yuganes warman
Everything that has mass , posseses gravitational pull. We as humans do have mass, and thus posses gravitational pull too ? If so , do we posses tiny amount of gravitational pull ?
The discussion centers on the concept of gravitational pull and its effects on humans, confirming that all objects with mass, including humans, exert a gravitational force. The gravitational force can be quantified using the formula F = (G * m1 * m2) / r^2, where G is the gravitational constant (6.7 x 10^-11), m1 and m2 are the masses of the objects, and r is the distance between them. The participants clarify that while humans do exert a gravitational pull, the force is negligible compared to larger masses like Earth due to the small values involved. Additionally, the distinction between gravitational force and gravitational acceleration is emphasized, with the latter typically denoted by 'g'.
PREREQUISITESThis discussion is beneficial for physics students, educators, and anyone interested in understanding the principles of gravitational forces and their implications in both theoretical and practical contexts.
Reducing the distance increases g. And why would the constant be smaller? Doesn't the term "constant" give you a hint?Rithikha said:g=(G.m1.m2)/r^2
If you calculate the gravitational force (g) for everyday objects, the masses, distance are extremely small, not to forget the smaller constant. Hence, the resultant g is also very small and thus negligible.
I meant, the constant is smaller compared to the masses. Why do you think I mentioned the value if I didn't know that?A.T. said:Reducing the distance increases g. And why would the constant be smaller? Doesn't the term "constant" give you a hint?
The only part of your explanation that is correct, are the small masses. Also note that "g" usually refers to gravitation acceleration, not the force.
The constant has different units than mass. It doesn't even make sense to compare them.Rithikha said:I meant, the constant is smaller compared to the masses.
Then you should use "F" for force, not "g".Rithikha said:This is the gravitational force formula.
It's not clear how you can say "the force acting on the much smaller object is = to acceleration" when you also say "Force = mass * acceleration".quincy harman said:I thought that Force = mass * acceleration. So if something has very little mass and is accelerating towards an object the size of Earth at 9.8 meters per second2 then wouldn't you be able to say that the force acting on the much smaller object is = to acceleration?
You're right it makes no sense bahaha. Just thought about it.SteamKing said:It's not clear how you can say "the force acting on the much smaller object is = to acceleration" when you also say "Force = mass * acceleration".![]()
F= ma and, for gravitational force, F= GmM/r^2 where "m" and "M" are the masses of the two objects. If we take m to be the "little mass" and M to be the "larger mass" then, for the smaller mass, ma= GmM/r^2 so a= GM/r^2. For the larger mass, Ma= GmM/r^2 so a= Gm/r^2. That tells us, first, that all objects, attracted by the earth, accelerate toward the Earth with the same acceleration, GM/r^2. At the same time, the Earth is accelerating toward the object with acceleration Gm/r^2 which is, of course, far smaller than GM/r^2.quincy harman said:I thought that Force = mass * acceleration. So if something has very little mass and is accelerating towards an object the size of Earth at 9.8 meters per second2 then wouldn't you be able to say that the force acting on the much smaller object is = to acceleration?
What about Einsteins thought experiment in which he said that if you're in a closed box and accelerating at 9.8 meters per second per second in space that you would not know the difference from standing on Earths surface?HallsofIvy said:F= ma and, for gravitational force, F= GmM/r^2 where "m" and "M" are the masses of the two objects. If we take m to be the "little mass" and M to be the "larger mass" then, for the smaller mass, ma= GmM/r^2 so a= GM/r^2. For the larger mass, Ma= GmM/r^2 so a= Gm/r^2. That tells us, first, that all objects, attracted by the earth, accelerate toward the Earth with the same acceleration, GM/r^2. At the same time, the Earth is accelerating toward the object with acceleration Gm/r^2 which is, of course, far smaller than GM/r^2.
However, force is NEVER "equal to acceleration". They are different kinds of "things" with different units so never "equal". (For mass, say, 1 kg, the acceleration and force, in the MKS system, will have the same numerical value but still are not "equal". "2 meters per second" is NOT the same as "2 kilogram meters per second".)
You would observe the same forces and accelerations in both cases. That doesn't make force equal to accelerationquincy harman said:What about Einsteins thought experiment in which he said that if you're in a closed box and accelerating at 9.8 meters per second per second in space that you would not know the difference from standing on Earths surface?
