Gravitational potential energy concept question
When a piece of fruit falls, the gravitational force does positive work on it, leading to a decrease in gravitational potential energy. The correct answer to the posed question is B. As the fruit descends, its height decreases, which correlates with a reduction in gravitational potential energy according to the equation Ugrav = Mgy. The work done by gravity is considered positive because the motion of the fruit aligns with the direction of the gravitational force. This understanding clarifies the relationship between gravitational force, work, and potential energy during free fall.
Mdhiggenz
A piece of fruit falls straight down. As it falls,
A. the gravitational force does positive work on it and the
gravitational potential energy increases.
B. the gravitational force does positive work on it and the
gravitational potential energy decreases.
C. the gravitational force does negative work on it and the
D. the gravitational force does negative work on it and the
The correct answer is B
I want to make sure my reasoning is correct. The answer would be B because when the piece of fruit falls the only force acting upon it is gravity. So relating this to the gravitational potential energy equation Ugrav= Mgy; as the fruit falls its displacement is decreasing due to it getting closer and closer to zero thus making the over all gravitational potential energy decrease.
Thank you
That's right. And the work done by gravitational force is positive, because the fruit is moved in the same direction as the force is pointed to.
Thread 'Correct statement about size of wire to produce larger extension'
The answer is (B) but I don't really understand why. Based on formula of Young Modulus: $$x=\frac{FL}{AE}$$ The second wire made of the same material so it means they have same Young Modulus. Larger extension means larger value of ##x## so to get larger value of ##x## we can increase ##F## and ##L## and decrease ##A## I am not sure whether there is change in ##F## for first and second wire so I will just assume ##F## does not change. It leaves (B) and (C) as possible options so why is (C)...
  • · Replies 28 ·
