tex] the equation of motion becomes:
[tex]2\frac{d}{ds} (1/\alpha \frac{dr}{ds})-[\frac{2m}{r^2}(\frac{dt}{ds})^2-(\frac{dr}{ds})^2 \frac{d}{dr}(1/\alpha)]=0[/tex]
You mean the correct result obtained by Dalespam that agrees with the result I gave in #1 right?
Your derivation is incomplete. You have not shown that you can apply the equations you have mindlessly copied from a textbook to a physical situation. You should be able to answer the questions posed in the OP and give answers in Newtons for force or meters/second^2 for acceleration.
kev said:
... we should be be able to answer simple questions like "what does General Relativity predict that the weight of a 1kg mass on the surface of a very massive gravitational body to be?" or "what is the initial acceleration of 1kg mass when released from a short distance above a very massive gravitational body?"
I can answer those questions unambiguously. Can you?
Physics is not putting in results by hand. You need to learn how to derive them, kev. For this, you need to learn.
I am trying to teach you how to derive results (instead of putting them in by hand, as you have been doing), so I left the easy part for you, as an exercise. You still have no clue how to derive the equations of motion from the Lagrangian, eh?
kev said:
Your derivation is incomplete. You have not shown that you can apply the equations you have mindlessly copied from a textbook to a physical situation. You should be able to answer the questions posed in the OP and give answers in Newtons for force or meters/second^2 for acceleration. I can answer those questions unambiguously. Can you?
I am trying to teach you how to derive results (instead of putting them in by hand, as you have been doing), so I left the easy part for you, as an exercise. ...
You are missing the point. As I said in post 79, I have already derived the equations and Dalespam and DrGreg hold copies of that derivation, as proof that I have done so. I have given you over a week to show you can complete your own "exercises" and prove yourself worthy of being "my teacher" and not just some guy trying to look clever by posting exercises from a textbook that he has no idea how to complete. So far you have not completed any of the exercises or derivations you have posted in any thread, that are not already completed in the textbooks you quote from. I am still waiting and so is Tomsk who would like to see the derivation.
LOL
I don't think he's waiting on anything, he knows what to do.
Starthaus: If you don't want want to post the derivation because you are worried that I will miss the learning opportunity of deriving for myself, then you have no need to worry because I have availed myself of the opportunity and done just that. You now no longer have any excuses not to publish the completion of the exercise you set and the I suspect the reason you are stalling, is that you do not know how to to complete your own exercise.
P.S. Tomsk clearly expressed an interest in #78.
kev said:
Starthaus: If you do want want to post the derivation because you are worried that I will miss the learning opportunity
No, I am not worried at all. It is clear that you don't know what to do with the Lagrangian.
I have done the derivation from the initial information (What you call "the hard work" and what I call quoting from a textbook.) that you provided on the first page of this thread. It seems you want to move the goal posts again. All I am asking you to do is complete ANY of the exercises/derivations that have started and show you can end up with the equations given in #1.
No, you haven't. That would require knowledge of the Euler-Lagrange formalism of which you have none. Otherwise, you would have derived the equations of motion from the Lagrangian I derived for you long,long ago.
Yes I have and Dalespam and DrGreg have copies of my derivation to prove it. If you publish your derivation and it is different to mine I will learn from the different approach. If you show your derivation (if you are in fact able to do it) I will post my derivation and if it is wrong wrong or flawed, I will learn from that too. You claim your purpose here is to educate me, but so far I have seen no sign of you trying to be genuinely helpful and your posts are just confrontational and inflamatory as possible. Does the word "troll" mean anything to you?
Education doesn't mean doing all the homework for you, you need to learn how to do it yourself.
