Gravitational Potential: How to know where the max GP is located?
14 replies · 6K views · last reply
tiffany chan
New user has been reminded to use the Template when posting schoolwork problems
Exam question diagram: a planet of mass 100M on the left and a moon of mass M on the right, centres 22R apart, with a multiple-choice list of answers A to D: 2R, 11R, 20R, 2R and 20R.
By using the equation for the Gravitational Potential -GM/R. It is understand that the max Gravitation Potential would be at infinity point.
- G(100M)/22R-(-GM/22R) would be the maximum Gravitational Potential... I guess...
Then what would be the next step to find the distance?
  • Exam question diagram: a planet of mass 100M on the left and a moon of mass M on the right, centres 22R apart, with a multiple-choice list of answers A to D: 2R, 11R, 20R, 2R and 20R.
Yes. This is a quite clearly an error in the formulation of the problem. The intended problem is probably to find the point of maximal gravitational potential on the line between the centers of the moon and the planet.
Sorry, but it is very unclear what you mean by this.
Orodruin said:
Yes. This is a quite clearly an error in the formulation of the problem. The intended problem is probably to find the point of maximal gravitational potential on the line between the centers of the moon and the planet.Sorry, but it is very unclear what you mean by this.
Thanks for your reply.
So do you mean -GM/R is not the right equation to be used to solve this question?
-GM/R is a formula, not an equation. If G is Newton's universal gravitational constant, R is the distance of a test point from the center of the moon and M is the mass of the moon then it is a formula giving the moon's gravitational potential at that test point. So yes, it is a useful part of a correct approach to solve the problem.
You had proposed
Like @Orodruin, I have no idea what this formula is supposed to denote. Taken at face value, it is the difference between the potential of a test point at the planet in the gravitational field of the moon and the potential of a test point at the moon in the gravitational field of the planet. Physically meaningless.
You should be trying to find a formula for the total gravitational potential at a given test point in the combined fields of planet plus moon. The position of the test point will be present in such a formula.
Diagram of a planet of mass 100M on the left and a moon of mass M on the right, centres 22R apart, with a red arrow marked x measured from the planet's centre to a point between them.
1. Assume the maximum distance happened at a distance x from the centre of the planet.
2. Total Gravitational Potential would be: (-100GM/x) - (-GM/1-x) = (what should be the max GP equal to)??
  • Diagram of a planet of mass 100M on the left and a moon of mass M on the right, centres 22R apart, with a red arrow marked x measured from the planet's centre to a point between them.
tiffany chan said:
1. Assume the maximum distance gravitational potential happened at a distance x from the centre of the planet.
You write "1-x" to represent the distance between the moon and the test point. But the distance between moon and planet is not 1.
[Also, be aware of parentheses. by "-GM/1-x" you presumably mean ##-\frac{GM}{1-x}## but without proper parentheses, what you have written really means ##-\frac{GM}{1}-x##]
I use x because i considered it as ratio.
So correct way would be
(-100GM/X) + (-GM/(22R-x)) = total GP?
But I’m confuse of what value to be put for the total GP in the equation
Look at the question. You are not asked for total GP. You are asked for the position where total GP is maximized.
You are trying to find the place where a function is maximized of a function. If you have been exposed to calculus, there is a good way to use that. Otherwise, you could think about what has to happen to gravitational force at the point where potential is maximized.
When potential is maximised, the gravitational force should be zero?
Correct.
jbriggs444 said:
Correct.
If the force = 0 when the GP is maximised. That means, gravitational field strength at that point = 0 as well.
So, the equation will be: 100GM/x^2 - GM/(22R-x)^2 = 0, then solve for x?
Yes.
Isn't this a long way around, negating the usefulness of the potential concept?
Are you suggesting he finds the maximum by differentiating the potential and setting the derivative to zero? That is equivalent since the force is (minus) the derivative.
