Next Generation Planetary Missions Hunt for Gravitational Waves
Next-generation spacecraft targeting Uranus and Neptune will be equipped to investigate gravitational waves, as outlined in a study by Swiss and Danish researchers (arXiv: 2101.11975). These unmanned probes will utilize Doppler telemetry signals to detect changes in distance caused by gravitational waves, similar to the method employed by LIGO sensors. The proposed method is designed to be sensitive to lower frequency waves due to the vast distances involved, allowing for the detection of waves with periods comparable to the light travel time from Earth to the probes.
  • Understanding of gravitational waves and their properties
  • Familiarity with Doppler effect in telemetry systems
  • Knowledge of interferometry techniques used in gravitational wave detection
  • Awareness of the operational principles of unmanned space probes
  • Research the principles of gravitational wave detection using Doppler telemetry
  • Study the LIGO interferometry method and its applications
  • Explore the design and capabilities of unmanned space probes for deep space missions
  • Investigate the implications of detecting low-frequency gravitational waves
Astronomers, astrophysicists, aerospace engineers, and anyone interested in the exploration of gravitational waves and deep space missions.
veraamorim
TL;DR
Next-generation planetary missions could hunt for gravitational waves, say astronomers
Spacecraft heading to Uranus and Neptune in the next decade could be used to investigate gravitational waves as they venture into the outer Solar System. That is according to a new study by a team of Swiss and Danish researchers, who say that examination of the radio signals from far-flung probes might reveal the signature of these subtle ripples in the fabric of space-time as they roll across our planetary neighbourhood (arXiv: 2101.11975). https://physicsworld.com/a/next-generation-planetary-missions-could-hunt-for-gravitational-waves-say-astronomers/10.02.2021.
If you were one of the crew on this mission, how would you explain in your report what a gravitational wave is and what measuring instrument is available on your ship to track that wave?
Astronomy news on Phys.org
Gravitational waves passing through a region can cause the distance between free-floating objects to change. The Earth is a free-floating object, and so would be a space probe. As far as I can see at a fairly quick glance, they're proposing using Doppler in the telemetry signal from a probe to detect changes in distance (or changes in the rate of change of distance, more precisely, since the probe wouldn't be at rest) to detect such changes.
This isn't in principle different from what the LIGO sensor does. That hangs a couple of objects in an evacuated tube and uses interferometry to detect changes in the distance between the objects. In this case, the distance from one object to the other would be much, much larger, so it it potentially more sensitive to lower energy waves. However, it also means that it could only detect very low frequency waves because of the length of time it takes a radio signal to traverse the distance from here to a probe. It'll only detect waves that have periods comparable to the travel time of the light - a lot lower than the tenth-of-a-second period waves LIGO detects.
Just to be clear, there are not going to be crews on these missions. They're talking about unmanned probes.
